    Page 1 of 17 1 2 3 4 5 6 11 ... LastLast
    Results 1 to 20 of 325
      Feb 2011
      dallas, tx
      icemanrd19 67 camaro
      Well about 3 or 4 months ago i bought a 1967 Camaro from a guy in fort worth. Well Replacing a few nuts and bolts led me to ripping alot of the car apart. Currently the car is sitting apart and im trying to figure out what direction i want to take it.
      THis was my old project but ive grown up now to bigger meaner toys
      [/QUOTE]
      Updated parts list
      Exterior
      2002 plymouth prowler orange
      Marquez billet taillights P/N 103-bc
      DSE selecta - speed wiper kit P/N 121001 wired into stock fuse box
      Ringbrothers black air frame 20679-1032 hood hinges
      Stock hood latch painted black
      Forgeline rims 18x9.5 and 18x11 polished outers titanium smoked centers, Fronts 28.58 offset, hub 70.3, rears 25.4 offfset and 70.3 hub
      315/30/18 and 275/35/18 michelin ps2 tires
      Dse mini tubbed
      Dse subframe connectors
      ridetech billet gas cap
      RS lower valance with new lights tinted black
      Stock 68 camaro mirrors mr-27 and mr-26. First hole is drilled 1 inch up and 8 inches back on the door
      68 camaro rs kit with Retro - Electro PN-002 RS Electronic Headlight kit
      New rear quarters, trunk, tailpan, hood, roof, floor, dash, and radiator support
      New door handle kit part # dw-60p
      New rear bumper
      Smoothed firewall
      aluminum hood strikers
      Suspension and Brakes
      2012 corvette z06 6 piston calipers with 6 puck pads and 4 piston rear calipers with stock rotors
      Kore 3 rear parking brake kit1988-1995 corvette rear ebrake cables ac delco part number 19143763
      67 camaro big block intermediate cable pbk-11r
      front cable pbk-10a, New e-brake, Drill out the kore 3 bracket to 9/16"
      Hydroboost unit with wilwood Master cylinder street quality P/N 2021-STP
      Dse front subframe P/N 032006
      Dse rear quadralink P/n DS-041703 with ridetech single adjustable shocks
      ford 9" moser custom alloy 31 spline axle shafts torino flanged OD 6.9 or less/ press on bearings
      1/2"-20x 3.00" studs press in GM 5 of 4 3/4 bolt circle, 1/2" pinion offset
      "f" measurement 25.375?""g" measurement 24.375" Total axle width 54/750 axle flange to axle flange
      moser 9" ford complete 3rd member Truetrack 31 spline Diff n-case daytona aluminum pinion support 1350 yoke w/u-bolt 4.11 gear ratio
      Wilwood proportioning valve 260-11179, wilwood master cylinder and hydroboost
      Chassisworks tunel kit P/N 5922-f10
      Dse aluminum body bushings
      Interior
      Eddie motorsports black steering wheel launch MS140-54BK
      Morris Classic concepts 3 point setbelts
      American autowire kit
      Dynalined and Dynamat entire metal part of the car
      Rear sony 6x9s using the speaker covers as a spacer
      Kick panels with speakers
      New stock 67 dome light
      New stock 67 rearview mirror
      69 camaro rear quarter outer felts with the flag
      TMI one piece suede headliner
      recaro seats with suede middle inserts
      County prison white shift knob P/N sk502-cpbk-6rur on a Finch 6" shifter P/N 7000461-n
      Vintage air unit with modified DSE vintage air bracket P/N 011006
      dw-20 door mechanisms
      cpt-07p fisher logo sill plates
      bm-1048 quarter glass vertical moldings
      dw-27 window cranks
      ws-09 u-jamb seats
      gb-16 glove box door bumper set
      rsp-11bk black mesh package tray
      DJ-100 windsock end caps
      Engine
      vaporworx fuel tank with notched corners with 2012 camaro fuel pump
      T56 reverse lockout from wire barn t56-CON
      Billet specialties 77109 overflow tank
      PRC dual pass radiator 211001 and spal fan setup
      ls3 480hp rated at 495 with hotcam
      t56 magnum/ ls7 clutch
      Afco dynatech 2.5 exhaust 793-91125
      Holley black fuel rails p?n 534-209
      Finch performance gas/diff dual vent system
      Kwik Performance P/N k10143 air conditioner bracket kit
      autocraft oil pan
      Corvette accessories 19257325
      Elite Engineering Catch can CC-200B
      PCM of NC p-150028 A/C fan speed bump circuit and PCM of NC Hi/Lo speed Fan Kit
      DSE battery relocation kit
      stainless works headers part number ca679wd 1.75 primaries and 3" slip fit collectors
      dse motor mounts 060401
      ws-18 cowl hood to vent seal
      ws-47 cowl vent wedges
      Part # ws-05 trunk weatherstrip
      Part # ws-19 67 OEM window felt set
      lic-15 license plate bumper set
      Feb 2011
      dallas, tx
      opinions on either the G-link or dse 4 link? This car isnt going to be tracked its just going to be a nice hot fun car. Im comparing value too.
