    Page 25 of 32 FirstFirst ... 15 20 21 22 23 24 25 26 27 28 29 30 ... LastLast
    Results 481 to 500 of 637
    Thread: 51 Ford pickup
    1. #481
      Sep 2013
      sw Kansas
      Thanks, Pat.
      End of the day. There is a brace that the hinges and springs attaches to that isn't removable. Not being able to work properly over it causes grief! I have some shrinking to do and some hammer and dolly work but it's better than it was. The small patch is a rusty area that I had decided to forget. I never expected this to be bondo free but it won't have any deep spots. The whole hood and front fenders are going to need bondo from one end to the other.
    2. #482
      Jun 2012
      Australia
      Country Flag: Australia
      Glad you are enjoying driving it around and are still trying the finish it fully.
      Should have coated the patch above the brace though so the rust doesn't return quickly.
    3. #483
      Sep 2013
      sw Kansas
      Gojeep, you are correct. Guess who's out of epoxy primer? There's enough space to spray in there, just not real well.
    4. #484
      Sep 2013
      sw Kansas
      I made a t-bar to bolt to some of the hood hinge pins and clamp to the front of the hood to facilitate holding it while sanding. I hammer and dollied some more areas and am ready to start sanding again.
    5. #485
      Sep 2013
      sw Kansas
      I spent a lot of today working on the hood. I hammered and dollied on the last repair some more. I put the hood on the truck for a test fit. The brace at the back is bent some and I don't think I can bend it without causing more problems. It makes the hood wide at the cowl at the bottom. I started to fill the side vents by bending the metal back flat. That proved to be a poor idea. I ended up cutting out both sides and making panels to fill the area. One is tacked in before I quit today.
    6. #486
      Sep 2013
      sw Kansas
      Today's work was finishing the side started yesterday and doing the other side. All the holes are filled and I believe after one more test fit, I'm ready to start bondo.
    7. #487
      Jun 2012
      Australia
      I just put louvers in my hood and you remove them! ;)
    8. #488
      Sep 2013
      sw Kansas
      "One more test fitting". Did anybody just see the tooth fairy? How about 4 more attempts before I quit. I'm finally ready for bondo.
    9. #489
      Sep 2012
      London, Ontario
      Awesome as usual! I've had to take some time off, with a change of careers, but this makes me want to get back out to the garage.
      73 Maverick Grabber Project
      My never ending project:
      https://www.pro-touring.com/threads/...hlight=grabber
    10. #490
      Sep 2013
      sw Kansas
      Thanks for the comments, guys!
      Mr. Bondo got started and quit. It's hard to find good help.
    11. #491
      Sep 2013
      sw Kansas
      After an embarrassing amount of time, the hood is finished with bondo, sprayed with epoxy and the first application of high build primer. First of several. For those of you that like numbers, it was 104 degrees in the shop this afternoon.
    12. #492
      Oct 2015
      Dec 2010
      Apex, NC
      Very nice. Heat sucks, I am not motivated at all with it blazing.
    14. #494
      Jun 2012
      Australia
      You must have great cooling that extra heat under the hood wont bother you.
      Looks like a fibreglass one now! ;)
    15. #495
      Sep 2013
      sw Kansas
      2nd app. of high build primer after several hours of hand blocking. Really not very exciting.
    16. #496
      Sep 2013
      sw Kansas
      Today's stopping point
    17. #497
      Apr 2014
      Looks good! I was sanding primer in the heat today also, not fun!
      Pat
    18. #498
      Sep 2013
      sw Kansas
      Pitiful update. Bondo is close to the end on the fenders. Hood is ready for the next application of primer. I'm really slow at this.
    19. #499
      Sep 2013
      sw Kansas
      Lunch break. This is the hood in the 3rd application of primer. I believe it will be the last. Meet Mr. Buck. This is one side of the wheel well opening extensions.
    20. #500
      Any progress in that heat is great progress. The hood looks nice. I like the use of the buck it looks like it worked out nice.
