    Page 23 of 80 FirstFirst ... 13 18 19 20 21 22 23 24 25 26 27 28 33 73 ... LastLast
    Results 441 to 460 of 1589
    1. #441
      Sep 2011
      This thread is amazing! I always look forward to your new posts.
    2. #442
      Nice touch.
    3. #443
      Pittsboro, NC
      Awesome fab work Pat. What grinding tool/discs are you using to clean up the welds, etc. I assume for the small inside frame areas you are using a dremel, dynafile or something similar?
    4. #444
      Apr 2014
      Quote Originally Posted by apstewart View Post
      Thank you sir, I look forward to working on it ;-)
      Pat
    5. #445
      Apr 2014
      Nice touch.
      Thanks Wayne.
      Pat
    6. #446
      Apr 2014
      Quote Originally Posted by JayBird View Post
      I use whatever I can fit into the spot, you named a few and there are other special tools that I have. I'll post some pictures next time I'm doing some grinding work
      Thank you
      Pat
    7. #447
      Jun 2014
      I think what I love most about this build is how well thought out it is. Its not a wild build but it has just as many custom touches. everything has a reason for why it is the way it is and there is now doubt that in the end it will just work. Will you be doing the body work yourself as well or will you be farming it out?
    8. #448
      Jul 2013
      Pat you are a detail mad man and we all love it!
      T
    9. #449
      Apr 2014
      Quote Originally Posted by jetsetw31 View Post
      T
      Thank you!!
    10. #450
      Apr 2014
      Quote Originally Posted by 2ndroundko View Post
      Yes I will do the body and paint, and I'm so looking forward to that stage of this build!
      Thank you
      Pat
    11. #451
      Apr 2014
      I had a small section of the driver’s side floor with pin holes that needed to be replaced. I cut about 18” from a new left side floor pan and grafted it along the cross member so it would be hard to tell if it was repaired. Some high-build primer should make any imperfections disappear.
    12. #452
      Nice job when it's painted you won't even know it's been changed.
    13. #453
      Oct 2015
      "Some high-build primer should make any imperfections disappear". As if there would be any imperfections. Great work, as always Pat. You're an inspiration to us all.
    14. #454
      Apr 2014
      Quote Originally Posted by windows View Post
      Thanks, but there is a lot of inspiration on this site!!
      Pat
      - - - Updated - - -
      Pat
    15. #455
      Sep 2013
      sw Kansas
      As you have moved around the body, I'm reminded of the good and the bad of the 60's production methods. You certainly have removed alot of the bad. I'm also mindful that you started with a pretty good car.
    16. #456
      Apr 2014
      Starting with a good car saves a lot of time. It will cost more up front but it saves you $$ in the end!
      Pat
      - - - Updated - - -
      Pat
    17. #457
      Oct 2015
      Quote Originally Posted by keepat View Post
      Pat
      - - - Updated - - -
      Pat
      When did you develope the stutter?
    18. #458
      Sep 2011
      I saw this on another forum earlier.. maybe some weird bug in vBulletin?
      Larry is working on resolving this issue.
    19. #459
      Apr 2014
      What stutter ;-)
      It's fixed!
    20. #460
      Apr 2014
      Fitted and welded the last torque box (left front) next up is welding the unused holes in the firewall.
      Pat
