    Page 8 of 8 FirstFirst ... 3 4 5 6 7 8
    Results 141 to 145 of 145
    1. #141
      Jun 2020
      Arkansas
      a 10K between Ign power and the pwm signal, correct? just to be sure
      Mike
      69 Camaro - In the Works
    2. #142
      Mountain Springs, Texas
      Quote Originally Posted by AEH View Post
      That is what I would try.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
    3. #143
      Jun 2020
      Arkansas
      No luck with the pull-up resistor. My cheap oscilloscope came in. If I’m doing it right there is no pwm signal coming from the ecm. It’s also a signal generator and I was able to hook it up and control the fans. Ramp them up and down. I’m thinking my ecm may now be the right vintage and may not be capable. It’s supposed to be from a 2009 ctsv. Any other ideas to try?
      Mike
    4. #144
      When you checked with the scope did you have the pull-up installed?
    5. #145
      Jun 2020
      Arkansas
      Yes, I tried it both ways, a bunch of ways actually. But I’m not sure if I had it hooked up correctly. The manual that came with it says nothing in 4 languages and I’m not familiar with the use. I was able to see some 500ish hz noise in the system. Form the battery charger I think.
      Mike
