    Page 71 of 101 FirstFirst ... 21 61 66 67 68 69 70 71 72 73 74 75 76 81 ... LastLast
    Results 1,401 to 1,420 of 2014
    1. #1401
      san diego
      Trunk Release
      I also finished up my trunk release today.
      Here is the attachment to the fiberglass trunk:
      Here is the release mounted near my proportioning valve:
    2. #1402
      san diego
      My rear coilover shocks have started to squeek. Uggh. I am running spherical bearings on both ends so it must be the shaft seal.
    3. #1403
      Albemarle, NC
      ive had spherical bearings squeek before. shoot a little silicone lubein there and bounce the car a few times. if it goes away, you found the culprit.
      Michael Crawford
    4. #1404
      san diego
      Quote Originally Posted by dusterbd13 View Post
      I cleaned the sphericals and sprayed with penetrating lubricant. It is not the sphericals, unfortunately, also it has about 200 miles on them and squeeked at 20 miles of drive time.
    5. #1405
      Dec 2010
      Charlestown NH
      anybody can make parts and put them in, but taking the time to do everything right and as clean as you is something else. Looking great!
      https://www.pro-touring.com/showthre...-Touring-Truck
      DMP Fabrication LLC
      Follow me on Instagram for welding and truck progress! - Americangraffiti
    6. #1406
      Dec 2010
      I've got similar squeaking from my Panhard bar--it seems amplified a bit through the aluminum trunk block-off plate I've got (kind of like yours). If I just drive faster, I don't seem to notice anymore...
      Really, I haven't adjusted the bar since I first installed it (and adjusted for weight). I figure that since the bar's aluminum, something's changed shape a bit under the lateral loads I've applied over the last month or so; maybe one day, I'll get a heater in my garage, and working out there won't seem like such a bad idea...
    7. #1407
      san diego
      Quote Originally Posted by the dan View Post
      Thanks Dan, That means a lot coming from a fellow engineer that knows how to use tools!
    8. #1408
      san diego
      Quote Originally Posted by rustomatic View Post
      I hate working in a cold garage..... Do you have spherical bearings in your panhard?
    9. #1409
      Feb 2010
      Plainfield, IN
      A cold garage is one of the best places to work! Nothing worse than sweating all over your ride. Plus, I can wear my coveralls without over-heating. win-win.
      I think it was 40 something degrees in my garage last weekend.
      1969 1/2 Maverick
      4.6 DOHC, Mustang II front, T56, & Cobra IRS
      Custom Interior in the works.
      http://www.cardomain.com/ride/2200206
    10. #1410
      Roanoke (FortWorth) Texas
      That firewall looks pretty thin. I'm thinking about building one for my Mav since I already have the trunk apart for the fuel tank upgrade. What thickness material did you go with? How thin can I get away with to keep weight down. I'll likely fatmat it to help keep trunk noise to a minimum.
      Chris
      Total Cost Involved - Ridetech - Fatman - Total Control Products - Gateway Performance - MaverickMan Carbon
    11. #1411
      alpine ca
      Bryce get one of those propane heaters that mount on a 5 gallon tank heats up the garage nice and the wife will prolly come out more to get warm and spend time in the garage shoot the garage is warmer than the house on some nights ( oh ya youll have to put tha tv on her channel out there tho)
      john
      BUILD LINK
    12. #1412
      Dec 2010
      Spherical bearings, yes--the thing has heim joints at both ends. It's the standard Maier Racing adjustable Panhard for a '65 Mustang. Much like with a Watts link, the joints move constantly when you're going down the road, with every upward tick of the axle-mine is a pretty low frequency squeak, but it's a frequent low frequency. I meant to insulate my aluminum plate a while ago (block the noise), but then I found myself buying a house over the past couple of months. Oddly, applying mechanical neglect to the car now has resulted in more driving--my new street is a 10-mile squiggly line. Neglect is my wife's idea of car maintenance...
      Quote Originally Posted by Bryce View Post
    13. #1413
      san diego
      Quote Originally Posted by GrabberGT View Post
      Its .032" which is NHRA spec, .020" is you use steel. I dont care about noise, my car is too loud. No installation in my car....
    14. #1414
      san diego
      Quote Originally Posted by johnny68 View Post
      john
      HAHA, the garage is my man cave, the TV cannot be changed off of the SPEED chanel unless football is on. I like the idea of a heater maybe a NG heater, but its an excuse to go inside when its really cold....
    15. #1415
      Thanks. I'll add this to my shopping list for the Steel Yard.
      Chris
    16. #1416
      san diego
      Played with my flip camera and took some video driving around town. I mounted the camera to the driver side door handle.
    17. #1417
      Feb 2010
      ARIZONA
      Bryce:
      Your PM Message box is full! I am going to be getting a suspension analysys program and was wondering which one you have and how you like it. I just downloaded Suspension Analyzer by Performance Trends. Looks pretty good before I have actually done anything yet.The other one I was considering was SusProg3D.Thanks for any feedback.
      P.S. How is the little one doing?
      Larry
      67 Camaro, 350 SB, Custom A-Arms & 3-Link
      My Build https://www.pro-touring.com/showthre...LOVE-67-Camaro
    18. #1418
      san diego
      I autocrossed my falcon today! WooHoo.
      It was my first time on an autocross I ran a 77.569. I ran X but they said I was SM class.
      Corvettes were running 75-80 a 63 BP corvette ran a 69.xx a super modified sprite ran 64.xx.
      I will post up a video after I upload it.
      I had a blast, the car is driver limited, of course... I need a quicker ratio steering setup, that is my next big project. I was chasing the steering.....I think my tires rubbed a little. Brakes were great. The rear shocks seemed to get softer as teh warmed up. I think I need to something a little different with my oil pan baffleing. I think I was getting some slosh as my dad noticed that i was burning some oil after a hard turn. Motor was warming up in the staging lanes, so I an electric water pump to keep things circulating while the motor is shut off would be helpful. The automatic held up fine, I started in first and ran second the rest of the course. The trans temps were climbing at the end of my 3rd run I was seeing 200*F. I would like to keep that a little cooler. I really could have pushed the car harder. But that is a respectable time I think. The detroit locker was awesome. My tires were doing their job. The announcer said "that car is very flat through the turns for such a big car" He was talking about me, HAHA. I guess when you see miatas and S2000s all day my car is big.
    19. #1419
      san diego
      BTW, a big thanks goes out to my Dad and John (Johnny68), these guys did an excellent job as my pit crew! HAHA.
    20. #1420
      san diego
      SCCA autocross, the falcon can dodge cones.
      Skip to about 2:50, I cannot edit videos...Yet!
