    Page 4 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
    Results 61 to 80 of 210
    1. #61
      Apr 2004
      OKC, OK
      Quote Originally Posted by Steve1968LS2 View Post
      I don't see why you couldn't.. I was more curious about the service issue (ie, direct replacement pump) and if there was a cheap GM pump with a higher output.
      The Racetronix pump is nice, I wonder if they would know?
      The pump is a GM truck unit, not sure which one.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
    2. #62
      Newbury Park, CA
      A Walboro 255lph should be easily adaptable. But if Spectre says it's a 190lph that would be perfect. No need to heat up the fuel more than necessary.
      Perhaps Spectre would supply a replacement AC Delco number for the pump? Everyone in the AM deals with AC Delco or Federal Mogul P/N's.
    3. #63
      Apr 2004
      OKC, OK
      Nope, they won't, I have tried.
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
    4. #64
      Jul 2003
      Anaheim Hills, CA
      The pump is numbered, there should be some way to figure out which GM pump it is.
      Would be nice to know what's needed for a replacement.
      1968 Track Rat Camaro:
    5. #65
      Newbury Park, CA
      Time to make nice-nice with your local AC Delco rep Steve.....
    6. #66
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by MuscleRodz View Post
      What are they suggesting for replacement parts? Are they selling pumps separately?
      Scott from NJ.
      Vent Windows Forever! ...
    7. #67
      That pump looks like the same one Rick's told me to use when my pump died. Once I got mine out it turned out I had a Walbro pump but apparently Rick's is now using the GM pumps. The pump they told me to use cross referenced to a Delphi FE0114 pump that I picked up at Oreilly's. It was from a 96 1500 pickup with a 305.
    8. #68
      Apr 2004
      OKC, OK
      Quote Originally Posted by BonzoHansen View Post
      Not yet, pumps right now will have to be sourced from your local parts store, or other aftermarket source
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
    9. #69
      Jul 2003
      Anaheim Hills, CA
      Really? I would expect a Ricks tank to have a nicer pump like a Walbro or Bosche.
      This darn pump has numbers on it but I can't identify them. I guess I need to find a place that stocks them and visually compare the numbers on the casing...
    10. #70
      Aug 2005
      Hamilton, NJ
      Jeff Tate is a GM parts guy, get him in here...
      Scott from NJ.
    11. #71
      [quote=Steve1968LS2;489591]Really? I would expect a Ricks tank to have a nicer pump like a Walbro or Bosche.
      quote]
      Mine does have a Walbro but it sounded like they changed over to the GM pump at some point because that is what he assumed I had in mine.
      I did some more digging and this is the AC Delco part number that Rick's gave me: EP381
    12. #72
      North Bend, WA
      Would one of these likely fit on a '67 Camaro with DSE mini-tubs and a G-Bar?
      I'm going EFI.
      I have a GM NOS tank that looks like it will fit with my combo, but then again, I don't have wheels and tires yet, and don't have exhaust pieces to mock up.
    13. #73
      Jul 2001
      Detroit, Michigan
      What is a G-Bar?
      If you're minus the leaf springs than yes the tank will fit. If you mini-tubbed but did the offset shackles for the leafs, then no.
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
    14. #74
      North Bend, WA
      G-Bar = 4 link suspension system courtesy of ridetech and Chris Alston.
    15. #75
      Apr 2004
      OKC, OK
      Quote Originally Posted by Turbo67camaro View Post
      I'm going EFI.
      What width rear tire are you running? Should clear with 315's, not sure with 335's.
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
    16. #76
      California
      Quote Originally Posted by 69LT1Nova View Post
      Now if they would just make FI tanks for X body cars...
      If they fit 1st gen Camaros, why wouldn't they fit X bodies?
      Matt
    17. #77
      Apr 2004
      OKC, OK
      Quote Originally Posted by DarkoNova View Post
      Matt
      Filler neck is different for one.
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
    18. #78
      North Bend, WA
      Fit for G-bar w/ mini tub
      I doubt I'll go wider than 315s on tires due to the $ premium required to get there for wheels, tires, narrowed tank...just another consideration for my pending wheel and tire choice.
      Thanks,
      Mike
    19. #79
      Jun 2006
      Katy,TX
      So early 65-67 GTOs different than Chevelles?
    20. #80
      Apr 2004
      OKC, OK
      Quote Originally Posted by Skip Fix View Post
      Yes, but EFI tanks are available for both. we sold both
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
