    Page 19 of 30 FirstFirst ... 9 14 15 16 17 18 19 20 21 22 23 24 29 ... LastLast
    Results 361 to 380 of 585
    1. #361
      Oct 2009
      Reno, NV.
      Here's an updated pic of my GP, still needs buffing:
      Joe M
      '67 Firebird
      My build thread: https://www.pro-touring.com/showthre...irth&highlight=
    2. #362
      Nov 2007
      Oro Valley, AZ
      Quote Originally Posted by Samckitt View Post
      I am curious to know I'd they are narrowing the rear frame rails, what rear width tires will fit, what front suspension are they using, raer seat still usable? Are they going to sell this frame, how much?
      I was wondering about the rear seat myself with the 3-link. They did some test fitting yesterday/today it looks like.
      I also had asked about the rear tire, the reply was 335s, the fronts he would have to check on.
      -Darren-
      '78, '81 Malibu, '92 Sierra
      Quote Originally Posted by joemac View Post
      ...not only am I talking to myself as I'm going down the road I'm starting to answer myself and laugh at my own jokes-out loud...
    3. #363
      x2!
      1985 Monte Carlo SS- 224/228 cammed 5.3/4L80E/17x9.5 Budnik Tiller 5s/BFG Comp T/As
      2007 2500HD Silverado CCSB Duramax- 18" KMC HOSS, 285s
      2006 Corvette Coupe- Black/LS2/M6/3LT/Corsa/Callaway MP112/Nitto Invos SOLD
      2002 Sierra Denali Quadrateer-
      SOLD
    4. #364
      San Antonio, TX
      I would be real interested in seeing how the packaging turns out for the rear-seat area.
      I conclude that tubbing is soon to follow, possibly some trimming to clear the UCA.
      About the front end: I hope they offer a set of wheel wells. That would
      allow fatter tires, and to run much lower than the stock plastic wells.
      Dave
    5. #365
      San Antonio, TX
      Another tasty update:
      Dave
    6. #366
      Nov 2007
      Oro Valley, AZ
      Indeed... I always get a mental woody when I see they've added pictures to the album on Facebook :D
      -Darren-
    7. #367
      Nov 2009
      Colorado
      I'm glad it's a Grand Prix! These cars seem to be overlooked often....Can't wait to see the finished project!
      Ernesto M.
    8. #368
      Nice Rack!!!
      SOLD
    9. #369
      Fife, WA
      The chassis is designed to fit 335's, as this was the tire spec'd by Holley. Because this is a track-day car, they weren't really concerned about the rear seat, but if some of the center seat springs are trimmed, the rear seat should be able to fit back down. However, you probably wouldn't want to be riding in the middle and hit a bump. This car is also getting a full cage, so accessability to the rear seat will be difficult.
      The chassis originally was a one-off reverse-engineering job for Holley. To be honest, I've been pretty blown away by the response that this chassis is getting on our FB site as well as on the forums.
      It is definitely something we can do again, but pricing hasn't been discussed for another chassis. Also, the spec on this chassis was pretty high - remote reservoir Penske's, splined sway bars, 3-link, Woodward rack + reverse engineering and design time.
      Now that we have the specs, I'm pretty confident that we could offer this chassis with either 3-link or tri 4-bar in the back and a few IFS designs up front. The tri 4-bar would definitely minimize sheetmetal removal in the back seat area as well.
    10. #370
      Fife, WA
      Quote Originally Posted by mc84_zz4 View Post
      All of these questions will be addressed when it leaves our shop and heads down to Bobby Walden's shop in So Cal. He's finishing the car (or at least doing the sheetmetal work) for Holley.
    11. #371
      Fife, WA
      One thing to also remember -as per Holley's rendering, the wheelbase has been altered by 3 1/4" inches. They are moving the front wheels forward by this amount in the front fenders. IMO this makes the car look a lot better, and eliminates a lot of the front overhang on the nose. This wheelbase change is also going to do wonders on weight distribution. With a LS engine in place, the firewall is untouched and #1 cylinder is even with CL of the spindle. There is plenty of room to move the engine back so #1 plug or even the front of the engine could be made even with spindle CL. This wheelbase change also has done wonders for making room for the R&P and steering linkage.
    12. #372
      Dunwoody, GA
      So glad to see a GP getting some attention. I still have plans to build my own one day.
      Craig, would the wheel base changes be needed to package the rack and pinion and really make a product that is worthy of the AME name or could you build a great frame that would fit under the factory sheet metal and appeal to more Gbody owners?
      Trey
      ~ Jon Hammond
    13. #373
      Fife, WA
      Good Question! Rack placement is the biggest issue. If we were to use the suspension the we designed for the A body, maybe.
    14. #374
      Gainesville, GA
      Yo! Yo!
