    Page 15 of 30 FirstFirst ... 5 10 11 12 13 14 15 16 17 18 19 20 25 ... LastLast
    Results 281 to 300 of 587
    1. #281
      Dec 2007
      Carlsbad, Ca
      Nice work fixing the gaps on the bumper. Its going to make a big difference.
      i hope so. its now easy to see how paying someone to do this kind of work would be big bucks. i spend a crap load of time getting it all nice and aligned and then need to pull it off to tweak a bracket etc.... then its more time to get it back aligned where it was. all the little stuff takes a ton of time.
      Tim
      Build Thread Link
    2. #282
      san diego
      May 2008
      SoCaL-Pico Rivera
      Tim did you get your wheels?
    4. #284
      WOW awesome work!!!!
      Dec 2007
      Carlsbad, Ca
      not yet. now that sema has passed, im hoping its soon.
      Tim
      Build Thread Link
    6. #286
      Dec 2007
      Carlsbad, Ca
      so another 25 hours later (not kidding), the brackets are welded on the bumper and its been off and on and falls back in place. this thing was a PAIN in the ass. the main problem i had was how the brackets mounted to the bumper. since the mounting surface wasnt flat a slight movement twisted the bumper instead of just moving it up or down. since the bumper has dimension to it, and some areas are closer or futher from the axis, a small twist would send some areas +/- .050 out of spec. this caused so many headaches that i was ready to just give up. but, like i said the bumper is DONE. i still need to finish cleaning up the quarters and i still need to fit the lower valance. this was all supposed to be done weeks ago.
      like ive said before, i am breaking all of the purchases up and buying stuff in advance. this has screwed me many times and ive sold and repurchased a ton of parts, but if i dont spend it on the car, it gets spent at friggin Target. this month i picked up my single 10" subwoofer and the ISIS inmotion controller. for the sub, and after a ton of research, i picked up a focal 27v2 to go with the focal components. i narrowed it down to a few, but decided to just stick with one brand for the audio. its not a loud sub, but the quality is supposed to be amazing. i'll be building an enclosed box in the coming months.
      i also have a little money left to send to mike a musclerodz. ive given him a few deposits which all should add up to a PRC radiator and ac condensor in the near future. i was stressing about the ron davis/prc choice, but ive decided to add an intank engine oil cooler. rd wanted 700 since they cant fit it in a stock tank and it then makes it a tank custom, and PRC wants 85 and says if it needs a custom tank there will be no charge. i think the $615 difference in oil coolers, plus the $260 in base price has made my decision. i really hope prc delivers on their welds. ive seen some really good and some pretty good. rd usually looks machine done.
      hopefully i can get the rest of the bumper buttoned up and some new pics soon!
      Tim
      Build Thread Link
    7. #287
      Aug 2009
      Langley BC, Canada
      Quote Originally Posted by The WidowMaker View Post
      i got all the front suspension assembled today. i didnt finish until almost dark, so i'll get some better pics tomorrow. i still need to brush the tie rod connectors and figure out what to do with the sway bar heims to get rid of the gold zinc. i also need to feel out the red bump stops a little more. they look really out of place now, and if they dont tie together a little better as it comes back together i will replace them with some black ones.
      the rear suspension should be mostly done tomorrow. im also still waiting to get the wheels back. i didnt like the color even though i gave them the code, so they are being stripped and reshot. i should be getting them back in a couple weeks.
      i hope to have the frame under the body sometime in the next week. i need to work a couple areas including the raised fuel filler neck relief before i drop it on.
      I posted on the Lat - G thread but this one gives me email notifications (for some reason the Lat-G forum doesnt) Any way awesome build first off!!!!! What black coating is used on the bolts, swaybars, suspension parts..........? It looks awesome and wouldnt mind doing all mine!!! Keep up the awesome work I wouldnt ever guess this is a garage buildif I didnt see the pics on here!!!
      Kevin Freund
      1961 Impala Drop Top
    8. #288
      Dec 2007
      Carlsbad, Ca
      btw, just a quick update. its been raining here and i havent been able to roll the car out to work on the rear bumper, so i started on the wiper motor relocation. i wasnt able to come up with a way to make it work with the stock linkage, so im mounting an arm where the old motors arm was and then connecting my new linkage to that to power the wipers. everything is still hidden, but im on my 3rd design. its been fun playing with the mill and the lathe. ive run into a few snags, but i'll have pictures and an explanation when its all done. im not sure how others have done it on the chevelles, but i couldnt come up with any other good ways.
      Tim
      Build Thread Link
    9. #289
      Dec 2007
      Carlsbad, Ca
      here you go. this is all i really know.
      Tim at work we use a coating called everlube 6107 gloss or flat black. I had fasteners coated in this for my car.(Link below). I have some bolts I can send you to take a look at. I am sure I can get your bolt coated in this at no charge.
      It looks better than zinc and better rust protection.
      http://www.metalimprovement.com/coat...cesses.php#cce
      Tim
      Build Thread Link
    10. #290
      Aug 2009
      Langley BC, Canada
      Thanks for the help Tim, I will try to search around local here in Canada and see what I can find.
      Kevin Freund
    11. #291
      Girard Ks
      Ive read ur hole thread and the car is going to look super nice
    12. #292
      May 2008
      SoCaL-Pico Rivera
      Quote Originally Posted by 61ragtop View Post
      Kevin just sent you a pm.
      Tim if you need me to redo any of the part just give me a call.
    13. #293
      Dec 2007
      Carlsbad, Ca
      i really wish i knew more about it, but Fabian is the man. they have held up great to sockets and the coating doesnt add but a few mils to the fastner size. regular nut/bolt/lock washer combos are a breeze, but the pinch nut locking nuts were just a little harder to get on. i'll have to be a little more careful with my torque ratings.
      thanks!!!!!!
