    Page 12 of 23 FirstFirst ... 2 7 8 9 10 11 12 13 14 15 16 17 22 ... LastLast
    Results 221 to 240 of 451
    Thread: TwinTorino
    1. #221
      Jan 2010
      SLC. UT
      Nice progress Craig!
      Jeff -- 96 Mustang - 2V Stroked Modular Turbo // 13 RAPTOR // 67 Mustang Fastback build - Coyote 5.0
    2. #222
      Sep 2009
      Looking good. When will you get a video of the cars running?
    3. #223
      May 2007
      Any updates on this project? Torinos look sooo much better than mustangs in my opinion. Just saw this on my local craigslist: http://omaha.craigslist.org/cto/1850326536.html
    4. #224
      Motorcity, Canada
      Been too long since I have posted. Made lots of progress on the car since last time. Firewall is complete, heater box now fits like a glove, A/C condenser and radiator are mounted as well. All the wiring is in the car and all the parts and pieces to make the engine run. Just need to get the brakes so we can actually go somewhere once we get it running.
      Car is very close to starting - just have to get past the PATS (passive anti theft system) on the car. All the parts and pieces came from different cars so the keys don't match the ones stored in the cluster etc. I just need to reflash the PCM and turn it off for now. The engine cranks over and everything else on the car works. The PATS system won't allow the injectors to fire because it thinks the car is being stolen. I expect we will have it running this coming week.
      Craig
      1968 Torino GT 4.6L S/C T56 IRS x2
      www.twintorino.com
    5. #225
      Motorcity, Canada
      Finally got the PATS thing figured out. Surprisingly enough, with that out of the way, car fired right up on the first crank. Needed a motivational point along the way. Too bad we don't have functioning brakes and a driveshaft.. otherwise we could go for a lap around the block.
      Open exhaust is music to my ears . Motor mounts are shot.. polyurethane ones will fix that.
      http://www.youtube.com/watch?v=YCKnn4SFFaI
      Craig
      www.twintorino.com
    6. #226
      sounds greeeeeaaat!!!!!!!!!
      TN
      Nice!
      Benjamin
      Twin Dusters
    8. #228
      Rustburg, Virginia
      Sweet music!
    9. #229
      Charlotte
      DAMNNNNNNNNNNNNNNNNNNNNNN!
      2014 Chevy SS LS3 / 4 Door
    10. #230
      Aug 2010
      Any new work on these cars. Great work so far.
    11. #231
      oshawa ontario
      Quote Originally Posted by SVTforme View Post
      I hate to buy anything new......
      you are such a Canadian......man I can relate!
      probably has something to do with the 13% sales tax we have to pay on new items....
      keep diggin' brawtha.....!
      89 Iroc 406 Fitech 5 spd
      31 Scarab 2 x 454
    12. #232
      Joys of Alberta no PST just the damn federal tax. Never has stopped me ffrom spending cash though.
    13. #233
      Motorcity, Canada
      Suppose it is about time to post some updates. Making some decent progress lately.
      Keeping in the theme of used parts.. picked up some more of them. Found a set of nearly new Energy Suspension 4.6L motor mounts and also a Wilwood proportioning valve. Had to buy the oil filter adater new though - the one from Ford Racing is a nice piece (M-6881-C). Planning on running a remote oil filter w/t-stat and also an oil cooler in front of the cooling module. This part also increase the block inlet hose to 2" to further reduce the possibility of water pump cavitation.
      We made up custom radiator and condensor mounts which allow us to get them both between the frame rails to keep them as low as possible. This way the degas bottle can be mounted where it was intended to go and remain the highest point in the cooling system, but at the same time being low enough to clear the hood which is does nicely. All these parts are from a 2004 Cobra which uses a 36mm all aluminum radiator. All other Mustangs except the Mach 1 have plastic end tanks. A/C compressor is now in and the new Mustang heater box also fits on the firewall. Just need to run the lines and the A/C system will be complete.
      The firewall has been completed and is ready to install along with the floor pans. Rear suspension is nearing completion and just needs to be final welded. The only thing missing in the pic is the upper coil spring retainer. ABS wiring is now in place. Last thing to do is run the hard lines which will come next.
      As an aside - I had never used the wet toilet paper trick to remove a pilot bearing so I figured I would give it a try. I am used to the messy grease trick. Surprisiningly this worked like a charm and clean-up is a breeze. You sure can fit a lot of paper in there! Installed a resurfaced 2004 Cobra aluminum flywheel, clutch, pressure plate, throwout bearing and clutch cable. Trans side of things is ready to go. Just need to get the mounts in.
