Results 121 to 140 of 313
Thread: Project: SCHEVY 2001 Silverado
02-16-2009 #121
- Aug 2007
- Normal, IL
- 260
Caught your sig in another post, man, I really want a blacked out silverado now. Nice metal work, that truck is insane.
02-23-2009 #122Well I found a slight flex out back wanted to add another triangulated brace
Brand new, perfect condition bed...
Now all cut and section bed floor raised 5.5"
I didn't want to go more then 5.5" So to get the last >1" I'll section the bed crossmembers over the frame.
Cut the firewall and trans tunnel out to accommodate the motor, (body dropped 2", motor raised 1" and moved back 1.5"
Motor view, looks pretty far back without any accessories on it
Got my hubs from Moser Friday, should have my axles this coming Friday
5x5 lug pattern, 1/2"x120 screw in studs
Nick Schiffer
2001 Silverado
Currently Fabricating Full Tube Chassis
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
...back in the day
02-23-2009 #123
- Oct 2004
- St Louis, MO
- 373
Still WOW. Are those the MT's you plan on running? What size are they?
02-23-2009 #124yes, and 29x18xR20
Nick Schiffer
2001 Silverado
Special Thanks to:
...back in the day
02-23-2009 #125Jesus!!! I still cant believe that is the same truck that I was talking to you about awhile back..
02-23-2009 #126haha thanks man, always had a sweet spot for you sierra
Nick Schiffer
2001 Silverado
Special Thanks to:
...back in the day
02-23-2009 #127
- Mar 2006
- Lafayette
- 296
sick is all i can say!!!!!!!
Scott
Built LTX, TKO600, 12Bolt
03-02-2009 #128First of all big thanks to Marty, owner of the incredible http://www.syborgtwinturbo.com/ Big help in letting me use his wheel tool. Made it so easy to measure and check clearances.
I did however notice my wheel wasnt perfectly centered in the wheel well, and that pisses me off, however I'll be able to adjust it once I get the bed permanently mounted I'll figure out just how much I'm off.
Cut out for the tubs, still looking for a spare set of factory tubs if anyone has any laying around. Basically I want to mimic the factory just 6" wider.
One thing I hate is when people run big wheels, or such and the tires and wheel are soo tucked in leaving a huge gap between the bedside and tire, even though sometimes it requires that to fit way up top. I kept it tight, here you can kind of see the tire just touches that lip, well I plan to roll that edge so the wheel will be pretty close to the actual bedside. Laid out I still have a fingers gap up top against the bedside
Just a quick undershot
Measuring for backspacing
Moving up front
Mounted the tire
This is set at ride height
Nick Schiffer
2001 Silverado
Special Thanks to:
...back in the day
03-02-2009 #129Lock to lock
Almost laid out, need to trim some more.
Nick Schiffer
2001 Silverado
Special Thanks to:
...back in the day
03-02-2009 #130
03-02-2009 #131thanks man, I thought the same
Nick Schiffer
2001 Silverado
Special Thanks to:
...back in the day
03-02-2009 #132
- Oct 2004
- St Louis, MO
- 373
I'm gonna have to remember who has the tool, hopefully I can rent it when I get to the point of my build. I'm sticking the exact same rear tires under my 89 Mustang Notch. Getting ready to start on my frame rails soon.
03-02-2009 #133
