    Results 121 to 140 of 325
      Feb 2011
      dallas, tx
      icemanrd19 67 camaro
      Well about 3 or 4 months ago i bought a 1967 Camaro from a guy in fort worth. Well Replacing a few nuts and bolts led me to ripping alot of the car apart. Currently the car is sitting apart and im trying to figure out what direction i want to take it.
      THis was my old project but ive grown up now to bigger meaner toys
      [/QUOTE]
      Updated parts list
      Exterior
      2002 plymouth prowler orange
      Marquez billet taillights P/N 103-bc
      DSE selecta - speed wiper kit P/N 121001 wired into stock fuse box
      Ringbrothers black air frame 20679-1032 hood hinges
      Stock hood latch painted black
      Forgeline rims 18x9.5 and 18x11 polished outers titanium smoked centers, Fronts 28.58 offset, hub 70.3, rears 25.4 offfset and 70.3 hub
      315/30/18 and 275/35/18 michelin ps2 tires
      Dse mini tubbed
      Dse subframe connectors
      ridetech billet gas cap
      RS lower valance with new lights tinted black
      Stock 68 camaro mirrors mr-27 and mr-26. First hole is drilled 1 inch up and 8 inches back on the door
      68 camaro rs kit with Retro - Electro PN-002 RS Electronic Headlight kit
      New rear quarters, trunk, tailpan, hood, roof, floor, dash, and radiator support
      New door handle kit part # dw-60p
      New rear bumper
      Smoothed firewall
      aluminum hood strikers
      Suspension and Brakes
      2012 corvette z06 6 piston calipers with 6 puck pads and 4 piston rear calipers with stock rotors
      Kore 3 rear parking brake kit1988-1995 corvette rear ebrake cables ac delco part number 19143763
      67 camaro big block intermediate cable pbk-11r
      front cable pbk-10a, New e-brake, Drill out the kore 3 bracket to 9/16"
      Hydroboost unit with wilwood Master cylinder street quality P/N 2021-STP
      Dse front subframe P/N 032006
      Dse rear quadralink P/n DS-041703 with ridetech single adjustable shocks
      ford 9" moser custom alloy 31 spline axle shafts torino flanged OD 6.9 or less/ press on bearings
      1/2"-20x 3.00" studs press in GM 5 of 4 3/4 bolt circle, 1/2" pinion offset
      "f" measurement 25.375?""g" measurement 24.375" Total axle width 54/750 axle flange to axle flange
      moser 9" ford complete 3rd member Truetrack 31 spline Diff n-case daytona aluminum pinion support 1350 yoke w/u-bolt 4.11 gear ratio
      Wilwood proportioning valve 260-11179, wilwood master cylinder and hydroboost
      Chassisworks tunel kit P/N 5922-f10
      Dse aluminum body bushings
      Interior
      Eddie motorsports black steering wheel launch MS140-54BK
      Morris Classic concepts 3 point setbelts
      American autowire kit
      Dynalined and Dynamat entire metal part of the car
      Rear sony 6x9s using the speaker covers as a spacer
      Kick panels with speakers
      New stock 67 dome light
      New stock 67 rearview mirror
      69 camaro rear quarter outer felts with the flag
      TMI one piece suede headliner
      recaro seats with suede middle inserts
      County prison white shift knob P/N sk502-cpbk-6rur on a Finch 6" shifter P/N 7000461-n
      Vintage air unit with modified DSE vintage air bracket P/N 011006
      dw-20 door mechanisms
      cpt-07p fisher logo sill plates
      bm-1048 quarter glass vertical moldings
      dw-27 window cranks
      ws-09 u-jamb seats
      gb-16 glove box door bumper set
      rsp-11bk black mesh package tray
      DJ-100 windsock end caps
      Engine
      vaporworx fuel tank with notched corners with 2012 camaro fuel pump
      T56 reverse lockout from wire barn t56-CON
      Billet specialties 77109 overflow tank
      PRC dual pass radiator 211001 and spal fan setup
      ls3 480hp rated at 495 with hotcam
      t56 magnum/ ls7 clutch
      Afco dynatech 2.5 exhaust 793-91125
      Holley black fuel rails p?n 534-209
      Finch performance gas/diff dual vent system
      Kwik Performance P/N k10143 air conditioner bracket kit
      autocraft oil pan
      Corvette accessories 19257325
      Elite Engineering Catch can CC-200B
      PCM of NC p-150028 A/C fan speed bump circuit and PCM of NC Hi/Lo speed Fan Kit
      DSE battery relocation kit
      stainless works headers part number ca679wd 1.75 primaries and 3" slip fit collectors
      dse motor mounts 060401
      ws-18 cowl hood to vent seal
      ws-47 cowl vent wedges
      Part # ws-05 trunk weatherstrip
      Part # ws-19 67 OEM window felt set
      lic-15 license plate bumper set
