    Page 22 of 32 FirstFirst ... 12 17 18 19 20 21 22 23 24 25 26 27 ... LastLast
    Results 421 to 440 of 637
    Thread: 51 Ford pickup
    1. #421
      Minneapolis, MN
      ^^ agree with that. My project needs even some lackluster progress to happen!
    2. #422
      Sep 2013
      sw Kansas
      I wouldn't tell you this was a good decision but this is what I did. The grille and inner fender panels have been shot in gray. The grille will have to be redone next year when it warms up. The rest of the front sheet metal was in white epoxy primer. I have some left over clear that is the less expensive kind I've used. I wanted to seal the primer from moisture and fingerprints so I shot clear over the primer. I'm reasonably sure this will protect the parts till next year when all the body work will be completed. I will be doing double work but I didn't have any real good options. I needed at least 1 more month to do the work on the front and then paint it. The temp is cool enough at night that the paint won't completely cure. I caught a warm day and shot everything. The truck is going back together very soon.
    3. #423
      It sucks when mother nature chases you out of the garage with the cold. At least its protected. Good idea.
    4. #424
      Jun 2012
      Australia
      Country Flag: Australia
      What sort of temperatures can you spray at before it becomes too cold?
    5. #425
      Sep 2013
      sw Kansas
      Gojeep, I spray at 70 and above but the urethane needs at least 8 hours above 60 degrees to fully catalyze. When it gets below 65 in the garage, I get real nervous. If the temp gets to low, the paint will dry but not have the chemical reaction. A guy could have a real mess to remove and start over.
    6. #426
      Sep 2015
      SW KS
      On my Riviera (which I bought in Ingalls, btw) I'll be going with a matte white and I'll be blacking out all my Chrome trim, like it appears you're doing. If you need an extra set of hands, give me a couple days heads up and I'd love to come out and help you.
    7. #427
      Jun 2012
      Australia
      Thank for that.
    8. #428
      Feb 2003
      St. Louis, Missouri
      A lower temp hardener will cure that problem and have you painting for another month.
      Rick Butterfield
    9. #429
      Sep 2013
      sw Kansas
      It was time to put the truck back in the shop this evening. I had noticed an oil leak on the left valve cover. Out in the sun, I found this crack. I cleaned, sanded and repaired with Evercoat plastic epoxy. This is the same stuff I used on the right cover. I'm guessing the salvage yard people got a little careless with the chains when removing the engine. I'll keep my eye out for valve covers but the used stockers seem to bring at least $75. I'd like to spend way less than that.
    10. #430
      Sep 2013
      sw Kansas
      Chip, I appreciate the offer. I'll get in touch sometime and see if we can meet.
      Tiny bit of progress today. I removed a little bit of ugly in the brake dept. This was the first time to use my OTC metric bubble flair tool. I'm really happy with the bubble flairs. I bolted on the fenders and the grille. If this is the milk truck and the front is still in primer, does that make it half and half?
    11. #431
      It looks good all together.
    12. #432
      Jun 2012
      Australia
      Nice shot in the sunshine there.
      What is the round hole for in the door?
      Might pay to support the proportioning valve too if not in the plans already.
    13. #433
      Sep 2013
      sw Kansas
      Gojeep, the hole is a black lock tumbler. The way the window channel fits against the rear of the door, there wasn't anyplace to install it. The rod from the latch to the tumbler is bent in several places to clear all the obstacles.
    14. #434
      Aug 2014
      Quote Originally Posted by Gojeep View Post
      Weird. I've been lurking your build thread on 4wdaction.com.au for a while now, checked in a few times last week while you were on holiday and you show up over here! lol
      Anyone who wants to see something cool, check this out:
      http://www.4wdaction.com.au/forum/vi...?f=22&t=108215
      This man does some sick metal work. I bet he'll only need high build primer to get it perfect before paint!
      Oh, and Sorry for the hijack, the truck looks good in white. Is that your plan for a final color or did you just do it because you had it left over?
      Jay
    15. #435
      Sep 2013
      sw Kansas
      Stopping point for the day. Running boards installed. They are Dark Highland Green which was the first color choice I had. The wiring in front of the core support is cleaned up a little.
    16. #436
      Jun 2012
      Australia
      Quote Originally Posted by JayinMI View Post
      Jay
      Ha ha, thanks for the comments Jay.
    17. #437
      Jun 2012
      Australia
      On my white Jeep I swapped all the black locks and handles etc for chrome ones so they blended in more. Colour coding would be even better but not as hard wearing for a lock.
    18. #438
      Sep 2013
      sw Kansas
      Sanded and buffed on the doors this evening. Needs more work.
      There's a profile shot without obstacles and a shot of the door without enough light to see everything.
      Gojeep, the buffer and I removed a lot of the black from the tumbler. It was too dark to take a pic to see the difference.
    19. #439
      Dec 2010
      Apex, NC
      Jun 2012
      Australia
      Nice and smooth!
      The Jeep black key lock just needed the black polished off too and was chrome underneath.
