    Page 11 of 13 FirstFirst ... 6 7 8 9 10 11 12 13 LastLast
    Results 201 to 220 of 245
    1. #201
      WOW! Just getting caught up on your progress, you've done a lot of nice work since last time I checked in. It all looks great! I'm going to make sure I check in more often. Keep up the good work.
    2. #202
      Aug 2002
      Waleska Ga.
      Thank you sir.
      I’m waiting on fuel lines and fitting right now. Should be here this week. Then I’m back on this one. I’m also just started a 69 Camaro build, I’m supposed to be retired.😂
      David Sloan
    3. #203
      Aug 2002
      Waleska Ga.
      69 Elcamino time.��
      New fuel lines ran ,started installing exhaust and cold side
      Its so much easier to do on the rotisserie. Waste gates installed.
      Brake lines to the rear end completed.Name:  45B2E0F6-6DE2-4021-A774-8D5656D3809C.jpg
Size:  279.1 KBName:  964C5C3D-A676-49D5-8258-042D7BA6EB3B.jpg
Size:  316.8 KBName:  DB3BB233-42D4-4E50-A9C1-3A81CAFBCF96.jpg
Size:  274.3 KBName:  BE26313C-3F89-4F08-A055-7176B1F463CA.jpg
Size:  246.7 KBName:  B8BF2464-A821-42AA-8C62-3EB74971BCCC.jpg
Size:  233.4 KBName:  73ED8EEE-97D0-4F62-BA16-E78573E589B4.jpg
Size:  271.8 KBName:  EF87FD59-3559-46FE-9105-353D98087C6D.jpg
Size:  420.3 KBName:  83381D00-8A26-42B0-AED2-4728829BA108.jpg
      David Sloan
    4. #204
      Sep 2013
      sw Kansas
      No question about easier. Specially for us old guys.
    5. #205
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by wfo guy;[URL="tel:1388873"
      1388873[/URL]]No question about easier. Specially for us old guys.
      Yes sir!😂
      David Sloan
    6. #206
      Aug 2002
      Waleska Ga.
      Elcamino on its own wheels
      Off the rotisserie ��Name:  8104E649-6C34-440D-9219-425812C7CB2C.jpg
Size:  564.1 KBName:  E6D22489-1036-490C-BF55-4EDFCD29AB33.jpg
Size:  677.3 KBName:  799B0B82-10E0-47E9-90AA-01E59DC8AA74.jpg
Size:  573.7 KBName:  47ED96D3-A160-49CE-A7F0-FFAF86348D67.jpg
      David Sloan
    7. #207
      Sep 2013
      sw Kansas
      A project on wheels is always better unless you have one of the forklifts with 8' forks. It's good to see green in the trees in the background. We may live through another winter.
    8. #208
      Aug 2002
      Waleska Ga.
Size:  466.5 KBName:  D97CFE26-1B4F-48BC-954D-19042153DA5A.jpg
Size:  497.5 KBName:  699710DC-9AA3-41EA-A4E8-B4DD9B66035E.jpg
Size:  441.3 KBName:  F3EE788D-2D74-4760-AE51-C871D4256C33.jpg
Size:  394.9 KBName:  F1367E91-1487-4016-B69A-E4DE8144F870.jpg
Size:  529.6 KBName:  BEDCC9E8-A850-4D1D-B900-A5B95FCDC12C.jpg
Size:  513.2 KBName:  50403704-5BCC-4B14-8B21-F907869A3455.jpg
      Motor and transmission installed, so happy to be at this point.
      David Sloan
    9. #209
      Aug 2002
      Waleska Ga.
      Today’s work 69 Elcamino project
      Installing the vintage air lines and the close out panelsName:  C54A15B1-86B9-4DF7-8D10-68B7BDE12C8A.jpg
Size:  382.5 KBName:  011E61B7-29BC-47E1-A731-60AD2B05BB0F.jpg
Size:  298.5 KBName:  9166980B-3C21-4E51-BE5F-5EB8D4746D63.jpg
Size:  423.5 KBName:  927F4C83-B47A-4F02-B100-CD618E8CBFBF.jpg
      David Sloan
    10. #210
      Looking good!
      I am a little confused as to how the wastegates are plumbed and why they are so far back in the exhaust system.
    11. #211
      Aug 2002
      Waleska Ga.
      Looking good!
      based on information I could find, the waste gates are best at a 90% before the turbo. So when the throttle pedal is let off the gas’s coming from the motor will hit the gates in a straight line to vent off excess gas’s.
      this turbo thing is an experiment for me to see if I can make it work.
      im prepared to make changes to the system in the event it doesn’t work out or I just don’t like how it works.😊
      thank you sir!
