Results 1 to 13 of 13
Thread: A/C theory question
08-26-2007 #1
A/C theory question
I was told by a guy that sells and installs aftermarket A/C systems that it's a good idea to run the high pressure line (from the compressor to the evaporator) and the return line (from the evaporator to the condenser) next to each other and even to wrap them together with some kind of insulation.
The idea actually is to warm up the freon going into the evaporator and to cool down the now vaporized freon going to the condenser.
I know that offhand that sounds like a bad idea: You would be warming the freon that is supposed to cool the interior.
However, I think it is supposed to help keep the temperature from varying as much.
I don't know if it increases efficiency or not. Can anyone tell me if the compressor hase to work just as hard to condense cool freon as it does for warm freon?
Is it possible that this makes for a more efficient system?
I'm thinking that the compressor will have to run more, but might take up less power.
Does anyone know what this would actually accomplish?
