    Page 98 of 101 FirstFirst ... 48 88 93 94 95 96 97 98 99 100 101 LastLast
    Results 1,941 to 1,960 of 2014
    1. #1941
      san diego
      Quote Originally Posted by Racer351C View Post
      Its been a while since I have been on the forum to check out any updates on the Falcon. Life has been very busy. Nice fabrication on the assist cylinder bracket. How did you get around the flange on the outside of the frame rail? I remember using one of the brackets sold by one of the header manufacturers on my 67 Cyclone. They do flex alot. Those nuts that are factory installed in the bottom of the frame rail aren't very solid to begin with. Your design definitely ties it all together well. Congrats on the addition to your race team. HAHA!
      thanks racer! I used spacers to clear the flange. I started with a solid 3/4" plate and match drilled the holes to the frame but with the slight variations of the frame it did not work, so now I use a unique thickness spacer at each bolt hole, with large OD.
    2. #1942
      san diego
      Quote Originally Posted by j-c-c View Post
      This solution is from a car guy, you need a concrete grinder.
      I would need to resurface the Qualcomm parking lot, otherwise I might get stuck...
    3. #1943
      san diego
      Quote Originally Posted by rustomatic View Post
      It's shortie time! With my shorties (pipes tucked high), I've got somewhere between three and four inches, and it's still a pain at times; they do have ball flanges though, which helps with adjustments, for whenever I get around to making my big single. Mufflers are too thick... Still, I'll resist running a Supertrapp through the passenger door...
      custom headers are in my mind right now.
    4. #1944
      alpine ca
      time to call ed hanson they'll be pricey thou bud had great time sat and merry christmas
      john
      BUILD LINK
    5. #1945
      san diego
      I took some time off work and didn't work on the falcon, but I did some garage mods.....
      I have wanted to insulate and drywall the garage since I moved in. I finally got around to it.
      I stripped the walls down to studs.
      Moved some outlets and added insulation.
      Drywall up, time for mud and tape.
      Two coats of primer
      one side done, painted with super high gloss white paint with a glass like finish.
      time for the second side.
      added some outlets and a switch to turn off a few of my overhead lights when not needed. that counts as being green right?
      drywall and tape and mud done
      done, now to put the mess away.
      almost there, time for some garage art and foldup workbenches, and I need to get everything hung up on the walls and off the floor.
      its like being at a drive-in....
    6. #1946
      Ontario, Canada
      That water heater and washer/dryer combo should be replaced with a blast cabinet and air compressor.
      Ken
      My other car is a Vega.
    7. #1947
      alpine ca
      ya and that tv needs to be in the living room (mine)
      jophn
      BUILD LINK
    8. #1948
      san diego
      Quote Originally Posted by Kenova View Post
      Ken
      I have to keep the washer dryer to keep the wife happy. But I have considered a instant hot water heater using gas. This would free up some space for a bigger air compressor. I have a 33gal now and it doesn't keep up with the die grinders.
    9. #1949
      san diego
      Quote Originally Posted by johnny68 View Post
      jophn
      The wife wanted a bigger tv for our living room. So I took the 55 and bought her a 70inch.
    10. #1950
      May 2013
      Texas
      Quote Originally Posted by Bryce View Post
      Only car lovers would list one of the benefits of a tank-less water heater to be freeing up valuable garage space. I did the switch and was very happy with performance AND the space I got back.
    11. #1951
      san diego
      Quote Originally Posted by Munssey View Post
      awesome, I will remember that when I get closer to the switch.
    12. #1952
      san diego
      I will be scaling the falcon this weekend at my house, let me know if any of you guys want to stop by a get your calls on the scales.
    13. #1953
      Dec 2010
      Is it a sign of age or car-overdose when this many of us are thinking of tankless water heaters on a hotrod site?
    14. #1954
      Jan 2013
      So how much did your car weigh? I am guessing 2850.. Mine weighted 2950 when I dropped it off at Agent 47... without bumpers and a half tank of gass... all steel car with full interior and iron block and heads.
    15. #1955
      san diego
      Quote Originally Posted by Lance Carbuncle View Post
      2720 without driver and 10 gallons of gas. The power steering only added 6lbs.
    16. #1956
      san diego
      I think its the difference between theoretical and applied hot rodding.
      In theory we build hot rods but actually we have to live in the real world with limitations. Garage size being one!
    17. #1957
      san diego
      I am still surprised the power steering only added 6lbs.
      I ordered stickers and put them on a magnetic sheet and cut them out to make some nice removable numbers. And they passed the freeway test.
      I didn't order letters, so I printed some letters and used them as stencils on some carbon fiber tape on the same magnetic sheet. Worked out good.
      I also got a new autocross hat, this should keep the sun off my face and neck while working the course.
    18. #1958
      san diego
      I just experienced the first SDR event with the CAM guys. What a great turn out. I had a blast running with the friends. The car felt great, the power steering felt great, still has feel.... The stiffer rear spring really balance the car out and the overall package was great to drive. I don't really have any other mods planned before the next SCCA event.
      Here are the videos:
      Pictures and results next week.
    19. #1959
      Mar 2013
      I flipped through the build today. I didn't see videos, but the car and all of the details are amazing. Let me know if you want a rendering of your car.
    20. #1960
      san diego
      Thanks Driveit. I appreciate the offer. If you look at the post right above yours you can see the latest videos. I think youtube was slow uploading them and thats why you didn't see them earlier.
      I already had a rendering done back in 2012. But I will keep you in mind if I ever need another rendering for this car or another.
