Results 21 to 40 of 313
Thread: Project: SCHEVY 2001 Silverado
Maybe I missed it earlier in this thread, but what vehicle did the rack and pinion steering unit come from? Thanks, Randy
05-17-2008 #2www.gmfullsize.com/forum
Just a GM Truck site, not a tech as this site
Triangulated four link, I mention that info up top.Nick Schiffer
2001 Silverado
Currently Fabricating Full Tube Chassis
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
...back in the day
07-14-2008 #3Well haven't updated due to me forgetting the camera, but I've been working on mainly figuring out my front suspension I wanted to make it perfect at ride height, and finally after moving everything upwards, motor 1.5" up i got my arms at 2* LCA and the uppers at 6* this is set at 5.5" ride height. Tire will sit right at the lip of the front tires.
So with that figured out, I started the front crossmember
crazy cuts to make it fit
Made sure the tierods would be clear, at full turn they hit so I will make a small round notch
Tac'd
At final position
Nick Schiffer
2001 Silverado
Special Thanks to:
...back in the day
07-14-2008 #4Centered the rack up, took some measurements
Check out those arm angles, perfect!
Got the steering mocked up
Nick Schiffer
2001 Silverado
Special Thanks to:
...back in the day
07-14-2008 #5and some more pictures...
Check out this, the body bout doesn't have much room to weld to so I could do a plate angle up on one side and the other going down, but I hate that look
so why not make it look factory
all done.... :crazy:
Cut some steel
Welded up and smoothed out, the 2" hole will be drilled later
Nick Schiffer
2001 Silverado
Special Thanks to:
...back in the day
07-14-2008 #6had a few extra hands...
haha not, I wish though.
So I continued with that crossmember, made stock styled rack mounts.
Going to cut down some of the excess on the opposite side
Beveled edges and a nice solid bead
Back on the frame
Temporary bolts holding it in place
Lower control arm mounts, I was going to have them laser cut, but seemed like a waste of money and time for what I will need
Nick Schiffer
2001 Silverado
Special Thanks to:
...back in the day
07-14-2008 #7awesome man
nice pic with the 3 of you lol
I did a similar shot for a friend and his truckGTO Project https://www.pro-touring.com/showthre...-The-Great-One
Colorado Project https://www.pro-touring.com/showthre...cab-CodeRedZQ8
Check Out My YouTube Channel http://www.youtube.com/c/geedsgarage
07-14-2008 #8
