    Page 6 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
    Results 101 to 120 of 261
    1. #101
      New York, NY
      pics as promised, not ride height though...about 2 inches higher spring adjusters are still not adjusted and no weight either
      and I know front wheels are switched...
    2. #102
      Feb 2008
      looks good for sure!
      i dunno if this has been covered or not but rear swaybar gonna happen?
    3. #103
      New York, NY
      I'll use a splined bar w/arms. There are tabs on the axle for the endlinks, and bushings are on their way in the mail, but I won't buy a bar/arms until I know how much bar I need after driving it.
    4. #104
      Jun 2008
      Carol Stream, IL
      Quote Originally Posted by jerome
      ...I have plenty of room for suspension adjustment, I just need to plug in the numbers into the code I wrote, and it's pretty easy to figure out which hole to put the bolt in...
      Care to post this code you came up with, or at least let us know how you came up with it? Sounds like a great idea, but I wouldn't really even know where to start
    5. #105
      New York, NY
      %x=out
      %y=forward
      %z=height
      %a=axle f=frame
      %l=lower u=upper
      %INPUTS
      cgh=24; %center of gravity height
      wb=109; %wheelbase
      axh=13; %axle height
      al=[-22.25 22.25;0 0;8 8]; %lower links axle coordinates
      au=[13;0;18]; %upper link axle coordinates
      fl=[-8.5 8.5;28 28;10.5 10.5]; %lower links frame coordinates
      fu=[13;13;17]; %upper link frame coordinates
      pb=[0;-6;13]; %panhard coordinates
      mc=3000; %mass of car
      mr=250; %mass of rearend unit
      axr=4.10; %rearend gear ratio
      %ANALYSIS
      mu=(fu(3)-au(3))/(fu(2)-au(2)); %slope of uppers
      ml=(fl(3,1)-al(3,1))/(fl(2,1)-al(2,1)); %slope of lowers
      in=[-mu 1;-ml 1]\[au(3)-mu*al(2);al(3,1)-ml*al(2,1)]; %intersection
      SVSA=in(1) %side view swing arm
      antisquat=(in(2)/in(1))/(cgh/wb)*100 %antisquat percentage
      pvcy=(fl(2,1)-al(2,1))*al(1,2)/(al(1,2)-fl(1,2)); %plan view convergence y coordinate
      pvcz=(fl(3,1)-al(3,1))*pvcy/(fl(2,1)-al(2,1))+al(3,1) %plan view convergence z coordinate
      offset=(au(3)/(al(3,1))*axh*mc)/(axr*(mc-mr)*(cgh/wb+abs((au(3)-fu(3))/(fu(2)-au(2))))) %third link offset necessary for 100% cancellation
      conv_angle=atand((fl(1,1)-al(1,1))/(fl(2,1)-al(2,1)))
      %PLOTS
      subplot(2,1,1) %plan view
      plot([al(1,1),fl(1,1)],[al(2,1),fl(2,1)],'b') %lower driver
      hold on
      plot([al(1,2),fl(1,2)],[al(2,2),fl(2,2)],'r') %lower passenger
      plot([au(1),fu(1)],[au(2),fu(2)],'k') %upper
      title('Plan View (top is front)')
      subplot(2,1,2) %side view
      plot([al(2,2),fl(2,2)],[al(3,2),fl(3,2)],'r') %lower arms (uses passenger numbers)
      hold on
      plot([au(2),fu(2)],[au(3),fu(3)],'k') %upper arm
      plot([al(2,2),wb],[0,cgh],'c') %anti-squat line
      plot([fu(2),in(1)],[fu(3),in(2)],':k') %upper extension to intersection
      plot([fl(2,1),in(1)],[fl(3,1),in(2)],':r') %lower extension to intersection
      plot([pb(2),pvcy],[pb(3),pvcz],'m') %roll axis
      th=linspace(0,2*pi);
      plot(13*sin(th),13+13*cos(th))
      plot(3.25*sin(th),13+3.25*cos(th))
      title('Side View (right is front)')
      axis([subplot(211),subplot(212)],'equal')
      you can run it in matlab if you have it. I basically just calculated roll steer, side view swing arm lengths, and antisquat numbers for a given set of arm lengths and angles. You can then change the angles and see how these numbers react in bump and droop. A bit messy, but it works.
    6. #106
      Jun 2008
      Carol Stream, IL
      Thats quite the complex code. How much have you had to use it? I'm guessing a bit since you have the suspension set up already. Hope this all works out for you with the wheelbase/bed being off. I'm sure you'll get it right though, judging by the rest of the project
    7. #107
      New York, NY
      haven't used it recently, just for planning it. as you can see the wheelbase variable still says 109 for when I thought it was a shortbed haha
      I will have to use it again to figure out initial settings for first drive though
    8. #108
      Oct 2007
      Newark DE
      Any updates?
    9. #109
      Aug 2008
      Lawrence, KS
      Wow, lotsa work involved. Interested to see the finished product.
      Measure once, cut twice and pray.....
    10. #110
      New York, NY
      taking the gmat(standardized test) tomorrow, so I've just been studying for the past two weeks.
      The thrash to get it driving begins tomorrow night, goal is to drive in two and a half weeks!
      stay tuned, hopefully I'll have some good updates in the coming weeks.
    11. #111
      Batesville, IN
      Wow - I haven't seen Matlab code since my engineering days back at Purdue - 2002.
      Brings back some fond memories and some horrible nights in the computer lab writing code.
      Keep up the good work.
      Later
      Brandon Wiedeman
      1972 Suburban
      Wiedo's
    12. #112
      ummm...lessee
      We were using TTY's and punch cards running basic and fortran, and computers filled air conditioned rooms the size of my house.
      We went to the 'computer center' with a pile of punch cards......
    13. #113
      Good luck on the GMAT. I took it in May. Eat breakfast before you go. Take your time. Take a s**t before you go. Take all of the breaks that are given to you.
    14. #114
      Subscribes. Any updates?
    15. #115
      New York, NY
      back home for Thanksgiving, will have some progress this week.
    16. #116
      Aug 2002
      may i suggest a solution for your distributor problem. i noticed you have a hei large cap style distributor. why not sell it and buy yourself a msd small cap pro billet distributor.
    17. #117
      Charlotte
      I just read the whole thread, I'm digging it alot.
      I kind of LOL'd when you discovered teh frame problem, but it looks like you got it resolved.
      As for the Gmat, thats a crappy test, trust me. But you'll get through it and eventually get through grad school as well.
      Good luck!
      -Craig-
      2014 Chevy SS LS3 / 4 Door
    18. #118
      New York, NY
      hooked up all the electrical to try to start it tomorrow.
      Cranked it over a few times with the starter and all of the sudden it won't turn over anymore. It definitely turned over more than one revolution (more like 5 seconds), so its not like a rod doesn't have clearance.
      Took out all the plugs, unhooked the serpentine, undid all the rockers. Motor still won't budge.
      Anyone have ideas before I take it apart tomorrow to check for a foreign object in one of the cylinders?
    19. #119
      Sep 2008
      If you have a transmission on there it may be the starter lokced out against the ring gear or some other forreign object wedged in the ring gear.
    20. #120
      Albemarle, NC
      ave you checked the onnections, attey, etc? if youre not gttingvoltage, it wont crank. try it right at the starter ith a fresh battery and some jumper cables, etc. hot wire the coil, etc. if is not internal, should crank.
      also, yure using a t56, right? mak sue that its not caught betwen gears. also check to make sure that your cutch is fully disengaging.
      michael
      Michael Crawford
