    Page 41 of 48 FirstFirst ... 31 36 37 38 39 40 41 42 43 44 45 46 ... LastLast
    Results 801 to 820 of 949
    1. #801
      Chicago
      Why don’t you run the wires through the groove in the tank?
      The tanks are designed for only one wire (sending unit). You will see when you install your tank you can’t even move that wire meaning it is trapped between the tank and floor. Then add in the fact that my floor pan is Rhino-Lined. It just makes it worse.
      marty-mj
    2. #802
      Oct 2011
      I ran all my wires through the grooves without any issues. I’m able to freely move them back and forth. Maybe because I have a ricks restomod tank, the grooves are slightly deeper than stock?
    3. #803
      Chicago
      The top of the holley tank is depressions that line up with the ridges in the trunk floor and there was one spot that looked like it was doable but that was also a no go. I really think the Rhino line is the issue.
      marty-mj
    4. #804
      Can you sand down/smooth the roughness where the wires are going to run to keep them safe? Then tape them down with some kind of tape or even Eastwood mat you used. If your worried about the mat sticking to the wire you could leave the backing on in between to strips to stick it down.
      You could also space the tank down a quarter inch with something stuck to the tank right where the mounting straps go, it shouldn't make any difference in the mounting.
    5. #805
      Chicago
      All good ideas but I’ve committed to wrapping the wires around the tank. Plus if there is ever an issue I won’t have to lower the tank down to remove the wires.
      marty-mj
    6. #806
      Sep 2017
      Hi Jason,
      I so with you on the grommets as I have purchased at least 3 different kits and 5 or 6 small bag assortments and a bunch from McMaster Carr. My only regret is that I didn't place mine lower on the firewall as it would hidden from site but a bitch to get at.
      I just looked through your thread and your car is amazing and I love the grille. I think your harness going across the lower part of the firewall will look good if use a nice stainless steel line clamp and use a couple of the bolts from your closeout panel to hang it. I have some really nice ones that are rubber coated & anodized black that would blend in nicely. Once the motor and trans are in your not going to see much of the harness.
      Now that my engine is in and the ls Harness feeds it people can get a feel for my industrial look with harness and hoses.
      Your work even in wiring looks very classy and we'll planned out.
      Love your car it's bitchin
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    7. #807
      Sep 2017
      While I was at Good-Guys Columbus I ran into a gentleman that found an over the counter radiator hoses solution that may work in my car. I ordered them up to see how close they would be on my car and they look pretty good.
      Attachment 194043
      Attachment 194044
      The lower looks good but it will need a swivel neck for it to work correctly.
      Attachment 194045
      Marty
      I think those radiator hoses do go pretty good. You got alot more clearance than I do. My ac compressor to fan shroud is only 2.75 and my water pump and other vicinity pulleys about 3.5. I'm running a c and r radiator, had the high profile fans but had to order mediums. I just test fit and it's tight but I'll have about an inch between fans and the tightest pulleys. I sety dingo sliders and Speedtech engine stands back as far as both would go. I should have re fabbed them like everything else but I'm tired of redo and hard charging forward.
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    8. #808
      Chicago
      Thank You Jason I appreciate the kind words.
      Marty
      Jason
      I ordered a swivel lower water pump neck and it looks like it will really help with the alignment of the lower hose. I am hoping to have the radiator back in this weekend and hoping it works as planned.
      marty-mj
    9. #809
      Chicago
      Fuel Pump Wiring Concept ( 09-23-21 )
      Time to run some wires
      I plan to install a weather pack connector in this location so if I have to remove the tank it will be easy to access.
      Back in the trunk to make sure the wires coming out of the tank are long enough.
      More parts ( 10-05-21 )
      Weld studs are installed I will clean up the excess once it dries or is it hardens.
      I had to make chipboard stands to keep the weld studs from sliding down. Most likely due to my generous amount of epoxy.
      Man to I make a bunch of notes. I am going to blame it on my Chemo Brain.
      marty-mj
    10. #810
      When are firing this thing up?
    11. #811
      Chicago
      My plan is to start the car up before I make the final "Wet" connection to the motor. So I ordered this little hose that ICT Billet offer so I can bypass the Vintage Air.
      Not sure why I took this picture but I like it.
      Tank is going back in and I am going to finalize the wiring to the fuel pump and sending unit. ( 10-09-21 )
      I stepped the shrink wrap so the grommet would stay in place.
      I also saved and labeled an extra grommet just in case I needed one later. Yes, I am building a service kit for the car that I will stow in the trunk.
      I also ran the wires around the tank.
      So it looks like I need to add one more Weld Stud...Ugh !!!
      I finally received the fitting I need to connect the Fuel Pressure Sensor to the Fuel Rail. I am sorry I don't really like it as it has to many points that could leak.
      marty-mj
    12. #812
      Chicago
      That is a really good question.
      In theory I could probably fire it up this weekend however, my Gas Tank is at the body shop and wil most likely get painted sometime next week. Then I need to get the radiator and the throttle body painted. After that I should be ready to go.
      marty-mj
    13. #813
      Nov 2018
      Great work, but something seems to be missing, can't quite place my finger on it.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
    14. #814
      Chicago
      So true, being honest I just stuck it on to make sure it actually fits.
      marty-mj
    15. #815
      Nov 2018
      Heh heh, I've made that mistake before, the mistake being that I forgot to go back and clamp it. PSSSSSSSHT!
      2021 Durango R/T
      2005 Dakota beater
    16. #816
      Chicago
      Trust me I have made that mistake so many times.
      My last big one was draining my Hot Tub and when I went to blow out the lines (yes I turned the powere on) well lets just say I was soaked from head to toe and it was 36 degree's outside.
      marty-mj
    17. #817
      Florida
      Is the hose touching the UCA bushing washers? Would it if you add more shims?
    18. #818
      Chicago
      It’s just the picture angle. Thankfully there is plenty of clearance.
      marty-mj
    19. #819
      Florida
      Didn't think you'd let it rub, but due to the pic I figured I'd mention "just in case". Carry on!!! ahahaha A lot of us are watching even though we may not post in the thread often.
    20. #820
      Chicago
      Thank you and one of the reason I post and take so many pictures is just in case someone see's something I missed. So I am alway happy when someone post a comment asking me to look at something that might be an issue.
      marty-mj
