    Page 8 of 20 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 18 ... LastLast
    Results 141 to 160 of 381
    Thread: Half-Breed
    1. #141
      Nov 2010
      Wharton, Tx
      Awesome job so far. Subscribing to track progress.
    2. #142
      Nov 2011
      Killer fab work...love the ls too! I think the 70 is by far the best looking year out of them all.
    3. #143
      Aug 2012
      Pennsylvania
      Great work man!! I'm working on a 67 Fastback and cant wait til I finish the sheet metal work. Thanks again for the inspiration!!!
    4. #144
      Aug 2012
      Pennsylvania
      Subscribed!!
    5. #145
      May 2012
      Awesome build, I just read the entire thread. I wasnt sure if I was into it at the beginning, I am now!
    6. #146
      Jan 2010
      Long island NY
      Quote Originally Posted by Zachalanche View Post
      a little more on the door bars. they are tacked in place now, ready for final weld.
      Attachment 61818
      Looks good iam doing evo seats also. did you cut out the seat humps? Also are you using aftermarket seat brackets?
      70 Mustang fastback 428 sb
    7. #147
      Oct 2010
      SLC
      Quote Originally Posted by 1970 TT Rustang View Post
      I used the evo sliders, and just welded tabs on to line up with the mounting holes on the seat pans. I also welded the bolts on so the evo seat basically installs like the stock mustang seat did.
      Zach
    8. #148
      Zach awesome project! I like what your doing with it.
    9. #149
      Jan 2010
      Long island NY
    10. #150
      Oct 2010
      SLC
      Progress is slow as ever, but here's where things are at.
      Finished welding on the top of the cage and prepped everything for the new roof.
      New roof installed welding is about 1/3 done.
      Also mounted the computer
      Zach
    11. #151
      McKinney, TX
      Very cool build!
      89 Mustang "Box Wine"
    12. #152
      Aug 2012
      Pennsylvania
      Coming along well!!
    13. #153
      Jul 2010
      OREGON
      Nice work so far and congrats on the ls..
    14. #154
      Oct 2010
      SLC
      Thigs are really going slow now as I start to work through the details. I added hydraulic lines to the pedals. all 3 pedals are all one assembly now. this should speed up the final assembly of the car after paint. the lines on the engine compartment side connect where the old brake and clutch pushrods used to pass through the firewall.
      Zach
    15. #155
      Feb 2010
      What size wheels did you go with?
    16. #156
      Oct 2010
      SLC
      Quote Originally Posted by Griggsp51 View Post
      18X11 all the way around.
      Zach
    17. #157
      Oct 2010
      SLC
      correction, 18X11.5 all the way around.
      Zach
    18. #158
      Feb 2010
      Wow that's impressive to fit in the front
    19. #159
      Oct 2010
      SLC
      Yeah. the new steering geometry bought me a lot of room since it doesn't swing the wheel as far as the original suspension did. I will have to limit the rack and pinoin travel a little, because the rim does contact the lower a arm, even at that, I should still have a slightly better turning radius than a corvette (which isn't fantasic). if I need more turning radius I have some ideas for some modificatins I could make to the a arm to allow a little more steering.
      I also still need to flare the front fenders a little (similar to the rear). hopefully it all works when I'm done.
      Zach
    20. #160
      Oct 2010
      SLC
      A few more updates:
      started working on the bracing that goes between the cage and the body. here are the A-pillars.
Size:  138.8 KBName:  DSC02214.jpg
      been trying to clean the garage a little, so the hood ended up back on the car. not really productive progress, but seeing the car with all its body parts was motivating.
      Starting to think about the venting on the front of the car. I'm trying to make the side vents line up the way the up curve on a boss stripe would, so I can disguise it a little, while still having a large opening to remove air from under the fenders.
      ......and here's the car as it currently sits. Still in mockup phase, so like I have said a few times already, it all has to be disassembled.
      Zach
