    Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 ... LastLast
    Results 21 to 40 of 210
    1. #21
      Newbury Park, CA
      Pics would be great.
    2. #22
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by MuscleRodz View Post
      There are two 70-73 tanks, one with emmissions, one without, and they only go to 73 for efi tanks
      Correct. I discount that for swaps, lol.
      Scott from NJ.
      Vent Windows Forever! ...
    3. #23
      Oct 2005
      Orlando, Fl
      I think this is an A-Body tank, but you get the idea. Pictures from the other thread.
      Michael Barnes
      71 Chevelle - LS1/T56 swap - On the Street!!
    4. #24
      Nice. Does anyone know what the pump output is like?
    5. #25
      Feb 2007
      Plano
      Mine just came in last night from Rockauto....looks great..made in Canada...
      I read the pump is stock capacity and Gm part number that comes in Tahoe/Suburban/Trucks..all though cannot remember where
      69 Camaro LS1 T-56, Corn is for making bourbon
    6. #26
      Feb 2007
      Plano
    7. #27
      Newbury Park, CA
      So is that just a small sump on the bottom of the tank? That might work for straight and normal driving but it won't keep the pump submerged if cornering hard. Current OE setups use a venturi pump and bucket reservoir to overcome low-fuel cornering starvation problems.
    8. #28
      Apr 2004
      OKC, OK
      nope, it is a bucket reservoir, pic is a little decieving. Depending on the tank, 5"-6" tall, about 8" square. Pump is from a late model Chevy truck, I don't remember which one right now. I have a tank on its way to me now. I could give some better pics of the well with dimensions once it arrives.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
    9. #29
      Nov 2007
      near Orlando
      I need some persuading to talk me into one of these over a Rick's. I am going EFI and at first I wanted a stock look and did not know about these tanks. So I researched the Rick's Stainless tanks and like the way they look on cars. Does one have a benefit over the other (other than price).
      RagRat
      Chris Costa
    10. #30
      Newbury Park, CA
      Thanks Mike. This has the makings of a great setup.
    11. #31
      Apr 2004
      OKC, OK
      Quote Originally Posted by Rag-Rat View Post
      Rick's tanks are great tanks. Unless you are mini-tubbing or need wild HP fuel requirements, or want stainless, no need to go to the extra expense.
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
    12. #32
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by trapin View Post
      Alright....about a few months ago I heard a rumor that there was a company called Spectra that builds aftermarket fuel tanks with built-in fuel pumps specifically for LSX conversions into classic cars for around $600-$700 a pop.
      What I want to know is; how do I contact them? Anyone have a website URL? Anyone have one of these tanks? And lastly...is there any truth to all this?
      Thank you gentlemen.
      Mine just showed up today.. GM32AFI for the Track Rat project. Looks good so far.
      1968 Track Rat Camaro:
    13. #33
      Jul 2003
      Anaheim Hills, CA
      Behold the man that turned me onto these... lol
    14. #34
      Jul 2003
      Anaheim Hills, CA
      I do believe this is the pump capacity:
      The tank comes with baffling and sump to stop fuel slosh and prepped for the EFI and features an in tank electric fuel pump that produces 85-115 PSI at 50-60 gallons per hour. This is the perfect tank for a LS conversion and keeps the original look of the factory tank.
      Pump is the same as AC Delco EP381
      with a 3 1/8" in diameter.
      So, would this support your typical LS engine (ie, less than 500hp)?
      Also, I'm going to pull it apart to see if a larger pump can be used.
      It was just over $450... Add in the 'Vette regulator/filter (PN GF822) and you have a cost effective efi fuel system.
    15. #35
      Apr 2004
      OKC, OK
      You won't be disappointed Steve. They are the best efi tank solution if you have the room for a stock tank
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
    16. #36
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by Steve1968LS2 View Post
      Cool, can't wait to see it.
      Scott from NJ.
    17. #37
      Jul 2003
      Anaheim Hills, CA
      I did some noodling and it seems like it would be good up to just over 500hp with the included pump.
      Anyone want to double check my calculations?
    18. #38
      Newbury Park, CA
      That pump is likely a 190LPH. 50GPH = 190LPH.
      If so, no problem for 500HP. 600 would be the upper limit. Magnuson recommended a 190LPH for mine.
      From the Holley site:
      HP/2 = # of fuel
      50 gal * 6#/gal = 300#
      300 = HP/2, HP = 600
      This is likely pretty conservative.
      Looking closer at the above pics, is that a hole in the bottom of the sump? Is that how the sump fills? Does the pump filter cover this hole so that it acts as a one-way valve? Slurping up the fuel from the bottom of the tank through the hole?
    19. #39
      Apr 2004
      OKC, OK
      You are correct, should handle most any stock LSx. LS7 may be the exception. If needed you could get a pump upgrade from someone like Racetronix good up to around 650hp
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
    20. #40
      Apr 2004
      OKC, OK
      HP/2 = # of fuel
      The hole is how the tank self levels when not in use. The return line pumps unused fuel back into the well, and forces the excess fuel to run over the top of the well. No chance of starving the pump unless you run out of fuel. When you shut the car down, if the fuel in the well is higher than the tank, it will gradually self level with the rest of the tank.
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
