    Page 7 of 11 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 LastLast
    Results 121 to 140 of 210
    1. #121
      Apr 2004
      OKC, OK
      Quote Originally Posted by SSable View Post
      Does any know the line sizes coming off the spectra tank 3/8? 5/16?
      Feed is a 3/8" line with SAE 45* flare. Return is 5/16"
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
    2. #122
      Mantorville, MN
      I'm not finding a part number anywhere for a 68-69 tank... Mike, your site lists GM37BFI as 64-69, but I don't think that's right (maybe I'm wrong on that???)
      Derek Kiefer,
      Mantorville, MN
    3. #123
      Mantorville, MN
      Quote Originally Posted by Derek69SS View Post
      Anyone? Anyone?
      69 Chevelle tank...
      Derek Kiefer,
      Mantorville, MN
    4. #124
      Feb 2007
      Tinley Park, IL
      Quote Originally Posted by MuscleRodz View Post
      I would not recommend it. Very good chance of burning up the pump depending on the regulator used. I would stick with a stock tank until ready for efi conversion. Plus stock tanks are cheap. Spectra has those too.
      What is the correct regulator that would be needed to run this with a carb?
      Nick ~
      1969 Cutlass
    5. #125
      Jan 2007
      SOCAL
      Does anyone have the part number for the Corvette regulartor quick disconnect ? Also, where do you place the regulator? Where is the corvette regulator located?
    6. #126
      Feb 2007
      Tinley Park, IL
      Quote Originally Posted by Mr Nick View Post
      Possibly this? The notes even say its for an EFI pump, but running a carb.
      http://store.summitracing.com/partde...5&autoview=sku
      or this
      The Aeromotive product comes with 2 different springs, so I could keep the same regulator when I do switch to EFI.
      Nick ~
      1969 Cutlass
    7. #127
      AutoX
      FWIW,
      I am running this tank and found out last weekend the limits of the baffle. With R compound tires on the autocross track you are looking at fuel starvation at anything less than 1/2 tank of gas. Above 1/2 tank if you are a smooth driver you should be OK.
      Also in mine at least i have never gotten the fuel gauge to work properly, it has the problem that someone here predicted...it reports full for a very long time, presumably due to the baffle holding the fuel level indicator artificially high with the flow from the return line. At 1/2 tank of gas by volume, mine still reads ~90% full.
      Still, for the price, a very nice tank and pump. I have about a 400 HP small block, pump is plenty strong enough for me.
      I am thinking about putting some foam in to decrease the sloshing...any opinions?
      Paul
    8. #128
      Well here is my experience with the spectra premium gm32afi. I bought one from RockAuto for 460.00 shipped. I scuffed and painted the tank not expecting any problems. After I installed it and put 1/2 tank of full in it I first found the fuel sender was not working. I heard the pump running but would not pressurize the fuel system. No matter what I did it would just run but would not push fuel. So I called RockAuto and the would send a replacement right away but I had to send the whole tank that I just painted back. Got my replacement within 3 days. This time I tested everything before doing any painting. Good. I again painted the tank and everything seemed fine. Car fired right up. Noticed the fuel gauge would go past the full mark when I filled up, no problem. So I went on a spring cruise and the car ran great till I ran out of fuel cause the gauge would not read below 3/4 ! Now I have to ttry to get another replacement! Anyone have sending unit problems?
    9. #129
      san diego
      is the sending unit and gauge matched? for example are they both for chevys 0-90ohm? sounds like the sender is a ford.
    10. #130
      Falcon65, The fuel gauge is a 0-90 ohm Autometer. The fuel sender is 0-105 ohm. I did get it figured out. The problem is in the design of the tank I beleive. The in tank pump and level sender sits in a bowl that being filled with fuel returning in the same spot.
    11. #131
      san diego
      im glad you got it figured out, thats is a bummer that it is designed poorly. maybe some foam will help to reduce return interference?
    12. #132
      Nov 2007
      Its not interference, the baffle area stays full with fuel and the float for the sender is in that area, not outside the baffle so the float is up all the time. They should have modified the sender arm so it sat outside the baffle area. Not as well designed as a GM sender from the 4th gen f-body
    13. #133
      Plantation, FL
      Are these tanks avalible for the 68-72 Novas?
      flgc
    14. #134
      Apr 2004
      OKC, OK
      Quote Originally Posted by NovaMan View Post
      flgc
      nope
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
    15. #135
      May 2009
      Baton Rouge
      I got one of these Spectre tanks from Rock auto about the same time and just got it installed last week. Mine wouldnt pump fuel either, but i could hear the pump running. So i pulled the sending unit then the pump itself. I put the pump in water (to prevent a fire) and jumped wires to it (correct polarity) and low and behold it shot water about 8 inches. Next step was to check the polarity with a multimeter on the plug and sure enough, the 4 prong connector (grey) under the sending unit assy, had the wires crossed for the pump. THis caused it to spin backwards and not pump fuel. I pulled the lock out of the plug and pushed the pins out with a paper clip and corrected the polarity. Verified the sending unit polarity also. It was ok, so perhaps the person wiring these units had a bad day or few days and obviously these units arent tested before shipping. So after wasting a couple of hours troubleshooting the thing, flushing the pump and lines, the fuel pressure hit 58 psi and fired right up.
      As far as your sending unit problem, pull the sending unit/pump assy and hook your meter to the sending unit wire (purple) and ground. Move the float assy up and down and measure the ohms. Also check to make sure that the float isnt obstructed in any way, it must float freely in the tank. If something is not allowing it to go down with the fuel level, it will cause the gauge to stick. This is the third component in this LS swap in a 67 Camaro that has not worked and needed modification or troubleshooting. Fun stuff...
      Quote Originally Posted by firstgenguy View Post
    16. #136
      Oct 2008
      Roseville
      Anyone? Anyone?
      69 Chevelle tank...
      I must be out of the loop also. I cant find this bad boy.
    17. #137
      Oct 2008
      Roseville
      Heres the number I came up with. This is for a 68 Camaro
      GM32AFI
    18. #138
      Jun 2009
      Got mine at tanks-to-pans.com...~$485 shipped.
    19. #139
      Feb 2007
      Tinley Park, IL
      I'm still considering this... but would like the fuel gauge to work properly. Would drilling a few small holes on the side (near the bottom) of the fuel well/bucket help the excess fuel in the well return to the main section of the tank? Hopefully without defeating the purpose of the well, which is to keep the pickup submerged at all times.
      Nick ~
      1969 Cutlass
    20. #140
      Jun 2008
      any word yet on this tanks ability to handle high G turning w/o starvation issues?
