    Page 12 of 32 FirstFirst ... 2 7 8 9 10 11 12 13 14 15 16 17 22 ... LastLast
    Results 221 to 240 of 637
    Thread: 51 Ford pickup
    1. #221
      Jun 2012
      Australia
      Country Flag: Australia
      What a shame about the engine. :(
    2. #222
      Jan 2009
      Chattanooga, TN
      AH bummer man! I'm with you about failing in the garage though! Way easier/cheaper than on the side of the road somewhere.
      Stephen S.
      1967 Ford Mustang 4.7L, T5
    3. #223
      Dallas TX
      Looked all through this today. Love the build. Great work but at first I was saying nooooooo to your wheel choice but was relieved to see you switch toward the end. Perfect now!!
    4. #224
      Sep 2012
      London, Ontario
      Oh crap....Man that sucks.
      73 Maverick Grabber Project
      My never ending project:
      https://www.pro-touring.com/threads/...hlight=grabber
    5. #225
      Sep 2013
      sw Kansas
      This is a quick rundown of what I considered. There is no add-in for time for new fabrication on any changeovers.
      Engine options
      5.7 hemi
      used with acces. $3680 plus frt. wiring harness and ecu $1,650
      new with clutch $5595 plus $329 frt.
      bellhousing $100
      Ramjet 350
      new $5745 free frt.
      acces. $300
      bellhousing $100
      clutch $150
      5.3 LS swap $1050 and up plus frt. PSI harness and ecu $900
      Hanlon adapter for 3650 trans with front retainer $550
      Coyote new $6,200 wiring harness and ecu $1,500
      acces. at least $500
      Used f150 coyote $3000 plus frt. wiring harness and ecu $1,500
      used low mileage 4.6 Crown Vic 4.6 $645 with shipping
      _________________
    6. #226
      Sep 2012
      London, Ontario
      Coyote in any form, would be cool. I can't publicly express my LS engine envy.
    7. #227
      Feb 2011
      Indpls, IN
      Sorry to hear about the engine problem.
      I was watching your Youtube video and its hard to read the gauges. But it appears that the oil pressure was 0. Had you had the distributor or cam sensor or oil pump out?
    8. #228
      Sep 2013
      sw Kansas
      Jetfixr, the wiring to the fuel pump and gauge was unplugged when that video was taken. There's something in that circuit that ties all the gauges together so they were all non-functioning. That engine had 103,000 miles on it and showed no signs of recent disassembly. The grease was really thick on most of it. It looked to be original except for the intake manifold which had the alum. crossover.
    9. #229
      Sep 2013
      sw Kansas
      Another day of fun and exercise! Moving forward to start over.
    10. #230
      Sep 2013
      sw Kansas
      Today's task after cleaning up the mess from the engine removal was to pull the pedal assembly and modify the mounts. There are 4 .5" risers that protrude towards the firewall that I believe were to provide spacing for firewall insulation. The master cylinder rod attached to the hydroboost is non-adjustable. In order to equalize the clutch and brake pedal heights, I removed .350" of those risers,now the pedals are very close to each other. I double walled the firewall in that area for stiffness for the pedals and didn't realize there wasn't any adjustment on the brake rod.
    11. #231
      Sep 2013
      sw Kansas
      We've had a little Indian summer the last 2 days. Today while it was 82 degrees, I vatted the bed floor panels and epoxy primed both sides and painted one side. I'm still thinking of using bed liner but I'm going to think about the budget before that decision is made. You can see I had a spectator in one pic. Doesn't he know it's February?
    12. #232
      Sep 2013
      sw Kansas
      Today's boring task. The hood had been ground on where the lead was and it was really thin. The brace underneath is bent and I'm going to have to make a jig to straighten it.
    13. #233
      Sep 2013
      sw Kansas
      The replacement engine was delivered today. There was a large cardboard box hiding the contents. There was no visible damage to the box. After removing the box I found that they used a pallet that didn't fit the engine at all. The oil pressure sender was broken and there was a thick oil over the front of the engine and in the valley. After I removed it from the pallet I gave it a solvent bath. Something strange blew off the intake. It appears to be leftover rib bones. They were large for chicken bones. Nice of someone to leave his lunch mess for me to clean up. After cleaning up the mess, the engine looks to be sealed up well. There's no sign of an oil leak on the pan or seals. I put a socket on the crank and it turns over so that's how far I got today. This weekend there will be lots of items to changeover.
    14. #234
      Sep 2013
      sw Kansas
      Everything's ready to do the swap tomorrow. I wonder if I can turn a 2 hour job into all day?
    15. #235
      I hope it all goes smooth for you today with the swap.
    16. #236
      Sep 2013
      sw Kansas
      I'm 4 hours behind my estimate but better than a lot of days I've had in the last couple of years. One of the pics is of a heater hose nipple that was broken off when I got the engine. There was a red plug in it so I assume the salvage yard new it and didn't mention it. We'll have a discussion about that. I faced it off and tapped it for 3/8" pipe. One pic shows the clearance that I have for the oil filter now. The new engine didn't have the oil cooler that the old one had. 2 less lines and 2 less places to leak. I had to drill and tap the crossover on the intake manifold for the ect sensor for the ecu. There was a few other items but most were small. I've spent most of the day bent over. I'll be feeling that for awhile.
    17. #237
      Jun 2012
      Australia
      Good to see that you are making some headway.
    18. #238
      Sep 2013
      sw Kansas
      It's running. Ford uses 2 ground systems. I haven't got it figured out yet. More work ahead.
      http://youtu.be/yu8Yf_aew8A
    19. #239
      Sep 2013
      sw Kansas
      I worked all day and got about 30 minutes of results accomplished. One pic is of the trans harness after it was changed from auto to manual. One is a pile of some circuits that I traced and removed. One is the rear harness in a semi- complete form. The throttle pedal hasn't been installed yet but it is able to move under it's own power now.
    20. #240
      Jun 2012
      Australia
      I'll have a lot of stripping excess wiring from my donor as well being a WK Grand Cherokee Hemi 4 door wagon, but transferred into a 48 Willys Pickup truck!
