    Page 14 of 32 FirstFirst ... 4 9 10 11 12 13 14 15 16 17 18 19 24 ... LastLast
    Results 261 to 280 of 633
    1. #261
      Aug 2002
      Sweden
      Country Flag: Sweden
      Quote Originally Posted by omiotek View Post
      If those are your welds on speed hunters show some more pics they look amazing. Great build
      I drooled over those welds too. And no, they're not mine...
    2. #262
      Aug 2002
      Sweden
      Did you build some camber into the spindles?
      How will you change the alignment?
      When you post pictures, can you size them bigger, maybe 1000 pixels wide? I think most people have high res monitors these days and the detail would be appreciated. :-)
      Camber and caster will be adjustable with shims. Caster by shimming upper or lower A-arm back or forth.
      For camber, look at the upper spindle joint. It's mounted in a aluminum block inside the upright. This is set at 1,5° camber for the moment. From start, I was going to make this thinner and pack up with shims, but right now it's needs to be milled if I want more or less camber.
      The upright has 4° caster built into it. Another -2 - +6 caster is available by shimming. So a total of 2-10° caster.
      default camber is 1.5°. I think I could between 1-4° camber after milling the aluminum block.
      I like shims - they're predefined and it's easy to change the same amount on both sides.
      As for picture size - I'm using the pictures from my blog. For some reason, wordpress-blogs are still scaled 600 pixels wide, and full size is 1500 pixels.
      If that works, I can link those pics instead?
    3. #263
      Aug 2002
      Sweden
      Looks like there's some kind of auto scaling in this forum, so it should be possible to link the large images instead.
      Or is the pic outside the frame in your browser?
      Quote Originally Posted by Nicks67GTO View Post
      Awesome talent and great vision. One of the neatest all around builds iv'e seen on this site or anywhere for that matter. I'm really looking forward to the finished product!
      Thanks!
    4. #264
      Jul 2013
      Wow, this car is going to inspire a ton of other projects including mine. Not because of the car itself, but the workmanship behind it.
      T
    5. #265
      Aug 2002
      Sweden
    6. #266
      The Netherlands
      Country Flag: Netherlands
      way to go Anders!! again a milestone :-)
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
    7. #267
      Aug 2002
      Sweden
      Thanks Martin,
      Yes, it's a great success to finally have it down on wheels.
      I'll post some more pics within the next weeks. The garage is so small that it's impossible to get a full view picture inside it. Must roll it outside...
    8. #268
      Looking forward to more pictures!
    9. #269
      Florida
      Anders, you've come a long way with the car in the past 5 years. Your engineering, machining, and fabrication skills are impressive! Like the others, I'll keep watching and enjoying your updates.
    10. #270
      Dec 2012
      Boise, Idaho
      I follow your build on FaceBook too. This is such and engineering marvel. So impressed. Keep it up Anders.
      Toby D.
      IronDougal racing
      I race Me, Myself, and Iron.
      https://www.pro-touring.com/showthre...-1973-Trans-Am
      FaceBookME
    11. #271
      Jun 2011
      Ohio
      Looking forward to more pics,this car is awesome!!!!!
    12. #272
      Apr 2014
      Cool ass Firebird! and another build with a Pontiac motor! awesome!
      good luck with build!
      Pat
    13. #273
      Aug 2002
      Sweden
    14. #274
      FRANCE
      Country Flag: France
      Awesome ! Love it !
      Gil
    15. #275
      Mar 2013
      Las Vegas
      This is one of the best builds ever. And it is a true build....not a bolting on of parts. You have some serious skill.
      69 Camaro - LS7 441ci ;wet sump, Custom cam, Port matched MSD intake, ported 90mm TB, Texas Speed PRC 285cc LS7 heads withBTR rockers. Tick built T56. Scott Mock subframe, TCI torque arm rear setup, C6 Z06 brakes, built ford 9" 3.73 gears, Trueforged 3pc Wheels. Lots more
    16. #276
      Aug 2002
      Sweden
      Thanks guys! Really great to read all the comments here!
      Will try to post some more pics of it tonight or tomorrow.
    17. #277
      Aug 2002
      Sweden
    18. #278
      FRANCE
      Pure sex, only one picture at a time please, I'm too old...
      Awesome work!
      Gil
    19. #279
      Mar 2015
      FL
      Amazing. Never seen this level of fab by an enthusiast. On top of that I've never even seen the type of suspension you are using (front and rear). Can't wait to see this thing hit Nurburgring!!!
      What do you think it will weigh? I remember you said 2500 lbs, but i will believe that when i see it. If you get near 3000 you're doing very well. If you get to 2500 lbs I think my head will explode. But if you get below 3000 I will be very impressed.
      Still can't believe you moved the engine back 8"!! YES!! Think you'll get 50:50 weight distribution?
      And another thing. Love that you're doing it with a Firebird! PONTIAC yes!! What are the plans for the engine?
      -Mitch
      G8 GXP, White Hot, Auto, bone stock
      68 Firebird, 428 Pontiac, CNC'd KRE Al d-ports, hyd roller, EFI, TKO600, TCI Eng complete chassis, Ridetech, Kore3 C6Z brakes, C5Z 18" with 315 rivals x4, C6zr1 mufflers
      RRR, NASA HPDE https://youtu.be/DPp1l9-FuNE
    20. #280
      Atlanta GA
