    Page 5 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 ... LastLast
    Results 81 to 100 of 278
    1. #81
      Atlanta GA
      siiiick!
      and what motor mounts did you go with?
    2. #82
      May 2000
      Very nice.
      Any concern with your exhaust being that close to the fuel tank and heating the fuel?
    3. #83
      Jul 2001
      Calgary, AB
      Quote Originally Posted by Mr.VENGEANCE
      siiiick!
      Thanks.
      The motor mounts are ATS pieces; Tyler can fix you up no problem - 702-245-6305 or www.t56kit.com.
      James
      1967 Camaro RS - The OLC
      1984 Camaro GT1
      1989 Camaro 1LE - The BOC
    4. #84
      Jul 2001
      Calgary, AB
      Quote Originally Posted by MarkM66
      Very nice.
      I am not concerned about heat there at all. The pictures make it look closer than it really is (there is about an inch of clearance) and the complete exhaust is being ceramic coated. We are also going to wrap the exhaust over the last two feet or so since in addition to the tank we have diff cooler lines running back there and fuel lines going forward; we also want to minimize heat behind the diffuser. Probably overkill but better safe than sorry.
      James
      1984 Camaro GT1
    5. #85
      Huntington Beach, CA
      Quote Originally Posted by reboot04
      And started looking at mounting options for the coils:
      James,
      How much room do you have between the heads and firewall? DSE created some brackets for Dale Earnhardt Jr's 2nd gen Camaro that I thought were pretty slick.
      Your project is looking killer!
      Rick
      " Better to Be Lucky than Good "
    6. #86
      Jul 2001
      Calgary, AB
      Quote Originally Posted by vp23271
      James,
      No room on the passanger side.
      Besides, the coil brackets that we are using are really really cool...
      James
      1984 Camaro GT1
    7. #87
      Dec 2007
      Springfield,MO
      Mighty fine project you have there.
    8. #88
      Portland Or.
      im likin' what im seein...
    9. #89
      Brisbane, Australia
      Are the cable ties on the braided lines leading to the remote reservoirs permanent? If so have you thought about stainless ones to keep in with the look of this build.
      Love the progress and it is looking fantastic!
    10. #90
      Jul 2001
      Calgary, AB
      Quote Originally Posted by bwhinnen
      No worries, the braided lines aren't even permanent - I just put them together to get the layout and clocking right on the fittings. We are going to try a couple of different options but at the end of the day there will be no zip ties holding anything together...
      Thanks, it's really starting to come together now. Bleeding the brakes while fabricating the diffuser today, Sheetmetal will be back on tomorrow... looking foward to seeing it back together again.
      James
      1984 Camaro GT1
    11. #91
      Jul 2001
      Calgary, AB
      Every spring, Heighton Restoration in Beiseker, AB has an open house and car show. Since we were mocking up the sheetmetal to make sure the fit was correct before welding the subframe in Chris thought it would be cool make the car half way presentable for the show. I think the results are killer:
      The stance is really close but I think that the actual ride height will be an inch higher front and back when we are done.
      The lower valance and Marquez running lights came out pretty well. The chin spoiler is a Carbon Fiber piece that probably will be replaced soon but definetely shows completes the front end well. We're not quite done on the header panel and a few other bits and pieces but wanted to get all the sheetmetal together one last time before paint.
      James
      1984 Camaro GT1
    12. #92
      Jul 2001
      Calgary, AB
      I am really happy with the HRE wheels (ok, heck, I'm happy with how the whole thing is coming together).
      The backspacing on the rears is (IMO) just about perfect.
      James
      1984 Camaro GT1
    13. #93
      Jul 2001
      Calgary, AB
      It's cool to see the entire engine compartment come together. The down bars still have to be painted and are in to confirm hose routing and clearances in the mean time.
      James
      1984 Camaro GT1
    14. #94
      Jul 2001
      Calgary, AB
      I'm still not quite done on the plumbing for the remote reservoirs. There winds up benig alot going on in that corner and I hope to be able to clean up the -4an lines to the reservoirs a bit before I'm done there.
      James
      1984 Camaro GT1
    15. #95
      Jul 2001
      Calgary, AB
      Matt at RFR Custom Fabrication made up the killer shims for the fenders. The down tube bolts will be changed out in final assembly.
      There is still some work to finish up at the back. We are about half way done the rear bellypan but it's coming together really well.
      James
      1984 Camaro GT1
    16. #96
      Jul 2001
      Calgary, AB
      The radiator support and closeout panel was a ton of work but looks natural with the sheetmetal in place. The cable release latch assembly is nice and tidy as well.
      Again Matt at RFR Custom Fabrication came through with the upper collars for the hood pins. The Ring Brother's pins were originally designed for Mustangs and left some threads exposed on the Camaro. Matt went above and beyond here and came up with a perfect solution.
      James
      1984 Camaro GT1
    17. #97
      James,
      Car looks awesome. Can you post a picture of the hood catch?
      Dave
    18. #98
      Franklin, TN
      What paint (color, brand and #) is on the radiator support and closeout? Looks great!
    19. #99
      Dallas TX
      By far one of my favorite builds. Even the nicest cars I always see something I would change if it was mine. I can't find anything to change on yours.
    20. #100
      Jul 2001
      Calgary, AB
      Quote Originally Posted by Fireeater
      James,
      Dave
      Thanks Dave, I am sure that I can find something of the catch for you, anything specific that you would like to see?
      James
      1984 Camaro GT1
