    Page 93 of 101 FirstFirst ... 43 83 88 89 90 91 92 93 94 95 96 97 98 ... LastLast
    Results 1,841 to 1,860 of 2014
    1. #1841
      san diego
      Quote Originally Posted by iRoush View Post
      looking good bryce, 8.5 degrees of caster with that steering is going to require some manhandling! Can't wait to see it run!
      Good thing I am 250lbs of hungry. I can put my weight behind it. HAHA. I still want to add power steering.
    2. #1842
      Dec 2010
      Bryce, in case you change your mind about the future hydraulic power, my Electra-Steer (the "improved" 4500-lb version) is surviving my normal abuse quite nicely, and has been autocross tested (more to come); my normal (twisty road) driving is arguably more harsh than an autocross. I'm running a 1.5:1 quickener into it; the computer makes everything work great, sensing torque input as well or better than the EPS on my 2012 Honda. All it takes is a bit of room under your master cylinder or dash...
      If you've got a minute, I have a question about your Stealth quickener: Is there any of the typical slack (slight, however noticeable) that seems to be common to many quickeners (mine is a basic Howe)?
    3. #1843
      san diego
      Quote Originally Posted by rustomatic View Post
      I looked into the electric steering and was not satisfied with the cost or load rating. But that's good to here and I will further investigate....
      I like my quickener. I have a little slop maybe 1/60 of a turn.
    4. #1844
      Dec 2010
      Thanks for the quick feedback, Bryce! I was kind of wondering if somehow the inline setup of the Stealth would behave any differently from the off-center configuration of most other quickeners (like my basic Howe). You're a dependable source of info!
    5. #1845
      san diego
      thanks bud, anytime!
    6. #1846
      san diego
      well found out my rear shocks are shot. Zero compression dampening and no change with the adjuster..... rebound adjustment over 4 clicks from soft is locking up the extension of the shock and not allowing the shock to extend back to ride height after a bump. weird.
      SO I will be buying new shocks, Afco makes a triple adjustable that will fit and ridetech shocks would fit. Not sure which way to go right now. I really don't want to spend 1100 dollars for rear shocks right now.
    7. #1847
      san diego
      san diego
      The falcon did really good yesterday. I finished 3rd in SU and 2nd in pro-touring. (.070 seconds behind rich in his 69 mustang). Good job rich.
      The car felt great all of the front end push was gone. The rear shocks were noticeable bad. I was getting wheel hop on acceleration as the car would hit the bump on full compression then oscillate violently. Also the car was porpoiseing over the bumps. I think some fine tuning and new shocks and I will competitive.
      I will post video and pics tonight.
    9. #1849
      san diego
      here is my fastest lap 68.xxx
    10. #1850
      san diego
      san diego
      well the old shocks had some internal issues and were not working properly, I ordered the SA ridetechs last week and they showed up today. So of course the first thing I do is put them on the car.
      such a noticeable difference and I haven't left the garage yet. The quality on the ridetechs are second to none. I can see the engineering thought that went into theses and that makes me smile.
      now for pics:
      old ones came out:
      I am reusing the springs at a rate of 225lb. Change one thing at a time and tune from there.
      Boxes unpacked:
      Installed:
      Upper mount:
      I am also adding a catch can to the breather system.
      Initial mockup:
      This car is sooooo tight to work on, everything just fits.
    12. #1852
      May 2008
      Austin, Tx.
      Great job Bryce!
      The suspension must be working REALLY well... I didn't hear the tires chirp once!
      Ray
    13. #1853
      san diego
      Quote Originally Posted by 454bug View Post
      Great job Bryce!
      Thanks Ray, the car feels really good now. With the new shocks my confidence should be higher and I should be able to start really pushing the car. My next race is the 4th. So I am almost ready now.
    14. #1854
      Nov 2007
      Lafayette, LA, USA
      sweet
      Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting - Holy cow - what a ride!!!
      See my build
      Jason
    15. #1855
      Jul 2012
      San Diego
      Looks Like it could be a Street Unlimited SDR Winner.Rich will have to work a little hard to keep up or win.I hope Tayler makes it.I haven't seen the 66 Fairlane vs 66 Chevellle in a long time.
    16. #1856
      san diego
      Sunday should be a funday. I cannot wait to see how the car feels on the track.
    17. #1857
      san diego
      Took the falcon the autocross today. I did okay. Still way too much body lean. I think I was lifting the inside rear tire. The stiffer springs and sway bar and shocks helped. It allowed to go faster around the turns but the increased lateral-g increased the body roll. Time for new springs on all 4 corners and a 1/4" wall thickness sway bar. That is an advantage of the splined sway bar. Quick change!!! I will get video and pictures up tomorrow.
      I also need a jack Roush hat, my floppy hat was just not cutting it.
    18. #1858
      san diego
      Quote Originally Posted by PRO-66 View Post
      http://youtu.be/yb2phchYkIY
      Here you go guys. Not my best work, but wanted to get something up before going out of town.
      Here is a video that mark took.
    19. #1859
      san diego
      A quick review of the last autocross:
      The ridetech shocks are awesome and I found out I can get them too stiff. This is a good thing for tuning.
      But I have a lot of body lean. So I ordered some new parts.
      Splined sway bar 33% stiffer than the old one.
      I ordered it uncoated (black zinc) so that I would get it on time.
      So I coated it with this. It puts on a light clear film and last 2 years.
      Out with the old
      New spring stack on the left.
      Assembled with the 25lb take up spring and the new 500lb springs.
      Installed:
      First test drive will be tonight.
    20. #1860
      san diego
      A few weeks ago I weighed a bunch of cars.
      My dads ranchero:
      My buds RSX, that he autocrossed with us the next day. He won the rookie class.
      Neighbors Busa:
      He needed blocks to reach the floor.
      Same neighbors Sky, I keep try ing to get him out the autocross.
      Tylers fairlane
      I get to use race car parts at work. Woohoo.
