    Page 14 of 14 FirstFirst ... 4 9 10 11 12 13 14
    Results 261 to 278 of 278
    1. #261
      Jun 2006
      Thanks for the pic James. You don't know me but Pedro and I had to bust a move to get that to you. Looks great, very nice job, you car looks fantastic.
      Jason
    2. #262
      Aug 2006
      Indianapolis, IN
      My jaw is on the floor... She's the perfect blend of modern and retro. Absolutely stunning work.
    3. #263
      Jul 2001
      Calgary, AB
      So... one of the things that showed up on the post race inspection after 'Vegas was some differential fluid that pushed out the vent and past the woefully inadequate filter that I had been using. I had expected problems there but at that point in time hadn't found a solution that I felt I could depend on (and by depend on, I mean something that I could have in the trunk that wouldn't stink up the entire car while properly doing it's job).
      Fortunately I decided to give Mike Norris (Norris Motorsports) and John Parsons a call after seeing their new fuel breather on Steve's car. After a bit of discussion they came up with a clean, simple, and (hopefully) effective solution that I just about have installed and plumbed...
      The basic components of the kit as supplied is the breather itself and a tidy billet mounting clamp:
      When the breather cannister is dissassembled you can see that this is more than just a simple vented catch can:
      Drain holes allow what differential fluid is collected to gravity drain back into the differential while at rest:
      James
      1967 Camaro RS - The OLC
      1984 Camaro GT1
      1989 Camaro 1LE - The BOC
    4. #264
      Jul 2001
      Calgary, AB
      To complete the installation, you need to supply your own AN hardware and hose, as well as a small breather (I used a K&N). For hardware I needed a 1/4" NPT plug and two -6AN to 1/4" NPT 90 degree fittings. I have used Earls Ano-Tuff fittings throughout the OLC build but, unfortunately, none were available locally (one of the joys of trying to build something like this in the great white north) so I grabbed some traditional fittings from my stock to get things together for now - I'll change them out later.
      First a plug for the extra/optional vent outlet, in an ideal world this wouldn't be here but it is and it's not much of an inconvenience:
      I used 90 degree fittings top and bottom to mimimize height (and save a bunch over 90 degree hose ends). The "in" and "out" are clocked at 90:
      James
      1984 Camaro GT1
    5. #265
      Jul 2001
      Calgary, AB
      The recommended mounting of the breather is for the "in" port to allow a straight drain back to the differential; obviously the whole assembly needs to be above the differential at all times. Since trunk space is at a premium in the OneLapCamaro, I fabricated a bracket on the back of the rear bulkhead "Y" supports (behind the upholstry) which puts the breather well out of the way:
      I have two large rubber grommets for the remote reservoirs which I am using to pass the line from the differential through up into the trunk. On the input side it will be a straight shot into the breather, on the "out" side which will terminate with the K&N filter I ran a line across the trunk, and out on the other side:
      Unfortunately, I ran a touch short of -6 hose and will have to wait until Monday to finish this up...
      James
      1984 Camaro GT1
    6. #266
      Mountain View, CA
      Cool.
      I'll be needing one of those as well. JP, tell me what you need to send me one.
      True T.
      My blog
    7. #267
      Quote Originally Posted by True
      Call Mike at Norris Motorsports. We work together to make them, but he's the guy to give money to.
      jp
      ​John Parsons
    8. #268
      Portland Or.
      amazing car! I personally don't like the front airdam at allllll but the rest of the car is beautiful, i really like the dash and the color! Nicely done.
    9. #269
      Maryville, TN
      Post up a video of this bad boy running!!
      A.K.A: That bald guy
      Find me on Facebook or my personal website.
      - 67 Camaro: Current Project Car
    10. #270
      Jul 2001
      Calgary, AB
      Quote Originally Posted by 67SSDan View Post
      There was a short video up from the optima Invitational but I can't remember where it is... the weather here stinks right now so you'll have to wait about 5 weeks for anything new. There were a couple of crappy youtube deals when we were first starting but they are not worth much.
      Should have no problems putting together some cool vid's in California!
      James
      1984 Camaro GT1
    11. #271
      Socal, Ca
      Quote Originally Posted by James OLC View Post
      I just bought a hand-held camera for this sort of thing. I should have made this purchase before the optima event. James, I would love to get some in car footage when you are in Ca...if you dont mind.
      David
    12. #272
      Sep 2007
      Thehoodstock,GA
      Quote Originally Posted by olds87 View Post
      The car make me salivate in my mouth.
      Just awesome
      That car makes me salivate in your mouth too!
      MarkK
    13. #273
      Jan 2009
      Cannes, France
      absolutely awesome car
    14. #274
      Feb 2006
      That is very cool. Looks like Bad Penny, which is also very awesome.
      Alex Godsey
      Somerset, KY
      Pro Touring 67 GTO
      461 Pontiac Power
    15. #275
      looking great
      Your doing a killer job, cleaning up the core support area is a great call, love to see the progress other people are making, and i appreciate the endless hours you have already put into your ride.
    16. #276
      iceland
      Country Flag: Iceland
    17. #277
      May 2008
      Austin, Tx.
      Hey James,
      I've got a quick question for you... I noticed these ribbed rings on your axle housings (right behind the brake rotors)... Is this some kind of sensor for the Racepak setup? I didn't think you had any kind of traction control needing wheel sensors or ABS brakes on the car...
      Ray
    18. #278
      Mountain View, CA
      Reluctor rings for ABS. Though I don't think he has ABS installed yet.
      True T.
      My blog
