    Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 ... LastLast
    Results 21 to 40 of 145
    1. #21
      Jul 2009
      Cypress, TX
      That's good news! I appreciate the heads-up. I ordered a used pwm controller with the connector and wiring harness, but it hasn't arrived yet. So, I believe I won't need it, but we'll see what shows up via shipping.
      Quote Originally Posted by Samckitt View Post
      If you already have the fan(s) and don't want to buy the C6 vette unit, I have found a supplier for the PWM module connector & terminals that should be in my hands within a couple weeks.
      1969 Camaro - LSA motor, 6L90 transmission, TCI front subframe, TCI torque arm rear suspension, Ford 9" rearend
    2. #22
      Jul 2009
      Cypress, TX
      To insert the new pins/wires, first remove the grey faceplate from the connector. Gently pry up on the two short ends of the grey faceplate and it comes off easily.
      Using a small Phillips screwdriver, the small blue plugs can be easily pushed out and removed. Now insert the already crimped connector/wire into the now open hole until you feel it click in place
    3. #23
      Jul 2009
      Cypress, TX
      Controller and wiring harness showed up today. Almost ready for complete installation.
      The harness came with a radiator fan motor for a C6 Corvette that I don't need. Free to a good home (plus shipping). Contact me if you want it.
    4. #24
      Eastern Virginia
      After much searching I have finally located a supplier for the pwm module connector bodies & terminals. I should have these soon. I don't need them all, so i'll have some for sale.
      Scot
      86 Monte SS
    5. #25
      I'll take one please.
    6. #26
      Eastern Virginia
      I'll post when they get herre.
      Scot
      86 Monte SS
    7. #27
      Jul 2009
      Cypress, TX
      14 gauge wires were too large for the connector, but 18 gauge worked well.
    8. #28
      Mar 2011
      Quote Originally Posted by terrydmorgan View Post
      When you're wiring this all up, I'd go the extra mile and solder all of the 10 gauge power connections from the fan, to the pwm module and to the fuse/battery/alternator. Make sure all of your grounds are bullet proof too. I wouldn't skimp on the wire here and make sure it's good GXL 10 gauge.
      Heat is the achilles heal of those PWM units. If you can mount it to the frame in an area where it will get good air flow, all the better.
    9. #29
      Jul 2009
      Cypress, TX
      Thanks for the tips!
      Quote Originally Posted by entropyradiator View Post
    10. #30
      Jul 2009
      Cypress, TX
      Electronics are all wired and mounted. Now, just need to get the ECM reprogrammed for pwm operation. I'd like to find someone local here in the Houston/Cypress, TX area. Anybody know a shop that can do this type of work?
    11. #31
      Eastern Virginia
      Connector parts showed up the other day, the wire seals will show up tomorrow.
      Power terminals:
      pwm signal terminals:
      Connector body:
      I have 5 complete sets. When the seals get here I will also have ECM terminals. If you have the GMPP controller kit & want to add the Maxi fuse/breaker in the fuse box to power the fan, I can get the terminal for that fusebox as well.
      I spent a ton of time trying to find this connector. If you have searched it you know they aren't available from GM.
      When the seals get here I will have everything needed (except the wire) to add this fan module. $50 shipped to anywhere in the US.
      Scot
      86 Monte SS
    12. #32
      Jul 2009
      Cypress, TX
      I noticed quite a few complaints about failures of this connector on the Corvette websites. It's the supply line from the battery to the pwm controller.
      In the pics I saw, it looked like the connections weren't solid and had allowed some arcing of the contacts. I checked with Entropy and they told me to expect about 40 amps max for their dual fan arrangement. So, I found a heavy-duty looking connector that's designed for 50 amps (eBay for about $12.00). Not sure if there would have been a problem or not, but decided I was better off making the switch.
    13. #33
      If the culprit is the connection from the battery to the fan controller, how will you incorporate those new connectors?
    14. #34
      Jul 2009
      Cypress, TX
      Sorry Andrew, I'm not quite sure what you're asking. I'm replacing the factory connector with this high amp aftermarket connector.
    15. #35
      So not the connector that plugs into the fan controller, but the other connector. I think it's a metripack 800 that has the leads from the battery and the pwm signal wire.
    16. #36
      Jul 2009
      Cypress, TX
      Yes, exactly.
    17. #37
      Maybe I'll change that connector as well to a heavy duty Deutch connector. I really dig those.
    18. #38
      Feb 2009
      muggy midwest
      Those look like the Power and Signal power pole connectors I use-they are as robust as you can find-you won't have any issues with those!
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
    19. #39
      Jul 2009
      Cypress, TX
      Quote Originally Posted by H2Ogbodies View Post
      Good to hear!
    20. #40
      I realize that this thread is focused on how to make various OEM ECUs operate the coolant fans via pwm, but this functionality is also available in the Holley Dominator and HP ECUs. I am in the process of doing a LS swap into my 1967 Cougar and I am using the Dominator ECU.
      Last night I was able to configure the Dominator to control the fan via PWM using the C6 Corvette fan and fan controller.
      This will allow me to program the exact fan speed, based on duty cycle, based on coolant temperature and vehicle speed.
