    Page 6 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
    Results 101 to 120 of 313
    1. #101
      Nov 2004
      LYNCHBURG,OHIO
      BAD ASS man!! Im digging it!
      Greg Tholen
      GT Motorsports
      Dealer for Wilwood,Baer,Viking,Moser,BMR,Earl's
      (937)763-7272
    2. #102
      May 2007
      Grabbed another sheet of 3/16"
      Built my upper link mounts, going to gusset behind them otherwise they are basically done
      As you can see here the holes I drilled on a 25" radius (same as bar length) no need to re thread as I adjust my bar angles
      Nick Schiffer
      2001 Silverado
      Currently Fabricating Full Tube Chassis
      Special Thanks to:
      Air Ride Technologies - Wilwood Engineering
      ...back in the day
    3. #103
      Feb 2006
      Southern California
      Really nice work. It is great to see this post. keep up the great work!
      Ron
      "If at first you don't succeed Skydiving is not for you"
      1970 Z28
      Scott Mock C6 Subframe, Ridetech RJoint 4 link
      LSX454
      Anvil Auto - through the build
    4. #104
      May 2007
      Quick update
      Started my lower link brackets, 3 position adjustable
      Both bars at 0*
      And roughly where the bags will sit
      These are NOT the bags I'm using, I'm going to run the new f9200s instead, and the upper link bracket will probably be part of the bag bracket.
      Nick Schiffer
      2001 Silverado
      Special Thanks to:
      ...back in the day
    5. #105
      manitowoc wisconsin
      that is some fine work you have done. keep it up
    6. #106
      Oct 2008
      Any updates on this thing? Bada$$ build man.
    7. #107
      May 2007
      Wanted to add a gusset for the upper link mounts
      Finished up the lower link mounts
      Had to bend and weld them together
      Welded them up and added a gusset
      Finally designed and made my under engine bolt in crossmember
      Nick Schiffer
      2001 Silverado
      Special Thanks to:
      ...back in the day
    8. #108
      iceland
      Country Flag: Iceland
    9. #109
      Nov 2004
      LYNCHBURG,OHIO
      Nice!!!!!!
      Greg Tholen
      GT Motorsports
      (937)763-7272
    10. #110
      Feb 2006
      s.f. east bay california
      Your making awesome progress, Wish i could say the same.
      Anyway, keep up the good work. Eagerly awaiting the final product.
      Dog will Hunt
    11. #111
      May 2007
      thanks guys!
      Nick Schiffer
      2001 Silverado
      Special Thanks to:
      ...back in the day
    12. #112
      St Louis, MO
      This is f'kin awesome. I think this is tied with the Syborg build for coolest on here. Both trucks. But that's my $0.02
      I wish I could fab like this.
    13. #113
      May 2007
      CAB IS ON!!!!
      So I finally got my new rear bags, f9100s and at $200 a pc I was skeptical, till they showed up and I love them. On the right is a f9000, (blue tape protecting the billet)
      They get 9.75" of travel, compared to 6.5" ( I think on the f9000)
      More hand made brackets
      Rear bag brackets complete
      Bag in
      Rear end being welded up
      Nick Schiffer
      2001 Silverado
      Special Thanks to:
      ...back in the day
    14. #114
      May 2007
      The edges arent smooth because there will be a shock mount in front of that shortly
      Stock way bar (shape) can be used, plan to run a muscle bar from ART
      Now before I flipped the frame I thought about any weak point and this one stood out to me, where I pie cut it, so I added a gusset, couldn't hurt
      Stripped
      Flipped
      Nick Schiffer
      2001 Silverado
      Special Thanks to:
      ...back in the day
    15. #115
      May 2007
      Boxed in the LCA mounts
      Welded up and smoothed the bottom side, Plan to DA it before Powder coat
      and the frame heads home...
      Back in the garage, (before I organized my tools and such for more room)
      Money shot 3/4" from rocker, right where I want it
      Nick Schiffer
      2001 Silverado
      Special Thanks to:
      ...back in the day
    16. #116
      St Louis, MO
      wow
    17. #117
      Feb 2006
      Idaho Falls, Id
      Did you mention where you got the ends for your 4 link? I plan to build one for my 67 Firebird and I've been trying to find some good ends to use
      Traven
    18. #118
      May 2007
      SuicideDoors.com
      Nick Schiffer
      2001 Silverado
      Special Thanks to:
      ...back in the day
    19. #119
      Farmington Hills, MI
      Thats sick man, you are doing an amazing job.
      JEFF SHORTT
      -IDEAL STEEL
    20. #120
      May 2007
      thanks man
      Nick Schiffer
      2001 Silverado
      Special Thanks to:
      ...back in the day
