    Results 1 to 20 of 31
    Thread: heater options
      Nov 2007
      heater options
      Hey Guys,
      I have shaved my firewall and looking to add a small heater/defroster only no a/c. Does anyone make a all electric? Ive seen the toy jc whitney ones. What do you custom guys use?
      Thanks.
      Jan 2002
      Crockett, Texas
      Vintage Air makes this "Compact heater with defrost"
      I used one on a 69 Camaro with smoothed firewall.
      It works pretty well.
      Don 67 Camaro RS/SS Texas
      Nov 2007
      Thanks for the picts Too!
      Feb 2007
      The Netherlands
      Country Flag: Netherlands
      I also shaved my firewall. don't want those heater hoses under my hood.
      Any 12volt options?
      Oct 2007
      Lubbock, TX
      Do you have any wider shots of that set up? I mean like from far away. I'm not picturing that in my head where everything is at.
      Thanks. =)
      Jan 2002
      Crockett, Texas
      It bolts to the inside of the firewall, just above the passenger's feet. (it's out of the way). It is secured by studs that could be concealed. The fasteners show on this one, but I'm re-doing the firewall over the winter.
      The -10 hoses were routed behind the fenderwell.
      Oct 2007
      Lubbock, TX
      Sorry for all the questions but why do the hoses go to intake manifold? One does right? Where is the other heading?
      Jan 2002
      Crockett, Texas
      This is a better angle, one is fuel.
      The hoses are in place of the usual bypass port for a big block, inlet to heater core, and a return to the water pump. I didn't use the usual heater port on the intake for a cleaner routing.
      The hoses go under the alternator, and then behind the fenderwell.
      I don't mind the questions.
      England
      I saw an electric 1 fitted in the trunk and trunking fed to the front.
      Oct 2007
      Lubbock, TX
      Thats insane! I didnt know that much work and lines went into the whole process. WOW. Looks like I have to do some homework before I order my kit.
      Thanks Don.
      Southern Indiana
      The problem with electric heat is it requires an enormous amount of amperage to make such a remote unit work efficiently or any electric heater for that matter.
      I have been looking at plate heating elements used in commercial applications.
      I havent recieved any of the literature yet but the ones I looked at run onaround 13.5 v DC and figured that a box modified to run several of these might serve our hot rodding purpose but havent got cataloges nor pricing yet,,, cold weather and a friends bad heater got me looking for alternative as his carpet got trashed as well as several hundred dollars of insulation and sound dampener.
      But if you simply want a heat/def a small core with a fan hidden under the dash with a couple of discretely installed lines would make a very unique system.
      The VA stuff also works but ids out of my price range usually.
      good luck and Ill keep the forums posted as my search progresses.
      Good Luck
      Lee Abel
      AFTERMARKET PERFORMANCE
      Nov 2001
      Sacramento Ca
      Any corvair that runs headers has no heat. Same for a vw. So we have been dealing with this problem for quite some time. The best solution at the time seems to be:
      something like this coupled with heated seats or seat covers.
      remember that watts divided by the voltage of your system = the amperage draw. So a 300 watt heater is roughly a 25 amps. The unit pictured is small enough to hide under a dash, and can be modded with ductwork to actually defrost your windows, but provides little heat unless you're going to be in the car for over 30 minutes.
      Im still tempted to wrap one of my headers with copper tubing and pump water through it, back to vintage air's setup. I bet I could figure something out.
      Tony Langlois
      1966 Corvair Monza
      Mountain View, CA
      Quote Originally Posted by ZZ430
      BINGO!
      Man I have been looking high & low for exactly that. I'd heard that VA made one, but I've yet to find a distributor that knew of it.
      You wouldn't happen to have a PN for it would you?
      True T.
      My blog
      Nov 2001
      Sacramento Ca
      here you go True
      And it's MUCH cheaper than I thought it would be. Now I really have to consider my copper tubing idea.
      Tony Langlois
      1966 Corvair Monza
      Mountain View, CA
      Holy smokes!
      I'm STOKED!
      True T.
      My blog
      Oct 2007
      Lubbock, TX
      wow thats cheap. Is there a link to the instructions?
      Nov 2001
      Sacramento Ca
      Tony Langlois
      1966 Corvair Monza
      Oct 2007
      Lubbock, TX
      Thanks Tony!!
      Jun 2006
      NW burbs IL
      I welded in a quick bracket to mount the VA heater and routed the hoses through the cowl vent area for a smooth firewall.
      Here is the bracket I welded in under the pass foot area to mount the unit without having bolts through the firewall.
      The hose exit and cover plate I made.
      And the clean firewall with all the lines hidden behind the fender
      Matt
      Mountain View, CA
      Very cool!
      True T.
      My blog
