    Page 4 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
    Results 61 to 80 of 160
    1. #61
      Aug 2010
      now In Dandridge, Tn.
      Wow! I know that this is a big tire, but it really doesn't look so huge under the car. Our static ride height is 5 1/2" at the front of the rocker, and 6" at the rear. Now, nothing hangs down below the bottom of the frame - or rocker, and this is pretty low for a streetable car. But, it doesn't look that low to me, and the tire doesn't look that big. I know it's hot out hear in the I.E., but, it is a 335/30/19, shouldn't it be bigger?
    2. #62
      Albemarle, NC
      oddly, it does look kinda tiny. we need a better overall shot of the mockup to tell, though.
      and 5.5-6 in? eh. my daily driven s10 had 3.75 at the lowest points.
      and yes, i drug stuff. a lot.
      Michael
      Michael Crawford
    3. #63
      Jun 2009
      You know funny thing about that, I thought that 275's looked huge out of the car, and now I think they look like bicycle tires, lol.
      Dan W
      1968 Plymouth Road Runner
      1962 Dodge Dart 440
    4. #64
      Oct 2006
      Colorado
      I'm building a 71 Challenger also. I've got the same 19" 335 Nitto tire with Fikse wheels on order and was worried that I went too large with the 19s on back. Not any more! I kept mocking up the 18/335 mock up tire I have and the wheel well on the Chally just swallowed it. That's why I went with the 19 also. I mini tubbed and worked the outer tub where it meets the quarter at a slant so the wheels would tuck also.
      Wes
    5. #65
      Aug 2011
      North Platte,NE
      Challengers have big hips! You should have 345s in there lol!
    6. #66
      Jul 2009
      Grand Rapids, MI
      Looks good! How are you tieing the rear frame rail into the rear crossmember? Any pics?
      Will Ellis
      Build Thread
    7. #67
      Aug 2010
      This is a shot of the finished lower bar mount. The rail is sleaved with 3/4" O.D. 7/16" I.D. tubes.
    8. #68
      Aug 2010
      The rear axle in place at ride height. The side plates hold the axle housing tacked in place at ride height and with the pinion angle set.
    9. #69
      Aug 2010
      These are the housing mounts for the lower bars and lower coil-over mounts. They are cut out on our water jet. 3 plates per side.
    10. #70
      Aug 2010
      Lower housing mount assembly. The bolted in spacers are cut on a lathe to spec as to fit the pivit balls and shock mounts. The tubing insert is 1 1/4 x .090
    11. #71
      Aug 2010
      Front side of the lower housing mount is for the lower bar. This uses the 'center' and 'inside' plates.
    12. #72
      Aug 2010
      Over all shot with the cross tube in place.
    13. #73
      Aug 2010
      View from the back side. The shock mount will fit into the lower stand out off the 'center' and 'outer' plates.
    14. #74
      Aug 2010
      HAHA, Yes, I will finish welding all of the tubes and mounts. At first, I weld all of the ara that will be really hard to get to once installed on the housing. Later, it will go back on the bench and be finished.
    15. #75
      Brisbane Australia
      Country Flag: Australia
      What's the advantages of the bar between the brackets other than rigidity?
    16. #76
      san diego
      SoCal
      I can't wait to see you guys bring this car out to AMP for its first shakedown. The work looks great, good job!
      Brett H.
      1979 Pontiac Firebird Trans Am
      1991 Mazda Miata
      2005 Ford Mustang GT
      1987 Ford Mustang GT - Sold 06-29-2014
      1988 Oldsmobile Cutlass Ciera - RIP 9-17-2011
      1992 Chevrolet Corvette - Sold 10-12-2017
    18. #78
      Jul 2010
      OREGON
      After seeing what you built on 67-72chevytrucks.com I cant wait to see this one done..
    19. #79
      Aug 2010
      Quote Originally Posted by linkstar69 View Post
      Well, rigidity for one, lol, it does make it easier to get the mounts perfectly in line. And, as a bonus, it's a nice place to tie down to, if, god forbid, it ever has to go on a trailer.
    20. #80
      Aug 2010
      Quote Originally Posted by 79-TA View Post
      Thanks Brett, are you going to The labor Day Cruise next weekend? Autocross?
