    Results 1 to 4 of 4
      Aug 2006
      St. Pete, FL
      Getting Rid of Rear Hood Vents?
      Getting ready to paint my '69 GTO and I am pondering getting rid of the vents near the rear of the hood up by the windshield for a cleaner look. I saw that Foose did this on a '69 LeMans on Overhaulin'.
      My car is a factory A/C car and it lives in Florida so I don't want to compromise the functionality however if by switching the A/C to "MAX" closes a damper to the outside air and simply recirculates the cabin air I should be fine. Did they have this feature back in '69?
      I understand that the Firebirds after 1976 got rid of these vents as well.
      Anything else to be concerned about by doing this?
      Curt
      '69 GTO ragtop, 455 R/A, EFI, TKO600, Moser Trutrac 3:73, Speedtech, Hotchkis, Wilwood
      '64 Lemans ragtop, possible LS project
      '08 Pontiac G8, 546 rwhp
      Aug 2006
      St. Pete, FL
      No A/C experts here?
      Curt
      Harriman, Tennessee
      I have an Olds A-body, and it does not use the vents in the hood, bit instead simply breathes through the opening between the hood and windshield where the wipers park. Later 2nd gen F-bodies did the same, so there should be no problem with your closing off the vents in the hood assuming your Pontiac has the same set-up as my 442.
      Shiny Side Up!
      Bill
      "You can never go home again, Oatman...
      But I guess you can shop there."
      Aug 2006
      St. Pete, FL
      Thanks for the reply Bill. I think I'll smooth out the hood for a cleaner look then.
      Curt
