    Page 10 of 48 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 20 ... LastLast
    Results 181 to 200 of 954
    1. #181
      Woodbine, MD
      Put all new rear brakes on a lil while ago...and it actually made a big difference!
      I have a 8.5" rear i am building this winter that will have matching Baer brakes...
      All the hardware laid out on the work bench.
      New vs Old
      Douglas Lutes
      1988 Monte Carlo SS
    2. #182
      MD
      The drums go on the other way
    3. #183
      Charlotte
      Those backwards drums will stop on a dime!
      2014 Chevy SS LS3 / 4 Door
    4. #184
      Woodbine, MD
      **UPDATE**
      Santa was good to me this year and delivered ridetech coilovers for all four corners!! Stay tuned for a complete write up!!!
      Douglas Lutes
      1988 Monte Carlo SS
    5. #185
      The Netherlands
      Country Flag: Netherlands
      there seems to be a delay between your FB and PT.com updates..? Looks good Doug, lets see if there's a difference in the auto-X!
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
    6. #186
      Woodbine, MD
      I made these car stands today so I can have the car at ride height and work on the coil overs to get them adjusted just right!!. They are made of 2x4's and are 14"x14".
      I had to modify the base on the driver front one so it would fit with the lift plate there.
      Douglas Lutes
      1988 Monte Carlo SS
    7. #187
      Woodbine, MD
      Douglas Lutes
      1988 Monte Carlo SS
    8. #188
      Jun 2005
      Nice car.
      Anthony
      http://www.cardomain.com/ride/674663
      '71 Datsun 510, 2jz-gte (Supra TT) engine
      http://instagram.com/supra510
    9. #189
      Woodbine, MD
      Quote Originally Posted by Supra510 View Post
      Nice car.
      Thanks buddy!! I've had your car as a part of my screen saver for a while now!!
      Douglas Lutes
      1988 Monte Carlo SS
    10. #190
      Woodbine, MD
      **UPDATE** Having some small issues with the rear coil overs but I think the problems have been fixed. I will do a write up on those rear coil overs as soon as I am 100% done with the install.
      I'll tell you all one thing...ridetech makes some bangin' parts!!!
      Douglas Lutes
      1988 Monte Carlo SS
    11. #191
      Woodbine, MD
      So I am about to install my third brass prop valve from inline tube. Every one I have installed so far has leaked out of the front rubber boot that covers the valve. I called inline tube and they ADMITTED to me that 15/100 of these style prop valves fail and leak from that valve. Doesn't 15/100 seem a little bit high?? And they came right out and admitted it!
      Now I know that they do not manufacture these prop valves and apparentlly their supplier is the only company who makes these units.
      The one I have is a stock replacement, made of brass and has a 70/30 valving. They do make a solid brass one which has no front valve (leaking part!!) but that is rated at 50/50 valving.
      Currently looking for solutions....
      Douglas Lutes
      1988 Monte Carlo SS
    12. #192
      Feb 2011
      Oldenburg
      Country Flag: Germany
      Solution: use just a adjustable (Baer) prob valve, remove the brass prob valve an take a T-adapter.
      Give Rick from Bear a call, he will give you support.
    13. #193
      Woodbine, MD
      Well...still playing with the whole brake prop valve issue. In the mean time I have been doing some other small fix's to my car. I've been thinking alot about my oil filter recentlly so I decided to make a video comparing what I have been using.
      Douglas Lutes
      1988 Monte Carlo SS
    14. #194
      Woodbine, MD
      My rear ridetech coil overs are in and ride sooo nice!!!! I am still in the process of organizing all my photos and will have a write up soon.
      Douglas Lutes
      1988 Monte Carlo SS
    15. #195
      Woodbine, MD
      I almost forgot to put up what I was originally going to post about!!
      While working on my prop valve I noticed that something was leaking onto both of my front tires. It turned out to be my lower ball joints!! Have any of you heard of the grease liquefying in the lower ball joint? I did weld them in about a year ago and have since re-greased them with the Valvoline Syn grease that I have always used. Is there a way to drain these things??
      Douglas Lutes
      1988 Monte Carlo SS
    16. #196
      Feb 2010
      Central NJ
      My new BJ's and other grease fittings did seam to leak some liquid or sweat... i'm not positive but it may be the nature of synthetic greases??? I used Green Grease.... I just pumped in some more... i think the liquid was very minimal... try adding some grease and see how much is actually liquid...
      2 months until RTTS... get your crap together man!!! hahaha!
      -Sean
    17. #197
      Just North of NYC
      Can't help with the ball joints, but keep posting the updates. You've done a ton of work on your car and it should be a blast at RTTS2. See you there
    18. #198
      Woodbine, MD
      oh you want more do you??!!??!! lol
      I do have one more sneak peak I can throw in here....
      Douglas Lutes
      1988 Monte Carlo SS
    19. #199
      Woodbine, MD
      These are my new Kirkey Intermediate Road Race seats!!! I am getting them installed on Feb 20th and yes they come with covers!!
      And I'm gonna throw this in here b/c it's a bad a$$ pic!!!!
      Douglas Lutes
      1988 Monte Carlo SS
    20. #200
      Cartersville, GA
      Looking good!
      Joe Hinds
