Results 1 to 12 of 12
12-10-2005 #1
- Join Date
- Oct 2004
- Posts
- 186
How to connect AN lines to heatercore?
Well, I saw the pictures of Yodys car, and thought I would like to have AN lines to and from the heater core. But HOW would I connect them?
I'm building my own heaterbox for the blowermotor in Aluminum and would like to have welded bungs for AN-10 fittings on it. Another option would be to fit two bulkhead fittings in the box, but still, HOW would I connect them to the heatercore? I would like to have the original AC heatercore hose fittings cut down, so they don't stick out of the box like it would on an American Grafitti box. and then maybe put the AN fittings more over to the center of the car for easy access instead of far right as the original hose fittings are located.
Any Ideas?
/Dan from Sweden.
12-11-2005 #2
- Join Date
- Oct 2004
- Posts
- 186
anyone?
12-11-2005 #3You'll probably have to have weld bungs brazed on. Any welding done in proximity to existing brazed joints could melt the brazing and create a leak.
-Matt
Welders: The only people that think a co-worker catching on fire is funny.
12-11-2005 #4
- Join Date
- Oct 2004
- Posts
- 186
Thanks, I found a way I think. Im going to put 90deg elbows with hose between the heatercore and the elbow, then a hose from the elbow to a 90deg socketless AN 10 fitting, and then it goes on to a AN 10 Weldbung located more over to the center of the car. and then on the other side of the "lid" there is another weld bung, I did not want to use bulkhead connectors, I want it welded, its just soooo good looking :D
I think it will work
12-11-2005 #5If I'm understanding this correctly, your heater core will be enclosed in a box, correct? The only thing I see that will need attention with all those fittings hidden in a box is that you have big drain holes in the bottom, so if any of those fittings/hoses springs a leak, it will be obvious, instead of partially filling up the box before it leaks out. Otherwise, I think your solution would be the most simple.
-Matt
12-11-2005 #6
- Join Date
- Oct 2004
- Posts
- 186
No I'm building my own box for the blowermotor, the heatercore will still be inside the firewall, but I will cut the top tube of the heatercore, and both tubes will be rerouted via 90deg elbows to the weld bungs further off to the center.
The box will have a lid for easy access to the fittings and such. Also I will make a hole in the box at its lowest level so if it springs a leak it will flow out instead of in to the hole where the heatercore is located.
12-11-2005 #7Sounds good to me.
-Matt
03-14-2006 #8
- Join Date
- Sep 2005
- Posts
- 138
Any new info on this. I am also wanting to add AN fittings to the heater core, but can't find any that will work. I am leary of brazing them on, but there is a local shop that could do it if I can't find anything better.
I know Russell makes hard tube adapters for smaller diameter, but nothing I am aware of for 5/8" or 3/4".Jeff
1970 Corvette
LS1 & T56
C5 Z06 Brakes
03-15-2006 #9
