    Results 1 to 12 of 12
      CT
      changing a/c pulleys
      Hi guys,
      Im new to messing around with a/c compressors.
      Im looking at buying a new compressor from ebay but it has the wrong pulley. it has a v-groove and I need a serpentine for my LS1. I know this is a stupid question but, is it a pain to change the pulley?
      Im looking at getting a SD510.
      Thanks!
      Jacksonville, FL
      Between having to buy another clutch and just buying on with the serp pulley already on it, the cost might not be worth it (unless you are getting a smoking deal on the other compressor). Shop around, the clutches run up to $100.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      CT
      Thanks for the advice!
      If its going to cost me $100 for the pulley then your right.
      I can get the compressor for $100, which is very cheap.
      Jacksonville, FL
      Chris
      CT
      Thanks!!
      CT
      got it, thanks again for the heads up!
      Sep 2004
      San Antonio, TX
      That's an r-12 only compressor. It can be converted by changing out the oil. Be sure to change out the oil before using it w/ 134a. Also, it won't live quite as long on 134a as a newer compressor designed for it but still probably long enough. You still got a decent deal.
      The r-12 compressor can be identified by the service ports in the head. 134a 508 compressors do not have ports.
      CT
      i talked with him about that. He did some searching and gave me some information. In the end I bought it because it was a real good deal and wanted something to get my engine placement finalized.
      Dec 2009
      you might want to give the boys at Concept One a call. they are based in Georgia, but ship all over the world. i've had the pleasure of doing business with them in the past. they are awesome at what they do and know their pulley systems well. i'd be willing to be they can help you out.
      Concept One Pulley Systems
      keep us updated on your progress and what you find out.
      -RHoward
      CT
      Wow those pulleys look killer!!
      I ended up getting that sanden 508 but that site may have me making some changes.
      thanks
      Bill
      CT
      Oops... Just found the price list.
      I think Im going to stick with the stock serp. and fab. up a bracket.
      Dec 2009
      Bill--
      I have had the guys at Concept One send you an email directly. Let me know if you get it.
      RH
