    Page 17 of 80 FirstFirst ... 7 12 13 14 15 16 17 18 19 20 21 22 27 67 ... LastLast
    Results 321 to 340 of 1589
    1. #321
      Apr 2014
      Left side inter fender covers are fitted and just need a few seams welded. Getting close to pulling the motor and mount the body on the rotisserie.
      Pat
    2. #322
      SF Bay Area
      Seems a shame to cover up such beautiful tube work. Is it for rock protection?
      chunger
      '68 Ranchero 500
      '70 Cougar XR-7 Convertible
      '98 Mustang GT Convertible
    3. #323
      Apr 2014
      Quote Originally Posted by chunger View Post
      Yes just to keep them protected and clean.
      Pat
    4. #324
      Nice work Pat, it looks really clean.
    5. #325
      Apr 2014
      Wayne,
      Thank You!
      Pat
    6. #326
      Sep 2013
      sw Kansas
      Pat, will you seal up the cover panels after they are installed for the last time?
    7. #327
      Jun 2015
      San Diego
      awesome wheels, i love the look. have you considered sending your tires to diamond back classics, they can ground a red stripe in the tires, they do an amazing job. here's a link to there website.
      http://www.dbtires.com
    8. #328
      Apr 2014
      The plan is to find a rubber strip that I could slide over the edge of the aluminum to seal it against the inner fender well. A small 1/4" rubber U channel would work best.
      Pat
    9. #329
      Apr 2014
      Quote Originally Posted by KB Camaro View Post
      I had seriously consider doing that to the tires early on, and probably would have if the Bullitt movie car had redline tires unfortunately it had white walls, and I just can't warm-up the thought of white walls on this car? Who knows I may change my mind?
      Thank you
      Pat
    10. #330
      Ca
      Quote Originally Posted by keepat View Post
      Pat
      Hey Pat it looks great. I love the look, very OE (if that is what you were going for). Anyway try a company called
      http://www.trimlok.com/cat/Trim-Seal...ories_101.aspx
      They have just about everything. Good product and easily obtainable in bulk.
    11. #331
      Apr 2014
      Quote Originally Posted by MichaelUser View Post
      Great link! a lot of cool seals and gaskets!
      THANK YOU!
      Pat
    12. #332
      Mar 2015
      Nice work! Will that effect tire clearance at all? I know mine rub at full lock on the frame and Im running 295's up front. Was rubbing with the 275's too.
    13. #333
      Apr 2014
      Quote Originally Posted by 72_Nova View Post
      No rubbing, the closes point is 2" away from the covers.
      Thank you!
      Pat
    14. #334
      Apr 2014
      I started the pluming for the brakes by making the mounts for the line locks and proportional valve to go under the master cylinder to help hide it. I need to make room in the inner fender for the front brake line and I’ll do this to keep the lines clear of the motor.
      Pat
    15. #335
      Jan 2009
      Chattanooga, TN
      Such clean work! So awesome!
      Stephen S.
      1967 Ford Mustang 4.7L, T5
    16. #336
      Beautiful job! No one will ever know its there. Nice!
    17. #337
      Apr 2014
      I had a few people ask how I measure and bend the stainless steel tubing, so I thought I would post a little more details on the radiator overflow line. I have bent thousands of feet of S/S tubing over the years. Every 55 Fleming yacht commissioned on the east coast I have bent about 80 foot of ½” and ¼” tubing, all by measurements and drawings. I sure there are many different ways to bend S/S tubing but what I have found that works best for me is outside to outside tubing measurements. This is easy when working with 90 degree bends. In the pictures below you’ll see marks on the tubing. One is an parallel orientation line, then a line designating the outside of the tubing after the bend, and the last mark is a U or C (depending on how you look at it) this designate the direction the bend should go.
      By using a 45 degree fitting in the neck of the radiator I was able to bend the tubing about 45 degree to start the line. With the first bend close to the flair its best to flare the line 1st as some flaring tools need more room then the bend will leave. You can see two marks in the 3rd picture, 1 marking the where the outside of the tubing will be and the other marking the direction of the bend.
      Here I’m using a scrap piece of tubing to mark where I will make the bend, I also measure for the next bend and mark the orientation for this change indirection.
      Here are the tools I used to bend and flare the S/S tubing
      Pat
    18. #338
      Jan 2014
      Austin, TX
      very impressive....I just bent up my first full brake system, and it wasn't even in full SS, so I have huge respect for your work...that being said, I learned a TON and look forward to refining the process. Keep up the good work... this is by far one of my favorite threads on the board!
    19. #339
      Aug 2015
      Madrid Iowa
      Wow that's a fantastic job. Your precision is admirable.
    20. #340
      Oct 2015
      Thank you very much for S/S tube bending 101 class. I will be doing mine soon and will follow your instruction to a "T". Thanks again Pat.