      Feb 2011
      dallas, tx
      Just ripped the entire interior out. Will be going in on weds to talk to rod at rods car craft and hopfully soon get the car media blasted to see how much work is needed.
      Aug 2006
      S.W. Florida
      Gbar ,mini tub, 3rd gen iroc or z28 gear box
      Start with the suspension and undercarage. Move to the engine bay then to the dash and painting of the interior then body work
      68 Camaro TT LSX 427 "Golem" / click the link
      https://www.pro-touring.com/threads/...ighlight=golem
      sponsored by
      www.FactoryFinishPDR.com
      Feb 2011
      dallas, tx
      Im trying to do this without going back and redoing something over again. I want to get my car set up so when im ready to install the lsx and t 56 it will be ready to bolt in. Im nervous to see what the body work is going to cost me :(
      nice project!
      Feb 2011
      dallas, tx
      I just dropped off the deposit and my car will start being rebuilt in two weeks.
      My question is should i swap a ls1 or ls2 motor in the car? I will be putting a t-56 transmission in it. What is the best lsx motor to swap in this car with the least amount of work and why?
      alpine ca
      at least give Blake and Roger a call at speedtech and check into there torque arm set up you wont be disappointed
      http://www.speedtechperformance.com/
      john
      BUILD LINK
      Feb 2011
      dallas, tx
      BYE BYE car :( waiting to see what the damage is after the car gets blasted.
      Feb 2011
      dallas, tx
      Dec 2009
      Hey Ice - congrats man. Looks like you took 'tear it down and redo it' route. Takes guts but in the end you'll have a great car built exactly to your specs. Good luck and follow your heart (read: welcome to the club and watch your checkbook). Keep us posted...
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Feb 2011
      dallas, tx
      Thank you for the advice.
      Check out rods website of his other cars. www.rodscarcraft.com
      Feb 2011
      dallas, tx
      My car will be painted house of kolor kandy tangerine. This took about 10min so you guys could get an idea. Im thinking about either having my taillights like this by painting part of the chrome and tinting the tail light lens or leaving the outer shell all chrome and tinting the tail light lens. What are your opinions? Im starting to lean towards leaving the entire casing chrome and only tinting the tail light lens.
      Keep in mind i will be tinting my windows 20% and blacking out the vertical trim on the window and 1/4 glass so it almost looks like one solid window like this
      and my headlights are a rs headlights with black in the middle and chrome ring trim too. Sorta sticking with that theme. like this picture
      Charlotte
      I see my pic from Autofair here in that last one...
      I prefer the RS/hide away head lamps as well.
      2014 Chevy SS LS3 / 4 Door
      alpine ca
      going to look great like the side window deal
      john
      BUILD LINK
      Feb 2011
      dallas, tx
      Guess its time for a update.
      DSE quadralink and ford 9" installed.
      DSE subframe connectors installed
      Tires are here
      rear quarters, roof, complete floor, firewall, and alot of other sheet metal replaced
      IM sure there are a ton of other things im missing
      Feb 2011
      dallas, tx
      so time has come to buy some more parts. What is the best narrowed fuel tank for my ls2 and quadralink setup? Pros and cons of each.
      Im also looking for the best deal on billet fuel cap and billet tail lights. I would love to buy it all from one vendor
      Feb 2011
      dallas, tx
      Sorry guys i havent been on in a long time. Body wise the car is ready to go. Just needs paint. I just ordered this subframe yesterday. unfortunately this took a huge chuck of change and progress will be going much slower now. Not to mention my wife told me 3 weeks ago we are expecting out first child.
      another thing i just bought was my tank
      new camaro fuel pump, notched corners, and good for plenty of HP
      Feb 2011
      dallas, tx
      Will post pictures whenever i get all of my goodies instead of internet pictures. THank you matt at MCB.
      Im going to have to hold off for awhile buying any major parts since i just spent alot and we have a child on the way. I plan on bringing the car back to my house so i can work on it myself. Major body work is done. My question is we still have to prime it, paint it and assemble and i need progress to go much slower now so i can save money. At what point sould i have my builder get the car too so that i can start putting parts on whenever i have extra time and money? Should i have him just prime it, paint underneath and the firewall, or what? I dont really want him painting the door jams or the firewall until i completely put the car together so that i know for sure that everything that i want to add is done and fits. I dont want any cutting on any areas already painted.
      Im just looking for some overall advice.
      May 2011
      Central FL
      Congrats on your first child! Was enjoying the build, but we know what's coming... (a long break between now and when you can get back to working on the '67).
      - David
      1967 Camaro - In remembrance of my friend Scott
