    Page 21 of 32 FirstFirst ... 11 16 17 18 19 20 21 22 23 24 25 26 31 ... LastLast
    Results 401 to 420 of 637
    Thread: 51 Ford pickup
    1. #401
      Any progress is good!
    2. #402
      Sep 2013
      sw Kansas
      I spent the evening sanding on the front end parts. A couple of days with hammer and dolly will make them way better. Yecch!
    3. #403
      Jun 2012
      Australia
      Country Flag: Australia
      Getting there my friend. Thanks for showing your progress.
    4. #404
      Sep 2013
      sw Kansas
      I spent 2 hours with an assortment of hammers and dollies on the lower fenders this evening. The dents are more like ripples now. I don't think I will be able to metal finish them. I'm moving on to the next step in the operation.
    5. #405
      Jun 2012
      Australia
      Ripples are often a sign of excess material from stretching from the original damage or using a steel hammer on steel dolly to remove it. I find using a nylon headed mallet against a steel dolly will allow them to be flattened without adding more stretch. Sometimes I use a dolly made from wood or lead filled rubber with a steel hammer for the same purpose. One face or the other has to have some give so the metal has some where to go without being thinned and stretched even more. That and doing it all off dolly as much as possible. Any extra left can be removed with a shrinking disc. I know you said you didn't have one, but cheap enough to buy and find even the small 5" one from Wray does a good job. http://www.proshaper.com/product/5-d...hrinking-disk/
    6. #406
      Sep 2013
      sw Kansas
      Gojeep, I think I'll order one. I'll look at the info later and see what size will be the most useful. Thank you.
    7. #407
      Jun 2012
      N. Shore, Ma
      I used the back side of a fine grit 4 1/2" fiber backed sanding disc for all my shrinking, worked pretty good but I am sure the real shrinking disc would be easier.
      http://www.use-enco.com/1/1/13111-00...ber-discs.html
      Eric
      Building 1969 GTO - Roadster Shop chassis, LQ9 w LS3 heads and rebuild parts from TSP, Bowler prepped Magnum T56 6 spd, 3 Link Strange 9" w Speedway Floater Hubs, Wilwood 14" F - 13" R brakes, 275.18 - 345.19
      https://www.pro-touring.com/threads/94970-69-GTO-Build
    8. #408
      Sep 2013
      sw Kansas
      I started playing with shrinking disk repairs. I'm working on the lower fenders. There are spots I made good progress and areas that weren't so good. One more skill to learn!
      Eric, I'm trying your method because that's what I had available in short order.
    9. #409
      From what I've seen you do so far, you'll get it.
    10. #410
      Sep 2013
      sw Kansas
      Blasting away! What could be more fun on a nice fall afternoon. The shot of the fender is in progress. I should get the rest of the front sheet metal blasted today. In case anyone is curious, I have purchased 60 bags of blasting material. I think I have enough to finish the hood. I don't want to let anyone think I know much about blasting so I maybe wasting as I go. I did shrink some areas on the fenders. Some more progress.
    11. #411
      Sep 2013
      sw Kansas
      I ran 8 bags today. I'm about to be tired.
    12. #412
      Jun 2012
      Australia
      Glad it is working out for you.
    13. #413
      Sep 2013
      sw Kansas
      I've spent the last 2 evenings welding cracks that I didn't see before blasting and pounding on dents. I need another month of warm weather and I'm pretty sure that isn't going to happen. The hood has 2 rust spots that arrived after blasting. I'm going to make plates to fill the openings at the front. Just more work.
    14. #414
      Sep 2013
      sw Kansas
      Just in case anyone thinks I'm not working. Notice I didn't say "making progress".
    15. #415
      Jun 2012
      Australia
      Easy to spend a lot of time on things that are not photo worthy. Doing that now too, just stripping paint and fixing minor damage!
    16. #416
      Feb 2015
      Ladera Ranch, CA
      I ran across this thread yesterday afternoon and have read the whole thing. You have done a great job with this build!! Sorry to see the donor car ended up being more of an issue than a help. Keep up the great work! I'm soooo keeping my eye on this thread now!!
    17. #417
      Sep 2013
      sw Kansas
      Break time. Front of the hood filled and the 2 rust repairs on the brace area.
    18. #418
      Sep 2013
      sw Kansas
      Epoxy primer wherever I could shoot it. This is rust preventive. Some of the parts will have to be flipped in the next day or so and the other side shot.
    19. #419
      Sep 2013
      sw Kansas
      TLU! (totally lackluster update), I primed the other side of all the front end sheet metal this evening. Ho Hum.
    20. #420
      Sep 2015
      SW KS
      Some progress is better than no progress!
