    Page 2 of 2 FirstFirst 1 2
    Results 21 to 35 of 35
    1. #21
      Henderson, NV
      I also didn't see anything in this thead to indicate that DSE took back their early LCA's and corrected the clearance problem, although they may have.
      Woody stated that DSE took care of the problem and that this is only a problem with certain brake systems therefore not all the control arms would need to be recalled (which they would have if needed). Speedtech may or may not take care of the problem, but I'm a little weary when they start blaming the brake manufacturer for the problem as their initial solution. And it does sound like that was the final answer since he was going to modify them himself (NOTE: which was posted two business days after his initial post!).
      In order for either vendor to check clearance issues they would have to invest A LOT of money to get every single brake kit that someone might run. This is hot rodding, everyone has different setups and not every single avenue can be known every time. Hopefully vendors have a good idea of what they are up against and design accordingly, but in some rare instances things like this happen and the corrective action is to fix it as fast as possible and at no charge and maybe some incentive for the problem.
      I agree on the welds. Without any test data to back either one up as far as rigidity goes, comments are mearly opinions and not fact based.
      Some may or may not care if a company "copys" anothers products. In fact it could be considered an act of flattery, BUT looking at the products for those that do care its obvious ST products are byproducts of other vendors ideas and just makes you wonder how much actual thought, design, and engineering is behind their products and how much R&D was actually spent. For example look at their UCAs in the middle of DSE and GW arms. See any similarities.
      Or the offset shackles....Either way I don't think anyone here is "bashing" anyone just putting pieces of the puzzle together of things we do know.
      Shane Wagner
      1970 Chevelle "Cholula"
      2010 Camaro "Proven1"
    2. #22
      Walla Walla, WA
      LOL, no I REALLY don't want to go back there again. However . . .
      Kyle fixed the subsequent DSE LCA's. On the basis of this thread, I don't know what happened to the LCAs Woody had because he changed brake systems to solve the problem. [Edit - I didn't see Woody's post on what DSE did to resolve the problem. And I agree, DSE's customer service is top notch.]
      As for the leaf spring hangers and the brake brackets, I just don't think there's a copying complaint available. The brake brackets are just obvious: I've got a set someone made out of steel; what Speed Tech is doing is much nicer and doesn't require machining of drum brake spindles, but is still pretty obvious. The same goes for the leaf spring hangers.
      I'm guesssing you weren't the first person ever to put a T56 in a first gen. Did you copy the cross member or hydralic MC bracket of the folks who did? Probably not because all of the dimensions are obvious from the car and parts themselves. Just like the brake brackets and spring hangers.
      As for the UCA's, I read and participated in the infamous Speed Tech UCA thread. I wasn't convinced then and I'm not convinced now that Speed Tech copied. But that said, why should I care if they WERE copied if the product works as advertised. All Speed Tech's copying does is create another source for parts at (perhaps) a lower price point.
      And that's my point. There is the product itself, which should (in my opinion) be evaluated on its own merits. Then there is the manufacturer. If the product works, but you don't like the manufacturer, then say that; but don't fault the product because you don't care for the manufacturer.
      I respect your knowledge and experience. My quibble is that some guy out there working on his car may spend more than he needs to for a particular part because he's afraid the Speed Tech parts are functionally inferior, when no one to date has proven they are and the only objective guy I've seen on this issue (David Pozzi) hasn't yet found any reason to criticize them that I'm aware of.
    3. #23
      Dec 2002
      Lost Wages, Nevada
      ...........Its like the blind........ leading the blind............
      If you dont do any R&D, then how do you know that you can get away with MIG welding the final product (to cut down on cost, obviously) not knowing if it is a strees point (FEA or distructive testing) that needs to be addressed. OBVIOUSLY ..... The two origniators did the R&D necessary to include TIG welding their respective products.
      I'll call it the way I see it.... and we KNOW what we've been seeing from a specific manufacturer, for quite some time now. Design and execution are the relevent factors here and this thread BLATANTLY shows the were certain products stand in this circle.
