    Page 8 of 14 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
    Results 141 to 160 of 261
    1. #141
      Oct 2007
      Wa
      Good to see you are still going on this. Where are you getting your machining done at?
      Bob
    2. #142
      Dec 2003
      lost
      Jerome, I'm curious. You used the tall adjusters on the front, where are they set? Towards the lower side or the higher side? I am going to be running these on a project in the future and would like the end ride height about 2-3" lower than you are sitting now. Could you adjust out a few more inches from the tall adjusters?
    3. #143
      Sep 2007
      Edmonton, Alberta
      I'll pipe in on this. The adjuster only has about 2.5" of usable travel. The cup half of the adjuster can be cut to whatever length you like, and you can fine tune with the adjustable part. The best way to approach this is to mock up with the adjusters at their shortest. Find out how much you will need to cut off the cup. Then add 1" to the amount you cut off. Keep in mind that you will want to have the spring seat roughly in the middle of the thread when you are at the desired ride height. This will ensure that you have plenty adjustment either way for adjusting corner weights. It will take a few go arounds of mocking up, measuring and disassembling. Hope this helps some.
      Cheers
      Ryer
    4. #144
      Dec 2003
      lost
      Quote Originally Posted by bbcc View Post
      Cheers
      Ryer
      I'm pretty familiar with how the adjusters are used, hell I practically pioneered their use in PT cars. Each application is very specific as to whether the short or tall adjusters are better suited depending on desired ride height, which is why I asked Jeorme specificaly on his application.
      Not a noobie style question though thanks for chiming in.
    5. #145
      Sinned- were you the guy w/ the elCamino that was out by Lancaster? I was using your website as kind of a template for wghere I was going on my G body. Does the website still exist?
      Sorry for going OT, jerome
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
    6. #146
      Sep 2007
      Edmonton, Alberta
      Cool man. Ya, wasn't sure about your knowledge on the subject. Usualy safe to assume the guy is new.
      I have damn near the exact combination Jerome used. Without scaling the truck yet I have the adjusters at 1.25 from bottomed out. The truck is not at full weight on the front yet either.
    7. #147
      Dec 2003
      lost
      Web is down but I still have the site saved for future use. I will put it back up with my new project pretty soon. I'll post a link later.
    8. #148
      Thanks sinned
      Greg Fast
      1984 el Camino
    9. #149
      New York, NY
      Memphis-machining done at Cope Brothers in Parkland/Spanaway. It's in the industrial park w/ the line-x on the side of 512
      Sinned, I think in the pictures, there's roughly 1" left in the cup (I cut of 2 or so inches off the cup). The adjusters are turned so that the ring is seated on the cup, meaning it is as low as it will go without cutting more.
      Full weight isnt on yet, so it will go lower than in the pictures.
      Update on the status of the project - I started a job in July on the East coast, so there won't be substantial progress on the project within the next two years at least. It's a downer, but the project will get finished. I'll have a little bit of time at home during holidays, so there will be some progress, but not a ton.
      Jerome
    10. #150
      NC
      Very cool project. You have done a great job, looks insane.
      Congrats on the job to.
      Lookin forward to future updates
    11. #151
      Columbus, Ohio
      I love this project, keep up the great work!!!!! cannot wait until it is done!!!
    12. #152
      NC
      Any updates?
      Happy Holidays
    13. #153
      New York, NY
      Having lived in NYC for the last 4 years with no access to a garage and with the project at home in WA, I have decided to bite the bullet and hire professionals finish the project. Randy Parker (Parker's Race Shoppe) in Puyallup, WA will be doing most of the work. He builds tube frame dragsters for a living, so I am sure he will do a great job with the remaining chassis fab and fix some of my lesser quality work.
      A preview of the next few weeks:
      Front suspension:
      front coilover conversion
      Lee 670 steering box
      sway bar
      Chassis:
      new mid-chassis bracing
      new fuel tank mount
      new battery mount
      6 point roll bar
      Rear suspension:
      splined sway bar
    14. #154
      Looking forward to more details on this build. Move out of NYC...LOL
    15. #155
      Chicago
      That is awesome news I am looking forward to seeing this truck complete.
      marty-mj
    16. #156
      New York, NY
      Getting started - sitting at ride height:
      Randy connected the section that I had boxed to the factory boxed area
      Next steps:
      Rear suspension will be moved backwards to correct the unintentional shortening of the wheelbase that I had done
      Re-do of gas tank mount
      Re-do of transmission crossmember
    17. #157
      Chicago
      and the progress begins
      marty-mj
    18. #158
      Sep 2007
      Buford, GA
      Tell them to swap to an Explorer Rack and Pinion while they're at it. Check out this thread...
      http://www.blazinlow.com/forum/showt...nd-pinion-pic-!
      Here are some of the pics for that thread...
      http://s-seriesforum.com/gallery/Rack-Pinion
      Adam
      1985 S10 - LT1 + T56
    19. #159
      New York, NY
      Adam - thanks for the suggestion, but a Lee 670 steering box is already on the way. I figure a good recirculating ball setup is proven and can give just as good feel and performance as a rack and pinion without some of the R&D involved with getting the rack setup right.
      Randy made a jig to locate the upper control arm mounts, cut the spring pocket off of the frame and welded the frame rail up straight, factory-style. He then added a new upper control arm mount:
      Pockets were CNC-machined into the plates to accept oval offset inserts to adjust the pickup points for anti-dive:
      Unfinished Spohn lower control arm where lower coilover bracket will be mounted. Upper coilover mount has not been designed yet. Lower mount will be as close to the lower ball joint as possible and upper mount will locate the coilover as vertical as possible.
      I brought the cab and bed to the shop:
      We put the bed and body on to locate where the rearend should be. I had mistakenly shortened the wheelbase when doing the rear suspension the first time, so we will move the suspension rearwards to center the wheels in the wheel arches.
      A shot of the interior:
    20. #160
      NC
      Its about time you updated this, hah.
      Amazing work, everything looks great.
