    Results 1 to 9 of 9
      New Jersey
      Want a smooth firewall but need heat and defrost, Options?
      I want to smooth the firewall, but also need to have heat and defrost, no ac, what are my options? What have you guys done?
      Pics would be great!
      Camaro Convertible Build Pics - http://s447.photobucket.com/albums/qq198/rob07002/
      www.musclerides.com
      Rob Stevens
      Sep 2004
      Southern NJ
      I know you don't want AC, but I was able to run heat, AC, and defrost with a smooth firewall. I used a Vintage AC unit under the dash, and I ran a 4-way bulkhead fitting on a fabbed plate, which bolted inside the fender where the fan used to go (non-ac car). I then cut a hole above the factory fresh air vent in the kickpanel to allow the 4 lines to attach to the Vintage AC unit under the dash. Both the AC and coolant lines to the heater run between the fender and inner fender for a relatively stealth install.
      You could do the same and skip the rest of the AC? Doesn't seem to be the most efficient route. Otherwise you could relocate the heater core inlets and outlets, but not sure what you'd do about a fan.
      Matt
      1965 Pontiac GTO – Spotts 421 Tripower | TKO600 | 3.90s | Vintage AC | Baers | Hotchkis/SPC/BMR Suspension | Intro Vistas | BFG KDW Redlines | 06 GTO Seats
      New Jersey
      Thanks for the reply Matt. Very descriptive. I figured I would have to use the vintage air setup. Damn! I see soo many cars with smoothe fw, and thought there was another way.
      I guess I'll stick with the old setup for now.
      www.musclerides.com
      Rob Stevens
      San Jose, CA
      Rob,
      That's a good question. The only possible way I can think of is to get a little portable heater like this:
      http://www.clevergear.com/website/st...arch_page_no=1
      I'm sure it's not as effective...but...
      Tony Huntimer
      RaceHome.com
      @Camaro.Family Camaros
      1986 #IROCdaily - Stock IROC
      Jan 2002
      Crockett, Texas
      Vintage Air makes a "Compact heater with defrost" It's very small and is mounted under the dash. I did this one on a 69 Camaro.
      Even though the studs show in this pic, it could be mounted with no holes showing.
      Don 67 Camaro RS/SS Texas
      Northern Indiana
      Perfect timing. I in the process of doing the same thing, and not quite sure on what to do but was considering the Vintage unit.
      "Champagne taste on a beer pocket book."
      Mountain View, CA
      Don, if'n ya don't mind me asking....what did that setup cost?
      That looks like exactly what I had in mind.
      Though I am still not 100% certain that I am going w/o AC.
      True T.
      My blog
      Jan 2002
      Crockett, Texas
      It's $200.
      It works well, it includes a 3-speed switch, vacuum/electric solenoids, and control valve.
      The door is vacuum controlled, default is defrost, and when floor heat is needed, a flapper opens on the bottom.
      The only complaint I have is the noise. Of course it would be a little noisy since the motor and fan are open, but it's not unbearable.
      And during the summer, it doesn't kill you with in-car heat because the control valve is closed.
      New Jersey
      Interesting, That looks like a great alternative to the complete vintage ac system...
      I'm going to have to look into that.
      www.musclerides.com
      Rob Stevens