      If your gonna copy someting..... at least do it right.
    4. #24
      Mar 2003
      Boringville
      looks like the guys from ATS have some kind of personal problem with SPeedtech, funny that a company that doesn't offer any suspenion parts would care so much if speedtech copied. If they didnt' copy you, why are you guys so determined to prove them wroong? Didn't take any money out of your pockets? Not that i really care either way if speedtech copied
    5. #25
      Mar 2003
      Boringville
      BTW speedtechs are looks like a global west frame with a DSE crossshaft!
    6. #26
      Jan 2003
      Arizona
      No. I believe that one of the primary purposes of this forum is to save people from headaches--or worse--save them from harm.
      Case in point: I bought a Harley Davidson V-Rod back in 2003. After dropping $18,500 on something with only two wheels and no trunk, I opted for the cheapie $350 pipes (cause every Harley needs pipes).
      The pipes were junk. They practically fell off after 100 miles. Five days later, I discovered v-rodforums.com. Of course there were dozens of threads stating "DO NOT under any circumstances buy Samson pipes. If only I had found that forum earlier. True to form, Samson refused to take the pipes back, so I planted them in my backyard amidst the Hostas so that every morning, when I drink my coffee, I can be reminded not to get sucked into "too good to be true deals". As a manufacturer, I ordinarily keep my mouth shut, but when it comes to suspension and brake parts--safety parts, I'll speak up. Between the customer service, the brake clearance issue, and the new, expensive backspacing issue, I'd be pulling those arms.
      ________________
      Steve Chryssos
    7. #27
      La La Land, CA
      Quote Originally Posted by yody
      Cody-
      I, like yourself, call bull**** for what it is. DSE doesn't frequent the boards here, so they won' be in to defend themselves anytime soon. I feel that as manufacturers, we have the obligation to make good original parts that work like they are supposed to, for the best value we can to the end user.
      Speed-Tech is taking other manufacturers R&D, and making a copy-cat, sub standard part. I'll be the first to point out that this is the wrong way to go about it. No other company on this board, save for ATS, knows more about what each tubular control arm really does on a frame. GW and DSE did their homework on the arm, did FEA testing on them, and released a solid product to the market. The DSE design has special beveled washers and machining on the cross shaft that was put in because of a stress point that casued shaft breakage. ST did not incorparate this into their mimic version of DSE crossshaft for reasons unknown. I'd guess to say that they never did an FEA test of their product to see what will really happen under load. You want to save $200 bucks for an untested copied part? I'll pay the extra cash to make sure I'm safe in my car at speed, and on track days.
      You guys a say you don't care that they copied parts, but at least you aknowledge they they did.
      As soon as ST comes out with an original part that shows some of their own R&D was put into the product, I will evaluate the part for what it is.
      The Detroit Speeds and Global West's of the world are in no harm of being put of out business by guys like Speed Tech. Without the leaders and innovators that make the first part, they would have nothing to copy from.
      Tyler
    8. #28
      Aug 2003
      Prescott Valley, AZ
      Smartass comments like that tend to get many people turned off by forums. It isn’t the product itself that is being copied that is the issue it is the fact that a high quality company built a product with many hours of R&D to make sure it is dead on only to have another company take their product without any creativity of its own, lower the price and take a good portion of the profit away from those that truly deserve it. I trust that you do not own a business or have been in manufacturing at all to appreciate what has occurred. I on the other hand have and it is most disturbing. Unfortunately a Copyright can only go so far to protect the person who invented the product.
      I appreciate the guys on this board who give a damn and look out for us. That is what a forum of this quality is all about. I value the many years of experience that these members have on helping those who may only be 25 years old attain the expertise on products that someone may have no clue about and that could potentially harm him/herself. I look to those who have been there to help me when I need it the most. If a product has been developed that potentially could harm us why are you so insistent to silence the warnings?
      Liability is a huge overhead in the manufacturing world and that is why there are 500 companies offering the same friggin’ wheel. Have you ever noticed that those lesser known wheel companies tend to close their doors only after a short time after a product has been on the market?
