    Page 35 of 48 FirstFirst ... 25 30 31 32 33 34 35 36 37 38 39 40 45 ... LastLast
    Results 681 to 700 of 954
    1. #681
      Woodbine, MD
      Quote Originally Posted by Nothingface5384 View Post
      wow seized!? thats crazy
      I look forward to seeing their roto joint axle ear bushings in your axle and perhaps ridetech posilink swaybar end links to see if your car still lifts a tire!
      Dont you worry...I will have a very detailed install thread on this new suspension. It's going to be awesome.
      Douglas Lutes
      1988 Monte Carlo SS
    2. #682
      Jun 2010
      Blaine, MN
      I have been running the Currie Johnny Joint rear axle ear bushings for a year now. I absolutely love them. Purchased them from Marcus at SC&C. They compliment the Currectrac billet lower and adjustable uppers I have. This setup makes the rear end movement feel very smooth and predictable.
    3. #683
      Apr 2010
      Pittsburgh, PA
      Quote Originally Posted by Sweetmonty View Post
      hows the ride from them, harsh or unnoticable
      Wolfe Racecraft is another that makes these style bushings
      72 buick skylark
    4. #684
      Nov 2002
      state of confusion
      Harshness seems to be more associated with the LCAs and their bushings than with the UCAs and theirs. They take the brunt of the rearward forces caused by hitting bumps and the far sides of low spots in the road.
      I've got the tubular Currie Currectrac LCAs in my Mustang, and as long as there is some lube in the joints the ride quality is noticeably better than stock. Got mine from Marcus, too.
      Noirm
      Gone but not forgotten dep't:
    5. #685
      San Antonio, TX
      Doug, I am going to take a scientific wild-ass guess that the shocks are too long by about 1".
      I am surprised you car isn't bouncy by riding on the bump stops that often.
      What spring rate are you running up front 600-700? Or much higher?
      The LCA spacer/reinforcement plate would have made the ball joint ends probably bend even more, since they would have taken more of a hit.
      I would suggest taking the sway bar end links off, remove the shocks, then measuring the travel up/down from the know ride height, and then compare the travel length to the range your shocks can extend/compress.
      I imagine you can lookup the travel length your shocks have.
      I would imagine seeng the shock travel being about 1 or 1.x inches more than the suspension has, causing the shock to bottom out, then the bump-stops to engage, and the spindle still traveling (what Lance said) and the LCA taking the beating since it cannot move any more.
      New LCA may run the same fate if the shocks are too long.
      JMO
      And no more jumping the Monte, 'aight?
      Dave
    6. #686
      Jun 2010
      Blaine, MN
      There is no harshness at all. The axle feels more connected to the car. No wiggle feeling.
      BEN
      1984 Monte Carlo
      SC&C STREET COMP STAGE 2+, GLOBAL WEST LOWERING SPRINGS, HELLWIG SWAY BARS, CURRECTRAC REAR UPPER AND LOWER, CURRIE JOHNNY JOINT AXLE BUSHINGS, SC&C FRT CHASSIS BRACE, 8.5" W/3.42 POSI, LS1 F-BODY DISC BRAKES FRONT AND REAR, KORE3 BRAKE LINES.
    7. #687
      Woodbine, MD
      I plan to dive into this front end issue next week....so I will have pics and updates then.
      Thanks for all the reply's.....keep em coming!
      Douglas Lutes
      1988 Monte Carlo SS
    8. #688
      Oct 2011
      Peru, IN
      I just read all 35 pages. I need to sleep. I enjoyed your progress!
      JB
      Building a GN to carve corners and travel long distances. *inprogress* Ridetech Coil-Over Tru-Turn Suspension, custom paint by child's tricycle handle, Baer Brakes, 6152turbo, 2800stall, Lonnie Diers Transmission, factory installed T-Top water leak, Casper custom harness, hanging on for dear life vacuum line setup, homebrew ported heads, Translator2, AEM TruBoost control, Good looks by GM, oil and gas by fossils, slightly understanding wife mod, Praise Jesus it runs installation, and Baer Brakes for the 'whoa.' R.I.P. Powermaster 1987-2004.
    9. #689
      Woodbine, MD
      Quote Originally Posted by bishir View Post
      JB
      all 35 pages?? Good lord man!!!
      Any questions? Glad you enjoyed the progress...it is on going.
      Douglas Lutes
      1988 Monte Carlo SS
    10. #690
      Oct 2013
      Woodbine, MD
      [QUOTE=BIGMIKE@ridetech;1061874]Join the ridetech Nation program you will get some special swag and a discount on the arms.[/QUOTE
      What is the Ridetech Nation Program???
    11. #691
      Oct 2013
      Woodbine, MD
      Wow, I am redoing my car, had it setup for going straight but am scratching that for handling. Found your thread in my research and saw your MD tag then realized your in woodbine also, what are the odds. Can't believe I've never seen it around before. Great write up, thanks for all the great info.
    12. #692
      Jul 2012
      Mooresville IN
      [QUOTE=Olds502;1068099]
      Quote Originally Posted by BIGMIKE@ridetech View Post
      The program consist of specialty apparel, product discounts, and a hefty contingency pay out program. http://www.ridetech.com/info/2014/03/get-paid-to-win/
    13. #693
      Woodbine, MD
      Quote Originally Posted by Olds502 View Post
      You're in the Woodbine area too? Where at? You should come check out my shop and I'll take ya for a ride in the car. I'm actually planning a ProTouring BBQ at my house, I'll keep ya posted.
      Douglas Lutes
      1988 Monte Carlo SS
    14. #694
      Woodbine, MD
      Also keep a close eye on this build thread...a lot of cool things are about to happen...
      Douglas Lutes
      1988 Monte Carlo SS
    15. #695
      Sep 2011
      Lawler, IA
      Quote Originally Posted by SicMonte View Post
      I like BBQ!
    16. #696
      The Netherlands
      Country Flag: Netherlands
      Doug, why is the trans swap taking so long....???? I've just seen it only takes a weekend on a Monte! ;-)
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
    17. #697
      Woodbine, MD
      Quote Originally Posted by howehot View Post
      I like BBQ!
      Come on over!!! I'm only about 15 hours from ya!
      Douglas Lutes
      1988 Monte Carlo SS
    18. #698
      Woodbine, MD
      Quote Originally Posted by Martin71RS View Post
      Once I actually start the swap it won't take too long...I just haven't started it yet. Trying to get everything in place before I turn the first wrench.
      Douglas Lutes
      1988 Monte Carlo SS
    19. #699
      Oct 2013
      Woodbine, MD
      I'm on 97, do you have a local shop? Mmmm BBQ
    20. #700
      Woodbine, MD
      I have a home "shop". It's a five car garage with a lift and a full machine shop, welders...the works. I call it Dual-Lit Kustoms.
      Douglas Lutes
      1988 Monte Carlo SS