      We put the car on the scales and put every part and piece we planned on putting on the car. Looks like the car will come in at around 3450lb curb weight (56%ft/44%rr). With driver and gear we are looking at around 3650lb track weight. We put the car in the air and measured all of the corner weights and using the motion ratios front and rear figured out what spring rates to use. We are using 2.5" ID front springs and 60mm rear springs from Hypercoil. The target is to run a front ride frequency of ~1.55Hz and 1.7Hz in the rear for the street. For the track the ride frequencies will be similar front to rear.
      Craig
      www.twintorino.com
    14. #234
      Dunwoody, GA
      Looking great Craig. This is one of my favorites to watch because you guys are so inventive and this is such a different build.
      Trey
      ~ Jon Hammond
    15. #235
      Rustburg, Virginia
      Sweet...thanks for the update...glad to see this project still moving along nicely.
    16. #236
      Motorcity, Canada
      Managed to get some things done over the past month or so. Floors are in the car and basically done and now ready to weld in. Decided to move back to the rear suspension and things back together for good. First step was to add 1.5" to the rear wheel wells to make them clear the tires, and then notch the frame out for the 2.75" shock mount tubes. Once the shocks were in, we were able to confirm the shock jounce and rebound travel and everything looks OK clearance wise. Wheel wells are now tacked into place and ready for final welding. Sure would be nice if someone out there made Torino sheet metal parts . Still lots of welding to do here, but getting much closer by the day.
      Craig
      www.twintorino.com
    17. #237
      Oct 2010
      Cincinnati
      OK, explain the toilet paper trick....I have used grease and a punch before and frankly didn't have a lot of luck with it.
    18. #238
      Motorcity, Canada
      Quote Originally Posted by U_SAY_GO View Post
      I had only used the grease method in the past, and although it worked - it was a pain to clean up in the end. I was somewhat skeptical with this technique but I figured I would give it a try. All you do it tear up pieces of toilet paper into small strips and soak them before packing them behind the bearing. Take a piece of steel or something along those lines that has an OD similar to the ID of the bearing and keep packing the pieces in until the bearing comes out. After that you just clean up the mess of paper and water which takes all but a minute.
      There are tons of videos on Youtube of the process.
      Craig
      www.twintorino.com
    19. #239
      Motorcity, Canada
      Finished tacking in the pass side wheel well and made up the shock mount for that side too. Everything is ready for final weld. Time to move back to something we have been putting off for a while now - spring mounts, spring sizing and locking in the ride height with all these parts which turned out to be easier said than done. As you can see - we ended up making a new upper spring mount to clean things up and transition it into the existing frame.
      Three main parts to the rear suspension travel - and each stage has it's own issues:
      Rebound/full droop position - this is with the wheel pushed all the way down. The car will rarely see this position, but is is possible and will always occur when lifting thcar in the air using a hoist. The first issue we ran into is that our springs are too stiff and the spring will just fall out of the car as is as they are all their free length at this position. Simple solution - just buy longer springs right? Unfortunately not that easy - if you get longer springs, the car will just sit that much higher. Since the motion ratio is approx 0.5, if you make the spring .5" longer, the car rides 1" higher. Solution here is to run Hypercoil helper springs. You can completely compress these springs by hand, but there is enough spring force to keep the main sping in place. They compress to a mere 0.3". The keep the lower spring in place on the lower mount - we opted to use a nylon part made by Vorshlag which some may recognise as a BMW parts supplier. To keep these in place, we just made up 1 3/8" posts as you can see in one of the final pics. We also used a similar sized spacer to keep the ride height adjuster in place. The other key point about this position is still being able to get the spring adjuster in position on the top post.
      Design position - this is the position the car naturally sits at full of fluids on the ground. To fine tune the ride height, we opted to use 60mm ride height adjusters made by AST - yet other BMW part. Based on the second picture - you can see that the helper springs are full compressed and the entire weight of the car is now in the springs. To get the car at the correct height was a combination of spring length selection (since the rate was fixed to achieve a certain ride frequency), helper spring height, coil spacer height, and ride height adjuster overall height. The goal was to have the height adjusters at their midpoint at design position (which they actually sit at although not shown in the picture).
      Jounce position - this is with the wheel pushed all the way up and riding on the jounce bumpers, which in this case are built into the shocks. Couple of issues you have to watch out for here - coil bind on the springs, control arm contact to the frame, and upper and lower spring seat misalignment. For the purpose of illustration, I stuck another spring on the car as compressing the other springs would require anchoring the car to the ground.
      With all this in place and all the issues worked out (for now), the rear suspension design is complete and just needs to be final welded in place. This will make the process much easier on car #2.
      Only thing left in the rear suspension area now are the brake line routing and getting all the ABS parts in place.
      Craig
      www.twintorino.com
    20. #240
      san diego
