    Page 17 of 30 FirstFirst ... 7 12 13 14 15 16 17 18 19 20 21 22 27 ... LastLast
    Results 321 to 340 of 587
    1. #321
      Dec 2007
      Carlsbad, Ca
      so im thinking something along the lines of jcg's camaro build except centered in height instead of the half moon style cutout.
      Tim
      Build Thread Link
    2. #322
      Birmingham, AL
      That would look nice. I think it would look good if you used the lines of the taillights as a guide for the exhaust tips.
      Stephen
    3. #323
      Quote Originally Posted by srh3trinity View Post
      X2! That's exactly what Kris did with the Camaro so just modify the shape of yours to do something similar following the outer line of the valance.
      Jason
    4. #324
      Dec 2010
      Windy City, IL
      I've always been a fan of the '70-'72 GM A-bodies (with a 25 year collection of '70 Buick GS's to prove it), and as much as I do like the '70 Chevelle, I always thought it would look better with the '71 rear bumper, just to be uniform (4 round headlights, and 4 round taillights; instead of 4 round headlights & 2 small/square taillights).
      As far as the exhaust tips, the Buick had an N-25 (exhaust through bumper) option in '71/'72, which I'd also like to modify/improve (as I'll be incorporating it into my '70 GS Stage 1, which never had the exhaust through the bumper option), similar to what you're doing with the Widowmaker, Tim!
      Now that I see this pic of the '69 Camaro, that is very appealing and inspiring for cars like ours!
      I actually get goosebumps every time I go through this thread, Tim, looking forward to seeing the Chevelle finished, and excited to begin my similar build of my '70 GS, now that the 6' snowdrifts are finally beginning to melt away!
    5. #325
      Dec 2007
      Carlsbad, Ca
      protourgsx, thanks for all the kind words. i am a little weird though, and i love the 70 rear bumper. dont know why, just havent liked the 4 tail light look. but i like the 4 head lights.......... i couldnt really give you a good reason why though.
      thanks for the help. i laid out some ideas today and now have something in mind. i just need to hit the metal shop and pick up some stainless sheet to play around with.
      Tim
      Build Thread Link
    6. #326
      Sep 2009
      Oxnard, CA
      Let me know if you need any help their Tim!! Your doing a fantastic job on your car..
      Quote Originally Posted by The WidowMaker View Post
    7. #327
      Dec 2007
      Carlsbad, Ca
      Thanks Cris! im headed up north either the 3rd or 4th of next month and would love to stop by. i'll shoot you a pm when the date is a little closer.
      Tim
      Build Thread Link
    8. #328
      May 2010
      kitchener,Ontario,Canada
      Tim
      great build ... and still a inspiration for me to remove my ass from the couch and put mine together lol...back to your exhaust I've always loved the stock tips and exhaust location. I think with the tank location and how the trunk drops off on the sides its the best locale..thanks for all the great ideas ...mainly the rear bumper
    9. #329
      Sep 2009
      Oxnard, CA
      Stop on by Tim! Look forward to meeting you & giving you a little shop tour..
    10. #330
      Dec 2007
      Carlsbad, Ca
      a question for the metal experts; i picked up my new door shells and am acutally impressed with the rear fit of the drivers side so far (still a lot to go). the gap is really consistent and the profile matches the quarter well. i was prepared to weld an 1/8th" round rod to the edge of the door to assist in working the gap, but found that i only need to take off a little in one area. so, would you prefer to weld a rod the entire length of the door, or just remove some material? doing so will likely split the skin, but i can either mig or tig it back closed and then file to fit.
      which would you prefer?
      i do have to weld a rod to the bottom. the gap is a little too wide (~.320), although very consistent since its within .015 front to back.
      also, what do you guys do to build an edge up to get panels to flow better across the gap (height not width)? would you rather build with a weld bead of tacks, weld a rod or do the work with filler?
      Tim
      Build Thread Link
    11. #331
      Sep 2009
      Sandy, OR
      Tim I would remove material and where it splits just weld it back up.
      As far as if you need to add material I use 1/8" plate welded and ground filed to create a consistent gap. You NEVER want to use filler on an edge. If it is a slight gap in spots I just put down a few beads w/ the mig and grind/file to even the gap up. There are several ways to do it. if I need to fill a long gap I add plate. If there are a few smal spots then I put some mig beads. HTH
    12. #332
      Dec 2007
      Carlsbad, Ca
      thanks for the info Luke. i worked on the rear gap today and have it looking really good. i'll shoot some pics and post them up tomorrow.
      Tim
      Build Thread Link
    13. #333
      Dec 2007
      Carlsbad, Ca
      i finised working the rear gap of the drivers door today. i filed it down until it was perfect yesterday and then went back and welded it all up to make sure it wasnt going to split. today i filed the weld down until it was perfect again. it measures .190-200 all the way down. the quarter makes it hard to measure since it doesnt angle in 90* but i tried to do it as consistent as possible.
      i am still pretty amazed at how well it all lined up. you can see in the second pic that the profile matches the quarter very well for having no work. its in about .015 right under the body line and also a little more at the bottom. i plan to work those areas when i get back to the car next week.
      Tim
      Build Thread Link
    14. #334
      Oct 2006
      McKinney, TX
      what do you use to straighten up the gaps? I used steel rod for my trunk, but it looks like whatever you are using has a straighter edge.
      Looks really good!
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
    15. #335
      Dec 2007
      Carlsbad, Ca
      it was all a weld bead and a file. i would have added a rod, but the gap needed to be smaller, not larger. it filed down pretty nice, but i wasnt comfortable taking .020 off of .035 sheetmetal. so i welded it back up to get the penetration deeper to seal it back up and then filed it down again.
      Tim
      Build Thread Link
    16. #336
      Jan 2007
      Yardley, PA
      I had to do the same with my one 64 Chevelle vert. I had to grind down, and weld it back up, to keep the skin from coming off the inner frame.
      Looks great, a time suck, but worth it in the end.
    17. #337
      Oct 2006
      Corona, CA
      Keep up the good work Tim! Car is looking amazing. Radiator looks nice, and the gaps on that door look stellar. Best part is you are doing all the work yourself! Kudos bud...
    18. #338
      Dec 2010
      Apex, NC
      I love this build! Great work!I am doing all of mine in my garage and hope I can weld anywhere close to this good.
    19. #339
      Feb 2011
      North Idaho
      those door gaps are top notch
    20. #340
      Feb 2009
      caly
      thats is a nice chevelle
