Results 321 to 340 of 412
Thread: '66 Pontiac Resto-Mod Update
06-03-2010 #321
Hi Jim,
I've made some progress - slowly but surely. I'm swapping the PS Box (exisiting 800 box built by Power Steering Services) for a Lee 670 box. The 800 box is really brand new and is quick ratio but I'm looking for an even more sensitive feel. I'll be selling the 800 box. There is nothing wrong with it. I'll also be using all -6AN lines/fittings to rid myself of the old stuff. The reservoir was another issue. I wanted AN on both sides, and the "stock type" reservoir has a tube brazed on it for the return line (low pressure). To simplify I decided to use the March reservoir, which has an NPT threaded low pressure port. Quite possibly that will go on this weekend. The broken cap I've been able to retrieve and there were some plastic pieces in the reservoir, but apparently nowhere else.
I also installed a Lokar parking brake handle though I have not yet connected and installed the cables. May do that this weekend as well. I have planned out how they will be installed.
I dropped the car off Tues evening to have the convertible top installed on the frame. I'm also having the steering wheel wrap replaced with a dark burgundy/red rather than the black that's on there. The black just doesn't look quite right. Should have the car back before the weekend.
I am also having some slight tuning issues with the motor. It's not idling correctly, and low RPM performance is not where I want it. Fortunately, I chose to get a carb built by Jeff Esmel and he has been invaluable. It's possible that when I changed the intake gaskets I may have ended up with a small intake leak, so I need to check that this weekend.
Had the car out a bit this past weekend. Things are going well. All in all, the car is driving quite well and I'm very happy. Trying to get ready for Columbus!