      Tim
      Build Thread Link
    14. #294
      Aug 2009
      Langley BC, Canada
      Awesome to hear they are good with the sockets that's what I am lookin for. Fabian has filled me in on it. That ms again to both for the info.
      Kevin Freund
    15. #295
      Dec 2007
      Carlsbad, Ca
      so here are a few pics of the new wiper setup. its still a work in progress, but now all i really need is the linkage from the wiper motor to my new arm and its done. i have an 18" piece of aluminum hex on order from mcmaster and it should be all i need.
      so a little vocabulary to keep it all straight. "arm" is the pitman style arm on the motor and the new arm on the firewall. "linkage" is the stock piece from the wipers to the firewall arm and from the motors arm to the firewall arm.
      a little background. i originally thought that the motor only spun 180* and then reversed. its the only way my mind could grasp how the motor could "park" the wipers when turned off. i had thought that when turned off the motor just spun backwards a little more sucking them down. i was wrong. using a method still unclear, the motor spins clockwise 360* and then uses a cam action to make the arm longer when turned off. this is how they are sucked down.
      so, the original thought was to just rock the new arm back and forth like i thought that the stock arm went. once i found out that it went in circles it posed a slight problem. the new motor would be providing a lateral force, not a rotational one. meaning, if both arms were the same length there would be an issue getting the new arm to pass both 90 and 270 without ripping something apart. since the stock arm was 2.25" and the dse is closer to 2" (still need to call on that), i decided to make my new arm 2.5". this means that my arm will never be forced to make the full circle and instead will just rock as initially intended.
      the other issue was the mounting of both linkages on the new arm. i had a few ideas but settled on this one. i had to do some milling to offset the mounting points and to keep the thickness thick enough to tap, but thin enough to keep the stock linkage from pushing too far towards the windshield. the closer to the windshield it gets the more bind that is introduced. this is currently a sweet spot and there is no bind.
      here are the pics. like i said, still needs to be cleaned up.
      Tim
      Build Thread Link
    16. #296
      Dec 2007
      Carlsbad, Ca
      i built arm #3 last night but bored .020 too deep for the bearing seat and the snap ring fits too loose. i dont have enough material to bore another .025 and add a second snap ring, so arm #3 is going in the trash after a couple hours work. i changed some things up a little on this one, but most notably i swapped the side being milled which required a smaller relief and it presents with a solid side when viewed instead of the offset notches that you see now. i also overlapped the area around the notches so its full thickness for .188 instead of being much thinner like the one above.
      i did however clean up arm #2 above and it looks much better with the newly radiused corners. since arm #3's main difference was appearance, and since you wont friggin see it anyways, i may not build a #4.
      i work the next 48 hours, but plan to get the linkage hooked up on sunday after making a few more small parts. i may also do a short video clip to show how it all works.
      Tim
      Tim
      Build Thread Link
    17. #297
      Dec 2010
      Windy City, IL
      Tim,
      Highest compliments on the finest example of an A-body that I've ever seen! I'm also attempting to resurrect a '70 GS Stage 1, to be improved similar to yours, but have no sheetmetal/bodywork experience.
      With the window channels rusted out like yours, do you have more detail to explain or show how you replaced the metal to the point it is? Looks great, otherwise!
      I'm VERY interested to box in my frame, and add the crossmember/driveshaft loop/exhaust/transmission channels, too!
      Is your frame a Convertible frame, to start with?
      It doesn't look like a Hardtop frame, for some reason.
      Link to my project:
      https://www.pro-touring.com/showthre...-1-project-car
    18. #298
      Dec 2007
      Carlsbad, Ca
      i started off on a very tight budget with a stock rebuild in mind. i was going to strip it and get a cheap paint job and drive the crap out of it. then i found the forums............ so, what started as metal replacement in the channels turned into two new quarters once the budget was raised. the channels were my first body work project and they turned out nice, but the car needed alot of work to the bottom of the quarters as well. it was just easier to start over with the new quarters. what looks like rust on the front is just the underside of the vinyl top mixed with some glue. i havent really dug into it yet to find out the damage, but i think its going to be MUCH better than the rear.
      i dont have anything really good to show how the work was done. i used a metal brake to from the 90 and then used a stretcher to form the corners. i test fit everything with the window in place and the chrome strip mocked up to make sure it would all be nice when done.
      the frame is the original from the malibu. as far as i know the convertible frames were boxed from the factory.
      i'll keep an eye on your project.
      Tim
      Build Thread Link
    19. #299
      Dec 2007
      Carlsbad, Ca
      here is a little video of the new linkage. i am actually making the 4th arm tonight. this will have a little different ratio to get a full sweep on the window. the first few arms assumed that the starting angle and the finishing angle would be the same. since that didnt actually happen, even though the motor was moving the arm 4", it was only moving the stock linkage about 3.75". that .25 was a few inches of the window.
      theres one other issue that im working out with a few phone calls, but i hope to have an answer tomorrow.
      Tim
      Build Thread Link
    20. #300
      Dec 2007
      Carlsbad, Ca
      i finished ironing out the issues tonight with the remote setup. i ended up making another arm.... yep, number 5. this one takes dse's .550 and turns it into about .280. it keeps the wipers much further down using the delay feature. i called them again and spoke about the difference and they cant give me an answer as to why theirs parks the wipers so much more. either way its done.
      oh and about 6 months ago i promised myself that i was done swapping unused parts and losing money. but since the brand new tko is up for sale i guess i didnt keep my promise. i have a couple guys interested and the bell housing is already sold. a t56 magnum will be going in its place.
      Tim
      Build Thread Link
