    Page 27 of 80 FirstFirst ... 17 22 23 24 25 26 27 28 29 30 31 32 37 77 ... LastLast
    Results 521 to 540 of 1589
    1. #521
      Jan 2012
      Newton, KS
      The black paint on your charger looks stunning. I love watching your thread.
    2. #522
      Apr 2014
      I started on the roof of the car by using paint stripper to remove the vinyl top glue, paint, and primer. Then I used a 6” DA sander to remove any leftover glue and paint. As with most vinyl top I was left with some rust and pitting to treat and repair. I coated the roof with a gel rust dissolver and covered the roof with plastic to keep the gel from evaporating. After about 8 hours I removed the plastic and rust dissolver then neutralize the roof with water, and paint prep. One last sanding with 80 grit on the DA sander, a wipe down with Final Klean and 2 coats of epoxy primer. Next I’ll will skim-coat the roof, sand and more epoxy primer.
      Pat
    3. #523
      That came out nice Pat. A lot of area there, which rust remover did you use? I never tried the gel style it looks like it works well.
    4. #524
      Sep 2013
      sw Kansas
      Vinyl tops are not our friends! This means you're getting closer!
    5. #525
      Aug 2014
      Are you putting a vinyl top back on later?
      Jay
    6. #526
      Apr 2014
      Yes it worked great and it was from Eastwood.
      Thank you
      Pat
      - - - Updated - - -
      Still a long way to go!!
      Pat
    7. #527
      Apr 2014
      Quote Originally Posted by JayinMI View Post
      Jay
      Yes black vinyl top so it matches the original Bullitt Charger
      Thank you
      Pat
    8. #528
      Dec 2007
      Lombard, IL
      " I coated the roof with a gel rust dissolver and covered the roof with plastic to keep the gel from evaporating. "
      Was it Pink? I am such a fan of naval jelly. I do that all the time.....when tell people about it and they look at me like I'm crazy!! That stuff is such a time saver, when used correctly.
      Awesome work on every bit of this car...LOVE THIS BUILD!!!!
      Dan
      1971 Chevelle Maliboo Convertible 496/4L80E
      1956 210 2 door Sedan 8-71 blown 468/T400
    9. #529
      Apr 2014
      Quote Originally Posted by Zanie View Post
      Dan,
      No it was clear/blue in color and sold by Eastwood and it is a time saver!
      Thank you!
      Pat
    10. #530
      Apr 2014
      I used a Dremel with a wire brush to scuff the pits, and then block sanded the roof before skim coating it with body filler. Block sanded it again and sprayed a coat of high build primer. FUN! :-(
      Pat
    11. #531
      Nice! Plenty of work on a roof that big. It looks good Pat
    12. #532
      Sep 2013
      sw Kansas
      One more step! Is there good repo top material available?
    13. #533
      Apr 2014
      Thanks!
    14. #534
      Apr 2014
      Yes I have it and the headliner laid out on top of my 72 Trans Am to get the wrinkles out.
      Pat
    15. #535
      Sep 2013
      sw Kansas
      What's the trans am's story?
    16. #536
      Apr 2014
      It a numbers matching 455 HO TA that I restore 6 years ago. The link below will take you to the two+ year build.
      Pat
      http://www.78ta.com/HTAF/index.php?topic=6341.0
    17. #537
      It looks sweet!
    18. #538
      Texan Back in Texas!
      Following as I want to see this thing when it hits the road, awesome work so far.
      1965 Falcon Hardtop
    19. #539
      May 2012
      Pat thanks for the comments on the 71 Fastback. I had a 69 firebird rag before I built my 68 coupe Stang. I was 6 when my dad let me drive his 70 formula while he did gas and brake. I absolutely love your 72 and I'm blown away with what I see in the Chargers quality of build so far.
      Ang.
    20. #540
      Apr 2014
      Started to see a little surface rust starting on the hood and trunk that I had soda blasted over a year ago and never epoxy primer. So I pulled them out and power wash them with a solution of Hold Tight which neutralizes and cleans off the excess soda on the bare metal. Then I sanded the panels with 80 grit paper with the DA sander. Before priming the outside I sprayed inside of the frame work with rust encapsulator/frame coating.
      Pat
      Here you can see the left side in the picture is sanded and the right side is the virgin metal after powder coating.
      Using Eastwoods internal frame coating and rust encapsulator I was able to spray inside both the trunk and hood framework in a variety of different positions to coat all the internal surfaces.