      It's shake and bake!!! and i helped!
      Drewco Homes
    9. #29
      Walla Walla, WA
      Quote Originally Posted by chicane67
      Chicane: I'm not blind, and no one's leading me anywhere.
      So you're saying that GW and DSE made up a bunch of LCAs using MIG welds, tested them and determined that they weren't strong enough? Really? I'm sort of surprised by that because neither of them mentions TIG welding as an aspect of the STRENGTH of their product. DSE says on-line "The arms are then TIG welded in a fixture for accuracy and repeatablity of geometry." GW doesn't think it's important enough to even mention how their arms are welded in their on-line materials. If TIG welding is critical to a safe product, I know I'd mention that I do it and that it was important.
      I'm pretty sure I know who's blind here, and it's not me.
      Tito: You say "The DSE design has special beveled washers and machining on the cross shaft that was put in because of a stress point that casued shaft breakage." That may be, but GW says you can use their arms with the stock cross shaft. Is that bad or dangerous advice because the stock shaft doesn't have "special beveled washers and machining on the cross shaft that was put in because of a stress point that caused shaft breakage?" You and Chicane can say all you want about what DSE and GW did do and what you think ST didn't do, but the fact of the matter is that all of this stuff is probably MUCH stonger than the 37 year old stock pieces that a lot of us are still riding around on.
      Srteetfytr: You went on v-rodforums.com and read posts that reviewed the product, not panning the product because the manufacturer had copied someone else's design. That's all I'm asking for: is the product good, bad or a compromise?
      Harshman: David Pozzi says about the ST UCA "I'm going to try a pair of these arms on my 67 Camaro, they look like they will do what I want and the quality is great. The Global West and DSE are, of course, good products and improve geometry and alignment the same way, I recommend them too." Your point about the cost of doing the R&D is fair, and if that is reason enough for you not to buy the ST products, fair enough. I assume you also refuse to use generic drugs and only drive "Duryeas" - the first gasoline powered car in America. But don't start mixing in quality with copying - the two aren't related.
    10. #30
      Mar 2003
      Boringville
      ME??? smartass comment????? how dare you!
    11. #31
      Mar 2003
      Boringville
      BTW trust me i would listen to the ATS guys over Todd anyday! I just didn't see the need to be so passionate, also mkelcy makes some good points, I am interested to see the re-butt's. Also don't pull that weenie; "people get turned off of forums" card. If they didn't want any copies they should of got a copyright......
    12. #32
      Morrisdale, PA
      Guys, I did not want to start anything negative here. I've been around long enough to see that half of what is bought or manufactured out there needs some tweaking or repaired or replaced. I own a cabinet shop and do custom woodworking and stairway installs, trim new homes etc. I see products everyday that need customized, repaired or replaced before I can use them. That is part of life so I am not too excited about this. I just needed some good advice from people who know their stuff. I sent Todd two e-mails, he answered one. Has not answered the other yet. Did not offer to modify the arms or replace them. I did not ask him to do so. He is hard to get hold of, I agree. Took forever to get the arms, but they look super. If I had been on this forum longer I would have bought from DSE. But all in all, I am not mad about any of this. Just want to solve the problem and move on. I am going to cut away a small section of the skirt area under the ball joint and smile from ear to ear as the suspension gets finished up. Maybe this weekend. Thanks to everyone who offered advice and their opinions, I appreciate them all. It's super to have a place to ask a question like this and get so much help. Thanks again.
      Dave Smeal
    13. #33
      Jan 2003
      Arizona
      Good point Dave. I think your pix and comments tell the tale. We've all had two rounds at this. It's time to put the smackdown on yet another Speedtech thread.
      I, for one, am pissed because nobody commented on my nice Hostas.
      ________________
      Steve Chryssos
    14. #34
      Nov 2003
      Maine
      lol
      nice hostas steve
    15. #35
      Jun 2002
      Long Island, NY
      Speedtech debates all end up the same way-- Steevo's request is a good one. Thread closed.
