    Page 26 of 48 FirstFirst ... 16 21 22 23 24 25 26 27 28 29 30 31 36 ... LastLast
    Results 501 to 520 of 954
    1. #501
      Mar 2010
      Okinawa, Japan
      I'm sure your surprised but I vote 8.5, these are great rears and with just a little upgrading can handle a TON of power. Just going to aftermarket 30 splines and a trutrac is good for any amount of HP in road racing, hell it's good for 10's with slicks at the track... Weld the tubes and add the billet cover and you can go 9's, just look at the GN's doing it.
      All you're gaining with the 9" is more weight and less efficiency for more $$. The only reason you don't see a ton of 8.5's out there is it's just a really uncommon axle.
      My $.02
    2. #502
      East, Tennessee
      Quote Originally Posted by carguykeith View Post
      My $.02
      X2 I agree!
      We have MANY customers with Turbocharged GN's deep into the 10's and into the 9's with a Sh*t load of torque running a built 8.5 rear end. Doug just doing what your planning on will handle 700 rwhp easily at the drag strip leaving off a trans brake but I don't think that's your plan so I think your 8.5 set up will handle even more hp on a auto-X. Save weight, save money and go with the 8.5 Hell I am pushing 500 hp with my turbocharged T-Type with a Stock 8.5, stock axles, stock posi chunk and still holding up fine after 5 years and a lot of 20 lbs boost beatings on the Auto-X & Dragstrip.... I am not changing anything until it breaks and once it does I will be doing Exactly what you planed on without a single worry!
      1986 Buick T-Type
      RideTech, DSE, BAER Brakes, Forgeline Wheels, LED lighting, More!
      * Get your Top of the line GPS Theft recovery devices Here!
      www.GNSperformance.com
    3. #503
      May 2007
      Mooresville, Indiana
      I'm definitely not an expert on rearends (no jabs needed), but I would vote 8.5 for the same reasons. We had planned to run one in Sam's 67 that we're building but found a 12 bolt first. My second choice would be a 12 bolt before a nine inch. We have been running a 12 bolt in our 66 for three years with Moser C-clip axles, Eaton posi and Richmond gear with absolutely no issues. We taking it out right now to replace the axle bearings just for good measure and to add a -8 AN bung for a better vent.
      Just my humble opinion...
    4. #504
      MD
      How much work does the 8.5 need before you can run it? Can you just throw it in and focus on getting a proper transmission in that car?
    5. #505
      Nov 2002
      state of confusion
      Perhaps don't overlook the Ford 8.8" axle. It's what the 2013 GT500 drives through in slightly strengthened form, at 650-ish HP and 600-ish torque.
      Obviously it's still in active production.
      There is or at least was an effort to adapt the 8.8 to the Malibu/MCSS chassis discussed a while back over at maliburacing.
      Norm
      Gone but not forgotten dep't:
    6. #506
      Woodbine, MD
      Quote Originally Posted by tommycomfort View Post
      .......................that is me not jabbing you for that comment. Too easy...too easy.
      When you say a -8 bung for a better vent...can you elaborate please good sir?
      Douglas Lutes
      1988 Monte Carlo SS
    7. #507
      Woodbine, MD
      Quote Originally Posted by SickSpeedMonte View Post
      The 8.5 is just a stock one that was sitting outside for a good while so it is pretty much just a rusty housing.
      Plans are to bring it into the shop...dissassemble...clean...weld tubes...weld on the big ford axle ends...have someone build it with the 30 spline axles and tru-trac...3.73 gears...and a 1350 yolk (is 1350 right?)...then install the Baer SS4 brakes.
      Douglas Lutes
      1988 Monte Carlo SS
    8. #508
      May 2007
      Quote Originally Posted by SicMonte View Post
      Yeah, that rearend statement was a slow pitch!
      The small plastic vent on the stock 12 bolt housing doesn't seem to work too well during extreme use so we plan to tap and plug it and then weld in this bung on the top of the axle tube and run it up to a vent mounted higher. I didn't come up with this on my own, I have seen a bunch of guys that do what we do doing the same.
    9. #509
      Woodbine, MD
      Thanks for the pic Tom!!!
      The car hasn't been touched in quite a while. I recently re injured my back so I have been focusing on getting that back to normal so I can even drive the car!!! All this down time has really made me think of some simple thing I need to take car of on the car.
      1) Move the battery to the trunk
      2) I need a diagonal bar behind the drivers seat per SCCA regulations for the hill climb.
      3) I think I need a new dimmer switch b/c my high beams work and my low beams don't. This blew when my newly built alternator was pulsing between 8 volt to 18 volts.
      4) I think I also have a connection with a buddy of mine to get the car painted! It will still be satin black don't you worry but it will be actually painted instead of rattle canned. I'm afraid it might loose some of its appeal though...
      5) Use the really nice glove box ignition box mount I got from GNS Performance.
      6) Gauges...but those are expensive so probably won't happen any time soon.
