    Page 2 of 32 FirstFirst 1 2 3 4 5 6 7 12 ... LastLast
    Results 21 to 40 of 631
    1. #21
      May 2010
      British Columbia
      Quote Originally Posted by Chev Korbin View Post
      Do you have any other pictures of how that valance fits, any straight on shots? how much trimming/ modifying did you actually have to do? Have you test fit the lenses yet,.. you should so we can all partake of the awesomeness, lol!
      I'll post some good pics when I take some , haha . I really didn't have to cut up the Shelby valance that much . It's pretty much a flat piece compared to the Cougar valance which curves around on the ends . Yes I've test fit the lenses and they look great , pics to follow .
    2. #22
      May 2010
      British Columbia
      Motor mounts version 3 are all fabricated and tacked into place
    3. #23
      May 2010
      British Columbia
      Here's the header that won't co-operate with the steering shaft . The green tape shows the path of the shaft , I ordered a couple of stainless U-J bends from Summit that should help get the job done , should be a challenge .
    4. #24
      May 2010
      British Columbia
      Since I've had my head in the engine bay trying to figure out how to modify this header , I've been thinking about the brake master cylinder / booster combo and which way I should go . I stumbled across this option , what are your thoughts ?
      http://www.fabquest.com/search-by-ca...-assembly.html
    5. #25
      Quote Originally Posted by langleylad View Post
      If you can fab the mounts, a dual mc manual setup will work great.
    6. #26
      Aug 2014
      Just out of curiosity what steering rack do you have in the car?
    7. #27
      May 2010
      British Columbia
      I have no problem with fabrication , on this project there's lots of it .
    8. #28
      May 2010
      British Columbia
      The rack was included in the TCI front suspension package
    9. #29
      Jul 2011
      The link below is the mounting plate that I grafted into my firewall for mounting the Wildwood setup. Obviously you can cut off the extra clutch hole and fab this piece in. The same Pedal setup for cheaper is in the link in that other thread you saw, and you can choose your master cylinder bore size during checkout while ordering online or just calling in the order might be easier.
      Here's the plate if you are interested:
      http://www.speedwaymotors.com/Pedal-...late,3351.html
    10. #30
      May 2010
      British Columbia
      Quote Originally Posted by LS7 Z/28 View Post
      Thanks man ! I'll check it out
    11. #31
      May 2010
      British Columbia
      10 days ago I ordered an Borgeson double u-joint from Jegs for the steering column . Hoping that it might help fix my problem . FedEx delivered it today ............ correct part ordered , wrong part sent !
    12. #32
      May 2010
      British Columbia
      Well Summit sent me the correct u-joint but it turns out that I don't need it after all , it's only money . I did manage to finish modifying the driver side header to clear the steering shaft. I ordered a couple of stainless j-bends from Summit. I learned a lot along the way , like back-gasing when tig welding stainless. Here's how it turned out , it looks like the lower pipe goes everywhere in the picture but it looks a lot better in your hands.
    13. #33
      May 2010
      British Columbia
Size:  115.6 KBName:  IMG_0382_zpsedgyyxyf.jpg
Size:  106.8 KBName:  IMG_0385_zpsraalvitp.jpg
      It's been a while since I've updated here. I've modified ( smoothed ) the firewall for the second time , I wasn't really happy with the looks of the first attempt. I've also finished with the rear valance mods , very happy with the outcome.
    14. #34
      Aug 2014
      Glad to see the update. Man, that looks awesome! I humbly request a teaser pic with taillights installed!
    15. #35
      May 2010
      British Columbia
Size:  119.6 KBName:  IMG_0387_zps1cajipd5.jpg
Size:  112.0 KBName:  IMG_0386_zpsx5lep4xp.jpg
      Here you go Chev , that's a ridetech fuel door . That bumper still needs to be tweaked ( a lot ).
    16. #36
      May 2010
      British Columbia
      I spent the afternoon installing a Electric-life power trunk release kit and aligning the trunk lid . The trunk lid seems to be a bit high in the centre , so some time with a BFH and 12" 2x4 was in order . Fits better now .
    17. #37
      Aug 2014
      That looks f@%#ing awesome!! Thanks for the pictures, the suspense was killing me hehe. Can't wait to see more!
    18. #38
      May 2010
      British Columbia
      Thanks Chev .
      I thought that I would close up the gap between the trunk lid and the filler panel , much better now.
    19. #39
      Dec 2007
      Lombard, IL
      nice work
      Dan
      1971 Chevelle Maliboo Convertible 496/4L80E
      1956 210 2 door Sedan 8-71 blown 468/T400
    20. #40
      May 2010
      British Columbia
      Thanks Zanie ,
      I've moved from the back to the front . I've shaved the cowl and continued smoothing out the firewall .
