    Page 17 of 32 FirstFirst ... 7 12 13 14 15 16 17 18 19 20 21 22 27 ... LastLast
    Results 321 to 340 of 637
    Thread: 51 Ford pickup
    1. #321
      Jun 2012
      Australia
      Country Flag: Australia
      Lets hope that is the end of it.
    2. #322
      Sep 2013
      sw Kansas
      The first pic is of a flare union in the return line. I found an area where a bend had collapsed for some reason around the center crossmember. I removed that and spliced in some replacement tubing. That lowered the fuel pressure to 48 lbs. I got to measuring the unions and found that they were smaller than the id of the line which is 3/16". I bored each union on the lathe to 3/16". Then the gasket on the schrader end of my fuel gauge came apart so I don't know if I'm where I need to be yet. The bed strips are painted and in. Foot prints are free.
    3. #323
      Sep 2013
      sw Kansas
      This morning the brain engaged and I decided that the o-ring kit I have was the answer to the fuel pressure gauge. When I got home, I found an o-ring that was close to the size of the Schrader valve and tried it. Success! The fuel pressure problem has been fixed. I still have something going on but I haven't come to a conclusion as to what is causing it yet. I'll try not to be boring until I have the answer at which time I will post it. Note that I'm positive that I will find it.
    4. #324
      Sep 2013
      sw Kansas
      What I thought was a piece of hose in the fuel return line near the tank with factory connectors turned out to be a piece of plastic hose with rubber sleeve. It was kinked at both ends. I now have the correct fuel pressure and believe I have solved all the efi troubles.
    5. #325
      glad you found it. That's different
    6. #326
      Jun 2012
      Australia
      That would be great of it the last of the efi problems.
    7. #327
      Sep 2013
      sw Kansas
      Short video. Window down, I'm operating the camera while driving. The last of it is hands free on the wheel.
      https://youtu.be/Xq2KETfvlWM
    8. #328
      Jun 2012
      Australia
      Must start feeling all the effort has been worth while.
    9. #329
      Sep 2013
      sw Kansas
      I realized if I didn't quit driving it that it would never get finished.
      This morning I got started early. I'm sure someone appreciated the noise. I spent 5 hours doing hammer and dolly work. I'm not good enough to make it good but now the plastic will be thin. I rolled the openings for the tail lights and fuel filler hole. I blasted them one more time and hit it with the da. I'm ready to weld in the panels where the running boards bolt on and then it's time for bondo.
    10. #330
      Nice job on the light and fuel opening they look good. The motor sounds good in the video.
    11. #331
      Sep 2013
      sw Kansas
      2 more rust panels installed. I'm tired of rust!
    12. #332
      Sep 2013
      sw Kansas
      Threw them in the vat one more time and epoxy primed. Body work is next. There's not a straight place on either fender.
    13. #333
      Jun 2012
      Australia
      Getting there though which is the main thing. I been removing small dents and creases from panels the last few weeks too to get them to a metal finished state if possible.
    14. #334
      Sep 2013
      sw Kansas
      I don't think I would ever get to metal finish with the skills I have right now. I don't have something like a shrinker disk. There are a lot of stretched areas.
    15. #335
      I'd be screwed I can't do a flat panel, which is what a round panel looks like when I'm done with it.
    16. #336
      Jun 2012
      Australia
      Flat panels are the worse and doing them right now. We are not talking low crown, but straight edge flat on the Willys Truck hoods I doing right now. And then I have to cut the two to make one wider longer one which will have 4 full length weld joints to metal finish perfectly flat! Will see it from the underside when it is up if I take any short cuts.
    17. #337
      Sep 2013
      sw Kansas
      I spent all day working on the rear fenders. I'm on the second coat of plastic. This isn't fun.
    18. #338
      Sep 2013
      sw Kansas
      I replaced the cracked passenger side window today. Then I went back to work on the rear fenders. It's almost 6 pm and they're starting to look like fenders. I intend to get them in primer still this weekend.
    19. #339
      Sep 2013
      sw Kansas
      This is the "mobile fender relocation device." My plan was to get them into primer today but there were too many spots that needed more work.
    20. #340
      Sep 2013
      sw Kansas
      Finally in primer.