      7) Move my trans cooler to the spot where Scot and Dan have thiers...I like that spot WAY better! Thanks guys!!!
      8) Last but not least...possibly pull the motor and freshen it up with new bearings and rings. I was talking to Bob Johnson on FB and he really made me think about running the motor the way it is and crashing it when the motor blows and oils down the track. When the motor is out I would install a Canton RR oil pan as well.
      Any of you got ideas?
      Douglas Lutes
      1988 Monte Carlo SS
    10. #510
      Sep 2011
      Lawler, IA
      Let your back heal. I have way to much experience in my family with back issues. Time is your best friend and don"t over do it because "today" it feels OK.
      It's funny how the little things get pushed aside. I had a list of 11 cleanup areas, mostly wiring, on the Monte the would take just a little time, 2.5 weeks later they where done.
      Spring is coming, hope to see you at another event soon.
    11. #511
      Woodbine, MD
      Quote Originally Posted by howehot View Post
      oh yeah TRUST ME...I am taking it easy even when it does feel better. I am well versed in back pain...
      I had back surgury (laminectomy) when I was 19 to correct my L5S1 disc that totally blew out and that started the whole pain issue. When they were in there they found out that I had congenital spinal stenosis. That basically means that my lumbar spinal column is tapered instead of a constant diameter...therefore pinching and crowding nerves whenever there is any amount of inflamation. This causes pain literally in my a s s and down my leg. Any kind of movement is not fun when it flames up and I even have to walk with a cane. Kinda sad.
      Things were good from 1999 (date of surgury) until about 2007. That's when the pain started to come back. Since then I had had 9 epidural steroid shots, Physical Therapy almost every week, and have had to stop doing things that I love doing b/c they are too much impact on my body. I used to be awesome at snowboarding..no more of that. No more boat rides on the bay with my buddy's...etc. It's weird that racing my car doesn't affect me at all! I guess it is the fact that I am strapped in the seat so tight that I don't move around. Good thing I guess.
      Yes spring is approaching fast. With all the events being so far away I am afraid that I will only be able to compete at RTTH. Last year Kim and I really went all out and hit every event we could and while it was an absolute blast...it killed me money wise and car wear wise. After blowing the trans and possibly the motor...I need to pick and choose events wiesly! I will still do a bunch of local events though and will never miss that hill climb again, but I just can't justify the expense to travel 8+ hours,or even farther, for an event. The only exeptions there are RTTH which I will never miss, and the OUSCI if for some un Godly reason I get invited, but im fairly certain that I don't have to worry about that! lol
      Douglas Lutes
      1988 Monte Carlo SS
    12. #512
      Woodbine, MD
      Just letting you all know that yes I am still alive...just in pain and currently getting different "opinions" on back surgery. Car is in the shop just begging to be driven.
      Douglas Lutes
      1988 Monte Carlo SS
    13. #513
      MD
      I'll come pick it up for you Doug.
      Don't mention it, any time ;)
    14. #514
      Woodbine, MD
      If you want to come over to drive it so I can make some youtube videos....done.
      Douglas Lutes
      1988 Monte Carlo SS
    15. #515
      Woodbine, MD
      with the current status of my physical therapy and back rehab...it's looking like the Polish Mountain Hill Climb and RTTH will be my only events this year.
      Sad but True.
      but I will still keep you all up to speed on the small improvements I do to the car and of course all my youtube videos I have to put up......LOTS OF THOSE!!!
      http://www.youtube.com/user/sicmonte?feature=mhee
      Douglas Lutes
      1988 Monte Carlo SS
    16. #516
      Woodbine, MD
      Douglas Lutes
      1988 Monte Carlo SS
    17. #517
      Woodbine, MD
      So I need to get a few loose ends tied up for this upcoming CDC/SCCA/ASCS season. This is the first one....
      My Bear Prop Valve is leaking at the highlighted connection. I took it to Facebook and was contacted by Gabi Baer with in about two minutes...then on the phone with Bear in about another two minutes. When I called Rick picked up the phone and new exactly who I was and what my issue was. He even said "are you Doug with the red arrow in the picture". Now that is customer service!! Got the info that I needed (pipe thread = teflon tape) and all is well over here!!
      Douglas Lutes
      1988 Monte Carlo SS
    18. #518
      Indiana
      You gotta love great customer service!
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
    19. #519
      Woodbine, MD
      Well today was a good day....a great day!!!
      I had my last doctors visit today concerning my back and it turns out that I am no longer a candidate for back surgery!! The pain and symptoms could come back at any time but the surgery needed is just too major at this time that we are going to try to mamage my current situation. Good news in my book. So I need to get my life and body back in shape. And once that happends about mid summer...I should be ready to get back into my Monte.....
      I have my sights set on RTTH.....watch out.
      Douglas Lutes
      1988 Monte Carlo SS
    20. #520
      Apr 2013
      houston
      i was wondering what kind of pulley set up you have i like how its still a v-belt set up but use serptine belt. my stock set up use the serptine belt for the water pump alt and crank but ps uses vbelt
