    Page 6 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 16 ... LastLast
    Results 101 to 120 of 325
    1. #101
      Feb 2011
      dallas, tx
      we moved into a new house a couple weeks ago and im bringing the car home for alittle then back to the shop to finish it up.
      Past couple days we have installed the quarter windows, door glass, wing window, the the trim with the windows mentioned, front spoiler mounted up, mocked up the front calipers, spoiler and narrowed the seats down for the quadralink and mini tub.
      Next up this week before it comes home is to install door panels, mock up gauges, turn signal lenses, align front bucket headlights, door locks, and and dynamat the doors
    2. #102
      Feb 2011
      dallas, tx
      heres an idea on how the trim around the window painted black looks. I love it. Im not sure how well it will withstand scratches but ill deal with that later
    3. #103
      Feb 2011
      dallas, tx
      dynaliner installed on the panel. The inside of the door is dynamated. I used one sheet for the door. I didnt feel the need to cover the entire inside of the door. Dynamat is a vibration dampener so this should do. You can tell a difference already just knocking on the door
    4. #104
      Feb 2011
      dallas, tx
      Heres a short video of the dynamat door Vs non dynamat fender. Its hard to tell in the video but in person OMG there is a huge difference. As far as the dynamat goes i did not cover the entire inside of the door. I cut each sheet in 4" strips and installed it that way leaving a little gap between each sheet. I was able to use one sheet of dynamat per door even adding some on the sides and the front of the door.
    5. #105
      Feb 2011
      dallas, tx
      need some help.
      So i have the passanger side windows to my liking. The problem is the drivers side wing window. I think it sits alittle too low. There is a screw on the inside of the door, bolt on the top right, and bolt on the side if you are looking at it. Now i can take the screw out and pull the window up and tighten the bolts to where i like it but i cant get the screw back in. So i tried the opposite first. Install the screw and then pull the window up. Problem is i cant seem to get enough adjustment this way like i did with the screw out.
      Does anyone have a picture or a idea what this screw actually does? I can start the screw but it doesnt seem to go in the correct path. Any help would be great
    6. #106
      Aug 2003
      Byhalia, MS
      Is this an original to the car GM door or a repop door?
    7. #107
      Feb 2011
      dallas, tx
      sames stuff as before. Im wondering if it was always hanging alittle low. I think i need to drill out the vent window clip since thats whats hitting.
    8. #108
      Feb 2011
      dallas, tx
      so I'm currently installing my american auto wire kit. The kit states that i need to cut out the fuse box area so the new fuse box can fix. Now its saying to align the right side of the template to the right side of the edge of the current firewall fuse box hole. Now if i do that it gets really close to another hole on the left side of the fuse box.
      My question is why not just split the difference from left and right instead of cutting all to the left of the hole? Less cutting or clearance issues? Im going to guess less cutting
    9. #109
      May 2009
      Minnesota
      On my 1968 Firebird I has clearance problems with the parking brake. Make sure to have the cable in place and check for clearance. If your even running the stock set up.
    10. #110
      Feb 2011
      dallas, tx
      I feel like I have 3/4 of the cutout to the left of the hole and 1/4 of the cutout to the right. I doubt that should cause clearance issues. If it does i guess ill have to go to a handle Ebrake setup. Anyone have any pic of the fuse box installed from the firewall view?
    11. #111
      May 2009
      Minnesota
      Not a great picture and I guess it was not the parking break cable. It was the emergency light switch that was in the way.
    12. #112
      Feb 2011
      dallas, tx
      By looking at a 68-69 fuse box it does look like i need to do all the cutting to the left. Solves that issue.
      Side note i did install my doom light, sun visors, and pillar pods. I also picked up some kick panels and door sills.
    13. #113
      Aug 2006
      austin
      Quote Originally Posted by icemanrd19 View Post
      I put cheerful lights in my car. That's just the way I am
      Greg
      1976 Trans Am SacrilEdge
      twin turbo 455
      Ttops and 4spd
      one of 110 made
      https://www.pro-touring.com/showthre...ect&highlight=
      https://www.pro-touring.com/showthre...ilEdge-is-free!
    14. #114
      Feb 2011
      dallas, tx
      hahahahahahah. thats actually funny. Im currently also looking for a air compressor for my garage
    15. #115
      Maryville, TN
      Dude, this thing is awesome! Can't wait to see it progress.
      A.K.A: That bald guy
      Find me on Facebook or my personal website.
      - 67 Camaro: Current Project Car
    16. #116
      Aug 2008
      Iowa
      agreed! Need a new update.
    17. #117
      Feb 2011
      dallas, tx
      Should be taking it to get the headliner installed within two weeks and then ill complete all the wiring
      In the meantime I'm looking for
      PRC radiator for a ls with dual spal fans
      Dse rear quadralink tow hooks
      Black leather racing seats. Corbeau gts II or recaro ls seats. Any opinions?
      Parking brake assembly
      Looking to buy 3 of these items. Tow hooks and two other big items asap
    18. #118
      Dec 2012
      Love my GTII's !!
      Build it right ... 'The 2nd Time !!'
      69' SS/RS X11 PRO-TOURING E-Force LS7 - SOLD
      2 Custom FJ40's -SOLD
      77' 911 Hotrod - SOLD
      'Killer Piggy' 73 FJ55
      67 Camaro - TBD
    19. #119
      Dec 2012
      Question ... with the dynaliner on the door panel, will this reduce any inner door 'vibration' noises coming into the car ? I just can't seem to make these go away and they're driving me %&&^(&^&^80 !!
      Steve
      67 Camaro - TBD
    20. #120
      Feb 2011
      dallas, tx
      Quote Originally Posted by sheck44 View Post
      Steve
      Yes the dynaliner will help a lot. instead of metal touching cardboard its touching foam. I dynamat the door itself too. The dynaliner made the door panels much stronger but the dynamat is what is going to keep the vibrations down. I put 3 inch strips on the inner part of the door with a inch separation. The part of the door that the panel attaches too i put dynamat on the window side of that anywhere that the panel as a indent in. Its hard to describe. I didn't want a solid piece of dynamat covering my enter door where the panel connects too and have to take it off if i need to mess with the window or something
