    Page 4 of 23 FirstFirst 1 2 3 4 5 6 7 8 9 14 ... LastLast
    Results 61 to 80 of 454
    1. #61
      Jan 2010
      SLC. UT
      Put the IRS back on, and got all the bits installed.
      Checked the clearance for the wheel/tire. here's some pix.
      I like these wheels/tires!
      we're going to have to do something with the stock flair
      Jeff -- 96 Mustang - 2V Stroked Modular Turbo // 13 RAPTOR // 67 Mustang Fastback build - Coyote 5.0
    2. #62
      Oct 2009
      Copperas Cove, TX
      Thats an awesome way to mock things up. Looks good man.
      Andy McCatherine
      1982 Monte Carlo SS (clone)
    3. #63
      awesome Jeff!
      Apr 2007
      Huntsville, Tx
      Excellent!! The progress is amazing. I take this happened over a longer period of time and you're catching us up on the build.
      Sam
      69 Firebird convertible T/A pro-touring custom, Now LS1/T56 six speed, 3:42 Eaton posi, 18" Iforged wheels, 04 GTO interior.
      www.fquick.com/SamHatco
      Jack of all trades, master of none.
    5. #65
      Aug 2006
      looks great keep moving along ..can not wait to see it on the ground
    6. #66
      Nov 2007
      Dayton, Ohio
      That clears it up. Not the way I think I would have done it but it works and looks good. Good job!
      Roger
      69 Mustang coupe, under construction
      2011 Mustang - DD
      https://www.pro-touring.com/threads/...ang-SuperCoupe
      Freedom Of Speed!
    7. #67
      Jul 2008
      Seneca, SC
      Great project
      -Kyle Voss
    8. #68
      Jan 2010
      SLC. UT
      Thank you for the compliments everyone, I appreciate it.
      Quote Originally Posted by SamHatco View Post
      Sam
      Thank you.
      Yes, this is our progress for the last 6 months on the IRS. and few years before that on the rest.
      this next bit will catch this thread up to where we are.
    9. #69
      Jan 2010
      SLC. UT
      Here's a few more shots of the IRS
      Other side:
    10. #70
      Jan 2010
      SLC. UT
      Next we stated figuring out the seat mounts.
      Got these from a 97 Mustang, we will most likely be getting some nice after market seats,
      but these will work for setting the mounts etc.
      Cut out the stock risers and set them it to check the clearance of my head!
      Head clearance was a lil tight for a 6' 5" guy like me.
      Decided to lower the back and tip it a little.
      tipping it is actually much more comfortable for me to sit in. Daddy likes
      We set the front 1" above the floor, and the rear 3/8" below the stock floorpan lvl.
      They're welded hot into the sub fram rails, and welded solid to the floorpan.
      Here's the bottom:
      also chopped 1/2" out of the rear seat mounting bracket
    11. #71
      Jan 2010
      SLC. UT
      We got the seat rails done, and were looking at the trans crossmember.
      Measured out the headders, and the collector flange is right there, so we cut them down.
    12. #72
      Jan 2010
      SLC. UT
      And, here's what we did last week.
      Pressed longer studs into the rear hubs.
      Picked up a few needed bolts, and got the IRS all assembled with the exception of 2 that needed to be ordered from Ford...
      The axle shafts are 31 spline, and the Dif ring is 373.
    13. #73
      Jan 2010
      SLC. UT
      Here's how she sits now
    14. #74
      Feb 2006
      Awesome build! I love the choices on the parts and the fabwork!
      I just started watching this one ,but will continue!VERY NICE!
    15. #75
      Jul 2009
      Nice. Keep up the good work.
    16. #76
      Jan 2010
      SLC. UT
      Thank you both.
      So, this is our build to date.
      This is our first full build and I welcome any comments or suggestions from you builders here on pro-tourning.
      Our aim is to do as much of this ourselves that we can.
      Soon we'll be getting into the body/sheetmetal. I've done structural and thick sheetmetal work before, but havn't
      done much with thinner curvy metal, so that will be interesting.
      We will need to do something with the rear flares, either bring them out, or bring the whole rear quarter out.
      Also want to extend all the side panels down a few inches to give the car a taller/lower appearance.
      not sure what we want to do on the front.
      It will be interesting to see how it evolves.
    17. #77
      san diego
      awesome Jeff, just awesomness!
    18. #78
      Feb 2009
      Looks like we have been working on some of the same projects on our cars. I also have a 67 fastback with custom front end and am installing a IRS rear just doing it a little differently. Great work and keepus posted. Scott
    19. #79
      Charlotte
      That IRS install is bad ass! I love it!
      2014 Chevy SS LS3 / 4 Door
    20. #80
      Nice work it looks great.
