    Results 21 to 35 of 35
      Henderson, NV
      I also didn't see anything in this thead to indicate that DSE took back their early LCA's and corrected the clearance problem, although they may have.
      Woody stated that DSE took care of the problem and that this is only a problem with certain brake systems therefore not all the control arms would need to be recalled (which they would have if needed). Speedtech may or may not take care of the problem, but I'm a little weary when they start blaming the brake manufacturer for the problem as their initial solution. And it does sound like that was the final answer since he was going to modify them himself (NOTE: which was posted two business days after his initial post!).
      In order for either vendor to check clearance issues they would have to invest A LOT of money to get every single brake kit that someone might run. This is hot rodding, everyone has different setups and not every single avenue can be known every time. Hopefully vendors have a good idea of what they are up against and design accordingly, but in some rare instances things like this happen and the corrective action is to fix it as fast as possible and at no charge and maybe some incentive for the problem.
      I agree on the welds. Without any test data to back either one up as far as rigidity goes, comments are mearly opinions and not fact based.
      Some may or may not care if a company "copys" anothers products. In fact it could be considered an act of flattery, BUT looking at the products for those that do care its obvious ST products are byproducts of other vendors ideas and just makes you wonder how much actual thought, design, and engineering is behind their products and how much R&D was actually spent. For example look at their UCAs in the middle of DSE and GW arms. See any similarities.
      Or the offset shackles....Either way I don't think anyone here is "bashing" anyone just putting pieces of the puzzle together of things we do know.
      Shane Wagner
      1970 Chevelle "Cholula"
      2010 Camaro "Proven1"