      David Sloan
    12. #212
      Aug 2002
      Waleska Ga.
      Since I was doing metal work on the 69 Camaro this morning and I had put 6 hours on it.
      Took a brake to rest then back to the garage to work on the Eldog.
      I needed to make the cover for the shifter hole in the 69 Elcamino couple hours later this is what I got.Name:  22E2C001-5B76-4E83-A51E-6D46C3F20C0F.jpg
Size:  627.2 KBName:  38A4EB6F-A271-4221-A0E2-6DDF797E9469.jpg
Size:  491.7 KBName:  8568399E-690C-4999-AE07-160D3DB9B63D.jpg
Size:  313.3 KBName:  FD0C9777-D021-4D1F-957B-063EDDC74562.jpg
      David Sloan
    13. #213
      Aug 2002
      Waleska Ga.
      1969 Elcamino project
      Picked up the drive shaft Friday and some other parts needed for this car and the 69 Camaro build.
      I decided that I wanted the metal dash to be removable so that’s what I’ve done. Cut all the welded pieces off then cut and trimmed until it fit.
      Next up I will try to build a new gauge cluster out of metal.
      I want to make a mount for the Holley dash display to mount in. The last picture is the display unit.Name:  0046341A-7853-486E-A8B9-8C68CCFD3C48.jpg
Size:  444.2 KBName:  CE693B53-E29E-4619-BB6E-9BA377EE0159.jpg
Size:  401.4 KBName:  B8F45410-331E-4170-A866-5002F761C6D7.jpg
Size:  503.0 KBName:  D93A3B99-BF34-41A9-9511-8C2572EEB823.jpg
Size:  560.5 KBName:  BD4BEFF1-22FC-422E-A7AA-0508A38E4A5F.jpg
Size:  506.3 KBName:  653E65EC-9BB0-46B3-883A-30E9830C0B2B.jpg
Size:  392.7 KBName:  0046341A-7853-486E-A8B9-8C68CCFD3C48.jpg
Size:  401.4 KBName:  D93A3B99-BF34-41A9-9511-8C2572EEB823.jpg
Size:  506.3 KBName:  148F5668-E410-41F6-8488-424868CC8B4B.jpg
Size:  382.6 KBName:  ED163C54-6325-4FA6-A7FF-B74B84CFE67A.jpg
      David Sloan
    14. #214
      Sep 2013
      sw Kansas
      Lots of interesting stuff there. I know the rear mount turbo's have been used for sometime. I will be interested to hear about turbo lag after you start driving it. Once you have the tuning ironed out, I wonder if it will be very noticeable? I like the bolt in dash. For us old guys who can't see and stand on our heads, that is a great solution.
    15. #215
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by wfo guy;[URL="tel:1389384"
      1389384[/URL]]Lots of interesting stuff there. I know the rear mount turbo's have been used for sometime. I will be interested to hear about turbo lag after you start driving it. Once you have the tuning ironed out, I wonder if it will be very noticeable? I like the bolt in dash. For us old guys who can't see and stand on our heads, that is a great solution.
      thank you sir.
      i can’t wait to find out about the lag myself. Yep not in to laying on my back trying to wire this thing up.
      David Sloan
    16. #216
      Aug 2002
      Waleska Ga.
      Figuring out the layout for everything going in the dash!
      David Sloan
    17. #217
      Aug 2002
      Waleska Ga.
      Today’s work,Dash holes rough cut for the gauges . I got to hammer and dolly it back straight now. I have a love/hate relationship with hole saws.��Name:  1F502836-2953-4057-A4CB-325956C42F41.jpg
Size:  412.2 KBName:  894A1FE0-112C-4379-8F3A-552F7CC607B1.jpg
Size:  380.0 KBName:  FC514591-1954-4E1F-8405-F157FFA0AB36.jpg
      Gauge layout and some pie cuts to get the gauges at the right angle.
      David Sloan
    18. #218
      Aug 2002
      Waleska Ga.
      More fitting and tack welding today.
      Got the Holley efi display mounted, A/C controls nextName:  045D4E0D-A9CD-4D60-B655-E7D2720D0F0A.jpg
Size:  349.7 KBName:  901989FD-5917-48ED-91CA-CC2E746FC61A.jpg
Size:  358.4 KBName:  1F17662E-AB2F-430C-A55D-77B9C2D43E05.jpg
      David Sloan
    19. #219
      Hopefully by the time you are ready to fire it up, Holley will release the Terminator X V3 firmware for the 7" dash...
    20. #220
      Aug 2002
      Waleska Ga.
      Please fill me in on this update. I’m not all that computer savvy 😊
      David Sloan
