Results 1 to 9 of 9
Thread: VA Gen IV install in a 71 Nova
09-28-2008 #1
- Join Date
- Feb 2007
- Location
- USA, TN
- Posts
- 850
I've also posted this on StevesNovaSite, but I thought this would be useful members here too. Most of this will apply to first gen Camaros as well. It is long, but I tried to post as much detail as possible. I've got most of it in except for the vents. I'll update on those later. I would also like to thank Frank at Prodigy Customs for his advise.
I've split it up into multiple posts to get all the pics in.
I decided on the Vintage Air Gen IV perfect fit system for a 69 Camaro. I went this route because it is cheaper to buy the kits than it is to buy the individual parts. Frank at Prodigy Customs set me up with the complete kit. He ordered it with the right side compressor option to match my compressor location (69 Camaro’s have a left side mounted compressor).
I received the kit in two large boxes. Everything was packaged well and all the small parts were bagged, tagged and inventoried. The only thing that seemed out of place was a 5/16 washer lying loose in the box.
There were three instruction books for different parts of the system. One a scale of 1 to 10 (1 = more harm than good; 10 = an untrained idiot could follow it), I’d rate the evaporator instructions at 8, condenser instructions at 9 and the control switch at 10. These are some of the best instructions I’ve seen. The kit is sell documented and illustrated. I can’t stress enough to read the instructions start to finish before beginning the installation.
What have I bought complete the installation?
- ¼ * ½ inch long bolts, Black oxide finish to match fire wall, Qty 4
- 5/16 * ½ inch black oxide bolts, Qty 1
- ¼ * 1 inch bolts Black oxide finish, Qty 2 (Optional)
- ¼ in nuts, Qty 4 (optional)
- ½ inch tubing clamps, Qty 2 (Optional)
- 3/8 inch tubing clamp (Optional)
- 3M Strip Caulk
- -6 adapter for Pressure/safety switch fitting (source from VA)
Evaporator install:
I will only comment on observations where I deviated from the instructions or adjusted the fit. For the most part the evaporator installs as per the instructions. The supplied firewall block of plate is made of heavy gauge steel and has nuts pressed into it to make installation easy. However, I did have to trim off the lower right corner of it so I could use the existing firewall hole to pass wiring through. I also used strip caulk to seal it instead of silicone as recommend. I like strip caulk. Make sure you have box on hand.
The instructions have a template for drilling holes through the cowl. The 69 Camaro template is accurate for the 3rd gen Novas. I was surprised, but it was spot on. The kit gives #14 screws that protrude through the cowl near the wiper linkage. The instructions say to drill 3/16 holes, I drilled ¼ inch holes and use the ¼ by 1 inch bolts instead. I lined the bolt heads with strip caulk to seal them. The longer bolts give you a mounting point for wire harnesses or relays later. The AC bracket already has ¼ inch holes. Install the brackets to the evaporator and mount it in the car using the supplied firewall bolt and the ¼ * 1 inch bolts (or #14 screws) per the instructions
Template taped in place.
#14 screw protruding through.
Bolt with strip caulk
Evaporator installed
09-28-2008 #2
- Join Date
- Feb 2007
- Location
- USA, TN
- Posts
- 850
Control panel modifications:
The control panel mods were done per the instructions with two exceptions. I added a washer to the cold/hot slide pot mount to better align it. I also added a 3/8 inch tube clamp to hold the wires in place.
Getting started
Washer and tubing clamp install
New face plate
Condenser Install:
The condenser required the most modifications, but nothing difficult. The Camao condenser is larger than the Nova condenser, but it will fit almost per the instructions. The following deviations from the instructions
- Move drier up 4 inches
- Relocate lower brackets
- Fab upper bracket (original will work, but requires rebending.
- Make new -6 hard line from condenser to drier (Gave spec to VA and they made)
- Relocate pressure/safety switch.
The good news: the condenser, all but one bracket and all but one hard line work with little or no tweaking.
To mount the lower brackets use the holes per the pic below.
To mount the drier, use the supplied brackets and mount to the condenser per the instructions. Mount the drier to the drier bracket using the upper most mounting holes The will raise the drier up 4 inches from the Camaro location. See pic
Note: 73 and 74 Novas may have enough room to mount the drier in the Camaro location.
In the pick above, you will see I used the included -6 line from the drier to the fender well. I had to bend it a little by hand, but it works fine. The -8 hard lines from the condenser to the engine bay work without modifications. I got the -8 lines for both the left and right side compressor installation and they both fit fine.
I purchased a -6 t-fitting to mount the pressure/safety switch on the fender well (see pic for future location. Mounting it on the drier per the instructions will directly expose it to the weather, wind, bugs and other road debris.
09-28-2008 #3
- Join Date
- Feb 2007
- Location
- USA, TN
- Posts
- 850
Hoses:
Frank at Prodigy Customs requested the kit with the optional right compressor and VA sent the lines for both left and right hand compressor. I also ordered the Trinary switch and VA sent both the trinary and binary switch. Most of the hard lines shipped with the 69 Camaro kit fit the Nova.
The -8 line from the condenser to the compressor fit perfectly. I checked the line for the left hand compressor and it fit too.
The -6 line from the condenser to the drier was 4 inches short because I move the drier up 4 inches. I marked up the line sent with the kit and set it to VA to have a new one made. I also took a ½ inch out of the bottom of the line so it wouldn’t hit the filler panel.
I wrote all my instructions on the tape and included a note. VA got everything exactly as asked. There was no change for crimping the rubber hoses. They charge $85 (including shipping) for the new -6 line, the -6 T-fitting for the trinary switch and the AN adapters for the compressor (SD508 compressors don’t require them).
The -6 line from the drier to the fender well needed some rebending, but it was easy to do by hand and it fits fine. The -6 from the firewall to the fender well required no modifications. I put the T-fitting for the trinary switch in were these two lines meet.
Hard lines from the bottom: I will straighten up the condenser when I make the upper bracket.
Hard lines from the top
Trinary Switch: I added the weather pack connector
Rubber hoses (I have moved the fuel line)
Wiring:
Wiring is completely by the book. VA supplies a one-piece wiring harness and a couple of loose wires. One of the loose wires goes from the trinary/binary switch to the AC compressor and the other is the ground wire for the heater control valve.
Here is a good place for the two relays. Self tapping screws make installing the relays a breeze.
You could also mount them on the two long bolts holding the evaporator to the cowl, but I have other plans for those.
I also added a hose clamp to hold everything up under the dash. Be very careful with this screw. You can easily damage the evaporator if you hit something behind it. The other plug on the evaporator is for the control panel.
Glove Box:
I test fit the glove box and it fit like a glove. You will need to drill holes for the mounting screws.
09-29-2008 #4
Banned
- Join Date
- Aug 2003
- Location
- Orlando, FL
- Posts
- 8,745
Wow! Do you want a job? I need a tech writer. Outstanding work.
Thanks so much!
09-29-2008 #5
- Join Date
- Feb 2007
- Location
- USA, TN
- Posts
- 850
I'm always looking for extra cash (LOL). The car is draining my resources. It also takes all of my spare time.
Originally Posted by ProdigyCustoms
09-29-2008 #6