      79 El Camino (ELDOGG)
      Eric Evans
    15. #375
      Jul 2010
      It's an 87 GN T-top, and is stock with a few minor bolt ons that are barely noticeable to the naked eye, including the audio system.
      These cars are capable of major power, even using the stock motor, my valve covers have never been off even. Here's what the performance mods include, which with a turbo car unlock it's power potential because its all about timing and boost.
      For getting air into he car:
      * bigmouth style cold air intake with KN filter outside he engine compartment in ambient air.
      * 25psi boost controll solenoid.
      * Power plate spacer that helps the increased airflow and stops the back pistons from running lean.
      For the ignition:
      * Chip burned to increase timing and work with methanol
      * injectors calibrated for increased flow
      * high output fuel pump
      * fuel pressure regulator
      * Methanol injection system, the factory coolant reservoir has been moved to behind the bumper and a new stock OEM one is used. (you can see he braided stainless steel line going up on he left side of he intake, that's for the methanol)
      For the exhaust, the blow part:
      * 3" down-pipe from he outlet side of he turbo
      * high-flow cat convertor
      * aluminized steel tubing with flowmaster mufflers
      The reason you use methanol is for cooler engine operating temps and safety.
      I could not run 25psi of boost (almost tire pressure) and then compress it in he motor w/out worrying about pre-ignition or detonation, which can blow the motor apart.
      The computer uses the MAP sensor to turn the spray on progressively a 10psi, so when I'm putting around, just using vacuum and not turbo pressure, I not only get excellent MPG but I don't use the alcohol at all.
      It's probably a high 11 second car on a track with sticky tires, like it sits now, low 12's should be easy... which blows the doors of most sports cars on the road today, here's a Dodge viper getting whipped by not one, but two GN's simultaneously.
      http://www.youtube.com/watch?v=wlvo8J7ZBds
      ---- as for the stereo --- that's even more difficult to explain but I'll make it brief.
      I've added a few things:
      1. 91 GMC CD player (since GN's only came with cassette players)
      2. 1/3rd octave trunk mounted EQ that allows me to tune he car digitally and control an iPod.
      3. 600watt alpine amp under the front passenger seat.
      4. pair of Focal high end neodymium mid-bass drivers in the doors in custom vinyl enclosures to look exactly like the factory concert sound speaker pods.
      5. Image Dynamics waveguides under the dash for mid-treble that puts the sound stage up on top of the dash and separates the stereo image equally across the car.
      6. the sub-woofer, is a vintage Polk audio C4, with 4 6x9' sub-woofers in a push-pull compound isobaric 3 chamber bandpass enclosure, it is very small and looks good in the trunk and only weighs 28 lbs but has the output of a pair of 12" sub-woofers. http://www.polkaudio.com/forums/showthread.php?t=107642
      Pics of the install here:
      http://www.diymobileaudio.com/forum/...l-install.html
      Bringing a sleeper 87 turbo Buick to life; the original murdered out pro-touring car!
    16. #376
      Aug 2010
      MIAMI ALL DAY!
      haven't posted on the site in a while but just want to update on my g-body.
      My Cutlass is now powered by a 430hp 355sbc with a lame little t-5 ... which i haven't decided if I'm going to rebuild it with a g-force kit or just go with a t-56...
      I'm currently building a 383 that will be on boost for this car by then I'll most likely have my mind made up about the transmission..
      but for now i have a lot on work on my hands between body work and suspension...but this is how it sit now..
      color of the motor is somewhat the color i want to paint the car..
      painted the bay..
      still got a lot work ahead, but slowly getting there
      "I've done so much with so little for so long, that now I can do anything with nothing."
      84 Cutlass 420hp 355/t-5/3:73
      84 K-10 454/700r4/4:10 front and back 6" lift 35" tires
      96 Roadmaster LT-1/4L60E/3:73 Intake/Chip/Exhaust
    17. #377
      Port St. Lucie FL
      Hey we ran into something the other night on the malibu I working on.The poly body mount kit we got said factory washer with sleeve and we dont have any.Did some cars come equipped with these or is this a good upgrade?
      Kacy
      79 Corvette, 406 SBC, Holley EFI, 700R4
    18. #378
      Jul 2010
      Quote Originally Posted by DreamSpeedPerf. View Post
      That's going to be really cool, put a turbo on it! ;p
    19. #379
      Jan 2011
      CENTEX
      Alot of the MCSS.com guys know me.
      Im finally digging deeper into the performance side of the house. I was on here awhile back but didn't have the means to build a ride like I want, until now.
      J
      J. Will.
      70 Chevelle Malibu, 69 Cutlass S convertible, 71 Monte Carlo, 16 Chevy SS (yes, that one)
    20. #380
      Jun 2010
      pembroke pines fl
      im here
      85 buick t type
